Question about EPoX EP-4PLAI Motherboard
Still a problem
Can you give me a answer to solve my computer problem? i put my memory in slot 1 and it run easily but after a month ago i experience that my computer restart and sometimes i used my pc then a blue screen appear and have a message but i cant read at all because it restart my pc then i try to connect my memory to slot2 and i run it and have no problem at all to used. but after at all i used it for a week i heard a long beep then i try to connect it in slot 1 again but there is still a long beep after that i bring it back to slot 2 and clean again my memory and it works but when i shut down my pc and i want to used it again the problems go back as a long beep.. what should i do to solve this problem?
  • enigma pulp Feb 28, 2008
    help me!!!!!!!
    Scholar:
  • 93 Answers
The blue screen flash and restard is actually a critical system message, but windows is set to restsrt the system on a system failure, if you want to read the message, start the computer and tap the "F8" key until a menu appears, one of the options will be "disable automatic restart on system failure" select this option and the next time it happens it will stay there.. but from what you are describing it is pretty evident you have bad ram, the long beeps you are hearing is the mainboard signalling a critical error, usually caused by ram, get new ram and i think you will have no problems
Posted on Feb 28, 2008
I installed 5G memory cards to my Gateway GT5238 PC, 1024 MB DDR2, Intel core 2 Duo E6300, 9-in-1 memory card reader, Non EEC, 4 slots, max memory 8192MB (8GB), PC2-6400, 8500, 5300, RAM DDR2. It had 1G to...
  • You Gateway only supports up to 8 GB. memory. Hence it will not see your 5 GB. dimms
  • tops: 8129 MB (8 GB.). 4- 2GB. Adding the maximum amount of memory will improve performance and help extend the useful life of your system as you run increasingly demanding software applications in the future.
  • Specs:
  • Installed: 1024 MB DDR2 (PC4200), 533 MHz memory (two 512 MB modules)
  • Expandable to: 8 GB (4 memory slots)
  • How much memory your Windows OS will recognize depends on which version of Windows you are running. 32-bit versions of Windows will see (and utilize) only 3GB or 3.5GB. To utilize more memory, install a 64-bit version of your OS. More information about OS memory maximums can be found at http://www.crucial.com/kb/answer.aspx?qid=4251.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
    Thanks, Joe
    Dec 02, 2010 | Gateway Computers & Internet
    My computer need to install more memory what i need to do
    First you need to check your owner's manual or online at the Gateway site to find out how much memory your computer can hold and what type.
    Then you need to see how many memory slots you have. You can then go out and buy the memory you need and remove the old and put in the new.
    You may just be able to add memory if there are empty slots--otherwise, you'll have to remove the old smaller memory sticks and replace them with larger ones.
    Jul 19, 2010 | Gateway Computers & Internet
    My computer keeps alerting that I don't have enough memory to run Excel 2007 or Word 2007. I just bought more RAM and it still alerts that there isn't enough (upgraded from 2 512's to 2 1 Gb's)! What's...
    Hi there i will help you to get this problem fix: first i must tell you that its only a memory problem its not that the memory is bad, it mean that the computer is not recognizing the memory you put in and this can happen if the memory is not fit correctly into the slot, so you should double check to make sure the memory is fit properly in the slot if you still experience the problem then you should ask someone with more ideas to put it in for you , if the problem still exist take the memory back to the store along with the original 1 and let them exchange it for you with similar to those you take out and if the problem still exist there might be a problem with the memory slot
    thanks for asking
    if my advise is helpful to this problem kindly vote for me
    hbristol173
    Mar 30, 2010 | Dell Inspiron 6000 Notebook
    It beeps and will not boot an intermittent beep.I checked to see if the components seemed seated correctly as far as I know they are I am a total novice.Any way it will not boot in anyway and the beep was...
    Take out the memory thats inside of the computer and reseat each memory one stick at a time in each slot one at a time. Try turning on the computer as well after each reseat to see if the beeps go away.
    If that doesn't work then take out the processor and reseat it as well.
    If the computer has a video card in one of the slots, take that out and reseat that as well.
    If after all of this the computer still beeps, then the motherboard is bad.
    Nov 30, 2009 | E-Machines T3265 PC Desktop
    Upgrading the RAM. Can't find where to put it.
    The computer has two memory expansion slots—Slot A and
    Slot B. You can install one or two memory modules.
    1 Shut down your computer completely using the Shut Down
    command.
    2 Unplug the computer.
    CAUTION: Installing a memory module with the computer’s
    power on may damage the computer, the module, or both.
    3 Close the display panel and remove any cables you may have
    connected.
    4 Turn the computer upside down.
    5 Locate and remove the screws that hold the cover plate in
    place, then remove the cover from the bay.
    Removing the memory module cover
    CAUTION: Static electricity can damage the memory module.
