Question about Car Audio & Video
Stereo is the wiring there for the sub if you don,t have one in a 2007 chevy hhr
You can use the factory wiring but, it would sound better with an after market stereo and RCA plugs. You should look into some amp wiring kits for your vehicle. More than likely you will nee an amp to push a set of subs.
Posted on Mar 02, 2008
Stero wiring for a chevy hhr
Chevrolet HHR Car Radio Wiring Chart Car Radio Battery Constant 12v+ Wire: Red/White
Car Radio Accessory Switched 12v+ Wire: Run a wire to the steering column and use the brown wire at the front of the center console on the passenger side.
Car Radio Ground Wire: Black/White
Car Stereo Power Antenna Trigger Wire: Pink
Car Stereo Amp Turn On Trigger Wire: Pink Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Dark Green
Right Front Speaker Positive Wire (+): Light Green/White
Right Front Speaker Negative Wire (-): Light Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Brown/White
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Tan
Jul 14, 2017 | Cars & Trucks
Which fuse in the fuse for the stereo on a 2006 HHR
Three sound sytems were offered in the 2006 HHR: without a separate amp, with a separate amp, and satellite. Check the 15A RDO FUSE in the body control module and, if you have the separate amplifier, the 30A AMP FUSE in the BCM.
Sep 07, 2014 | OEM 2006 Chevy HHR Radio / CD Player...
Chevy HHR stereo treble only
Does it do w/the radio AND CD player? If it has an AUX input jack does that do it too? If it does w/all audio types the stereo sounds (no pun) like it's bad....good reason for an upgrade? Or buy another used one off of Ebay.
Also, using the Balance and Fader controls see if it's just one speaker or all of them.
GL,
TD
Mar 06, 2014 | Vehicle Parts & Accessories
Install amp in chevy hhr
First do you have an aftermarket stereo? If not you'll probably want to purchase one. You don't NEED to have an aftermarket unit, but i highly recommend it. Assuming you use an after market unit do this. First determine where you'll mount the amp, choose somewhere secure, and not in a tiny compartment. Once you've decided where you'll put it run a minimum 6gauge power wire from your battery to the amp location. Within 18in from the battery on that power wire, insert a 95-100 amp inline fuse. Next run a maximum 20in ground wire from the amp to a chassis ground(if none is there you'll have to make your own, just drill a hole in the aluminum and bolt the wire down)with also min 6gauge. Make sure all the paint around the hole is scraped off and has only bare metal. Next to connect your stereo to the amp, use RCAs. The back of your aftermarket unit will have RCA outputs, run RCA cables from these and plug them into the amp RCA inputs. Note: there's multiple outputs on the back of the headunit, use the one marked sub, or rear, assuming this amp is for subs. Next on the back of the head unit is a wire that is blue with a white stripe, connect this wire to the slot on the amp marked R.E.M. now just hook up your subs an listen to them plow!!!!!!!!!!!! side note when running your RCAs place them on the opposite side of the car from the power wire, this will avoid alternator whine in your subs.... good luck if you have questions please ask.
Sep 23, 2009 | MTX JackHammer JH600 Car Audio Amplifier
2007 HHR AC stops working when it gets too hot outside.
warranty should be good at all chevy dealers
take it back
Aug 03, 2009 | 2007 Chevrolet HHR Special Edition
CAR BATTERY FOR CHEVY 2007 HHR
Your battery is located in the rear under your cargo floor. Where most cars would hide a compact spare.
Dec 22, 2008 | 2007 Chevrolet HHR Special Edition
2007 Chevy HHR Fuse panel
There should be a printed list on the inside of the fuse boxes, as well as in the owners manual. There is one box under the hood, and another on the right side of the console near the passenger's feet.
Nov 17, 2008 | 2006 Chevrolet HHR
Car Audio & Video Logo
148 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
