Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Mains lead entry
Wires not connected
  • 25 Answers
Take it to reputable dyson engineer
Posted on Sep 05, 2008
Need wiring schematic for ametek 119550
I had the same problem after not paying attention to the connections when replacing my motor. I spent days searching for information and only found several non-answers with small photos that no one can read.I contacted Oreck for wiring information. They explicitly stated that they can't provide any wiring information for safety and liability reasons.
I found the Ametek schematic which shows the LINE and TAP locations on the motor.
Note: I have a 2600HH XL with 2 headlights.
Connect as follows:
3A, LINE: White lead w/piggy back terminal from light harness #1 & white lead from the power harness to the piggy back terminal
2A, TAP: Black lead from light harness #1
3B, LINE: White lead w/piggy back terminal from light harness #2 & black lead from the power harness
2B, TAP: Black lead from light harness #2
Dec 13, 2012 | Vacuums
Pump motor on Bissell 1400 Little Green Machine
When I reassembled mine, there was 3 wires connecting to the motor, Green, black and red. The Green one was connected to the lead on the side of the motor, the black one on the lead directly above the green one, on the same side. The red one was on the lead that was the only lead on that side of the motor. Hope that helps.
Jul 30, 2010 | Bissell 1400 Little Green Pro Canister...
Dyson has no power
The most common cause of this problem would be breakage of the wires in the power cord at the point of entry to the vacuum cleaner body. With the power connected you may be able to prove this by flexing the cord at this point, particularly by pushing the cord toward the body of the vacuum cleaner. If you get any signs of life from the vacuum cleaner you can know that this is the issue (not a foolproof test, but one that can be performed safely, provided that there is no visible damage to the lead).
A qualified repairer will ensure that the vacuum cleaner is not plugged in to the power, open the vacuum cleaner casing, note the wiring connections, disconnect the wiring and and strip the external sheath of the cable back to a point beyond the breakage, cutting off the damaged section of wiring and reconnecting the wires.
See also: http://www.vision6.com.au/em/message/email/view.php?id=638671&u=19329
Apr 05, 2010 | Vacuums
No power
Mar 10, 2010 | Numatic Henry Bagged Canister Vacuum
My dyson will not switch on , the last time I used it the power faded in and out a couple of times I wiggled the lead and it continued to work. However today it will not power up, I have changed the fuse...
hi from uk the symptoms you described is a classic fault with where power wire has broken within the main cable usually at pint where it enters the vac ? hence wriggling wire temporarily makes contact are you sure the wires in plug are connected into their pins securely ? constant pulling on wire whilst vacuuming does cause this fault also kinking in wire you can diy replace the whole cable and replace with longer length as i usually advise so you can reach further without having to swap sockets ? hope this helps/inspires you ?
Dec 05, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My henry just wont work? fuse changed and still not any life? what else could it be ? Thankyou /
could be one the following
faulty mains lead,
mains lead contacts on the cleaner,
on/off switch,
capictor,
wire off motor
Nov 05, 2009 | Vacuums
Need proper wiring connections inside unit, where they have pulled apart from squeeze connectors.(Wiring diagram needed) Can someone E-Mail this to me? Fritz (an ''old'' mechanic) Folks I have talked to,...
Fritz , thanks please confirm... there are likely more than 2 leads from the motor??
I have not seen or worked on the Tristar CXL as it is very new.You will have a high low function but:
Should the power head function at both speeds or only hi speed
How many connectors pulled apart ?
Are the leads fastened onto the motor or are there push on male terminals on a terminal bar beside the motor with leads running off a shroud.
How many leads are on the switch itself....
Either way the wiring pattern will be the same,for all components it will just be a matter of which half of the motor harness connects in which terminal, if you wire it in reverse your speed switch should just function backward. The question is, is there a simple rocker switch for hi low or is there a circuit board type with a speed control on a mini board. If your power head functions at both speeds it will connect from the cord or rewind, prior to the speed switch. If it should only run on hi speed it will be tied into the hi speed half of the two speed switch.
So leaving your green ground out your pattern would be: black to 1 side of rewind to main switch to motor and head together and then remaining back to opposite side of rewind to cord.
Please confirm a bit more info as posted...
Oct 07, 2009 | Vacuums
How to rewire a panasonic vacuum cleaner
Once you have taken the handle off and the front plastic cover below the handle at the front and above the bag/bucket holder, you gain access into the power cable and switch connections.
One wire will disconnect easily, the other won't, so instead of trying take this wire out of its connection where many others are from the switch and the motor, cut it on the mains lead before it enters the connection and reconnect the new mains lead wire with a **** or block connector, the other should connect normally with a spade connecter,making sure its will take the amperage of the v/cleaner
Hope this makes sense!
Sep 18, 2009 | Vacuums
Hi, Fitted new paper bag to this cleaner but have 'No' suction. With bag removed no air movement can be felt at outlet(ie bag entry). Have you any suggestions?. Many thanks, John Pessall.
What kind of model is it?
If you have the bag door open just to feel if there is suction it won't work. The machine would have to have its door put back on before suction can be ascertained. In the meantime check the hose that leads into the bag, or main dust channel - it may well be clogged as well as motor filters usually located under the paper bag.
Mar 02, 2009 | Vacuums
Spare wire?
Greetings from GoVacuum.com,
I took a picture of the Sebo X4 wiring in the handle of the machine for you. This is a brand new machine taken out of the box, this is how the wiring should look. You'll see that there are 5 total wires here. You'll see the positive and negative from the cord at the top, and the wires that come up from the bottom of the handle are below plug. There is a blue, white, and black wire coming up from the bottom of the handle.
The blue and white should be on spade connector below the white cord lead, and on the right hand side the single black wire from the handle should be attached beneath the black cord lead.
If the machine is still working, then it must have been the Blue or ground wire that you removed, correrct? I'm not sure if this will hurt the machine, but the wire is definitely there for a reason, and if you still have it you may want to reconnect it.
If you'd like to contact Sebo directly and speak with a product specialist there, their phone number is;
800-334-6614.
Chris Jones
GoVacuum.com
chris.jones@govacuum.com
Oct 04, 2008 | Sebo Automatic X1 Bagged Upright Vacuum
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