    Before you handle the module, touch a grounded metal
    surface to discharge any static electricity you may have built
    up.
    To avoid damaging the memory module, be careful not to
    touch its pin connector on the side you insert into the
    computer.
    6 Remove the new memory module from its antistatic
    packaging.
    7 Insert the memory module in the slot and gently press it down
    into place.
    The clips on either side of the module will click to secure the
    module.
    Inserting the memory module into the slot
    8 Replace the cover plate and the screws.
    9 Turn the computer over and restart it.
    When you turn on the computer, it automatically recognizes
    the additional memory.
    Removing a memory module
    If you need to remove a memory module:
    1 Complete steps 1–6 in “Installing a memory module” to shut
    down the computer and open the memory module cover.
    2 Pull the clips away from the memory module.
    The memory module pops partially out of the slot.
    Adding memory
    Pulling the clips away from the memory module
    3 Carefully remove the module from the slot.
    4 Replace the cover plate and screws.
    May 15, 2009 | Toshiba Satellite Pro 6100 Notebook
    Compatability of Memory Upgrade
    DDR RAM needs to be installed in pairs, as in if you have two 1GB sticks these would, in a four slot board, be inserted in slots 1 and 3 or 2 and 4. The other odd 512MB stick could go in any other slot theoretically speaking. But, you would be better off leaving it out. The SPD chips on the two 1GB sticks should match themselves to time at the slowest common or fastest common denominator.
    There is a chance that by having the odd bank population that you said worked for awhile installed as you had, that the MB RAM slots were put under unusual voltage stess. There is a pretty good chance you can remove the 512MB stick, leave the two 1GB sticks in slots 1 and 3 or 2 and 4. But, this is VERY important: consult your board manual or access it online and read what the population requirments are for the slots as in some cases, the two matched sticks go in 1 and 2 or 3 and 4. This little oddity is found from time to time.
    Consult your manual or download it and read how the slots need to be populated and stick with the two 1GB sticks.
    There are memory testing programs you can find for free at majorgeeks dot com and test your RAM once you have it populated correctly.
    In the future, I'd suggest you purchase RAM from Kingston or Corsair directly online as they usually offer a lifetime warranty and this RAM right now for you board is dirt cheap.
    Hope this FIXED, as in ANSWERED you question and was more than helpful. Should you feel compelled to rate this solution after reading, either rate it FIXED or not at all. I know its helpful by default, that's what we do here. But only a thorough answer can FIX your situation. You should be fine if you follow my instructions. But, please consult you manual.
    Regards,
    Worldvet
    Nov 20, 2008 | Computers & Internet
    Recently bought a 1GB Memory Unit from Kingston Check compatablity in stuff-Uk.net and was confirm that this would be the correct unit i have been running the unit along side the existing Unit purchased...
    have to tried to run both sticks in the slot thats working 1 at a time to check theres not a problem with the ram itself, try moving the 1 thats working now into the other slot and see if it works, then try the other stick of ram
    Aug 11, 2008 | Acer Computers & Internet
    Installing Memory
    put the new ram in slots 2 and 4.
    Slots 1 & 2 are channel 1 slots 3 & 4 are channel 2, you need matching sets in each channel to run dual channel mode.
    Jun 09, 2008 | Gateway 507GR PC Desktop
    Double boot
    almost anything is possible, but in general a 430 watt P/S should be able to run 2 gigs of ram, however that doesn't mean that the ram you purchased is the correct ram for the motherboard or that you have so many other added perpherials i.e. dual or tripe CD drives, hard drives, USB perpherials that the load is simply to great for your P/S. A rule of thumb is find out what your system ' will ' run with and then work from there. For example if a person was serous about this problem he might disconnect all power connectors to all other equipment other then his hard drive, monitor/video card, and his motherboard just to see if the system could then boot normally. If it did, chances are the memory is okay for the motherboard in normal circumstances. However if the system did not boot normally, it might be an incompatibility with the 2 gigs of memory on that particular motherboard. Memory is not a generic add-on. A person needs to make sure the memory is correct for a motherboard before installing. Also you indicate the present P/S is only 4 months old, any particular reason why you had it changed out to begin with??
    Feb 27, 2008 | Biostar P4M80-M4 Motherboard
    SDHC Memory Card error
    I had exactly the same problem with a 2 year old LX-1. The card worked fine on the computer, formated no problem but would not work in the camera.
    I took a can of air and used maybe 3 one second bursts to blow out the card slot. Card immediately started working.
    -prmolina
    Feb 19, 2008 | Panasonic Lumix DMC-FZ18K Digital Camera
    EPoX EP-4PLAI Motherboard Logo
    160 people viewed this question
    Top EPoX Computers & Internet Experts
    David
    David
    Steven Wander
    Steven Wander
    Are you an EPoX Computer and Internet Expert? Answer questions, earn points and help others
