Question about Toshiba 32AF43 32" TV
Toshioba TV colour not sharp
Redish and greenish colurs only.Sometimes it does show good picture but reddish colour apeared on upper corners.You could be watching football macth and grass would look blue.
  • Munta Mar 01, 2008
    I will try this,and tell you tomorow if it worked.It is true,the set is near the wall,but there are no magnets I know of, around it.
    Thanks
    Scholar:
  • 135 Answers
Hi there!
There might be a problem on the degausing circuit. This demagnetises the screen every time you switch on. You may also have had a rise in the mains voltage thus magnetising the tube. Perhaps you can try switching off the TV at the wall for 24 hours or over night. If this does not work a repairer will have to remove it manually or repair the degausing circuit. Also make sure that there are no speakers or any magnetic items close to the TV. Good luck,JUS004
Posted on Feb 29, 2008
There seems to be a reddish tint. How can I fix that?
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Mar 12, 2011 | Hitachi 51F510 51" Rear Projection...
The picture is not clear. It has a red/greenish haze or gloss over the screen which distorts the sharpness. The manual controls do not help. What can I do?
Feb 28, 2011 | Akai PT5492S 54" Rear Projection...
I have a 60vf820 hdtv. The pictures appears to have a greenish tint but not all of the time. Sometimes the screen looks dim and sometimes appears normal. I have had the tv for 4 years and replaced the lamp...
Feb 28, 2011 | Hitachi UltraVision 60VF820 TV
Sharp LC37D44U Power LED was flashing green. TV would turn on, channel indicator shows in upper right corner, sound good, but screen would be black. Channel indicator disappears but screen is still...
I had the same problem. all the service reset would only make the display come on for a few second with no "k" on the screen - only the channel would show up. I purchased a complete set of board for the lcd on ebay, and started swapping them one by one. The inverter boards were the culpret. Tele working 100% since that board swap.
Nov 16, 2010 | Sharp Aquos LC37D44U 37 in. LCD HDTV
AV-32F703 has redish flare upper right corner. Is
bulb problem. needs to be replaced. the tv looks a little old maybe yu need a new v for once.
Feb 17, 2010 | JVC AV-32F703 32" TV
I have a good picture But it is too green. Is there an adjustment?
first turn your colur to black and white at front control..behind the pic tube got a card there got 3 variable resistor mark as R G B tune this three control to get pure black and white colour untill you satisfied then adjust back front colour volume must be ok otherwise replace the RGB ic/transister
Jun 03, 2009 | Sharp 13K-M100 13" TV
The black is printing dark redish brown
Dear friend, your Black Ink Cartridge is Empty thats why your printer is using the Colour Cartridge to produce the Black Colour. This is the reason you are having Dark Reddish Brown colour instead of Black.
Apr 08, 2009 | HP Deskjet 6940 InkJet Printer
Screen patch
Sometimes lcds will turn a yellow/brown/redish colour if they overheat. normally this will not cause long term damage to the screen but it is not good for it, try letting the monitor cool then using commpressed air to get rid of dust or attach a small fan to see if it helps. This may not fix the problem but should confirm if thats what it is.
Oct 30, 2006 | Samsung 997DF 19" CRT Monitor
Toshiba 32AF43 32" TV Logo
62 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
