Question about SAMTRON 55V 15" CRT Monitor
LG 45V model
28-02-2007
Dear sir,
I have LG 45V model monitor.
Problem was Characters and video both vibrating and sine waves like both sides of screen. I have changed 150 uF / 400V capacitor in SMPS. Vibration problem was solved, but new problem starts that black lines/bars moving from top to bottom. If I adjust Voltage adj. port VR901, Black lines goes but Shhh... Shhh... sound starts.
Lines increases with sub brightness adjustment or screen voltages changes from FBT.
Pl. guide me,
Thanks,
Atul
Hai dear, this problem is related s.m.p.s. section. so you can redry soldring at s.m.p.s. section and i hope this problem will solve
Posted on Mar 14, 2008
Generator burning my electronics up
take you generator in and have the output tested for correct voltage and sine wave configuration
electronics rely on a perfect sine wave ac current as a manufactured sine wave affects electronic components such as capacitors, transistors and diodes
generator sets that run an alternator ( not an inverter ) have a pure sine wave and have less affect on electronics.
go google and type in search headings like ---sine wave, inverter sine wave, sine wave affects on electronics, alternator operation and inverter operations and then you may get a pointer as to why your inverter gen set is affecting your electronics
Jul 23, 2016 | Honda EU3000iS Inverter Generator
MY MONITOR MODEL IS LG FLATRON T705SH I CANNOT ADJUST MY SCREEN RESOLUTION I WANT TO KNOW THE VALUES SUCH AS POSITION: SIZE: SHAPE: PLEASE HELP ME OUT SIR AS SOON AS POSSIBLE
Your monitor supports a maximum resolution of 1280 x 1024. If windows fails to give you the option of changing to this resolution and those below it then please follow these suggestions:
Update your video card drivers, if you don't know the manufacturer of your video card try windows update.
Install the latest drivers for your monitor as well.
Your monitors driver click HERE
May 04, 2011 | LG Flatron F700B 17" CRT Monitor
My husband hard wired an inverter for our RV to run the TV & associated equipment. It powers them fine but the reception has lines and dots running through it when on the inverter. We purchased a sine...
It is becaus the inverter erradiate EMI (Eletro Mechanical Interference) and the EMI is picked up by the TV antenna, try moving them a part as far away as you can from each other (the inverter and the TV antenna), there are also some filters you can pusches, but enven with all that stuff you could end up with EMI any way so don't spend to much,
Apr 20, 2011 | Electronics - Others
Hello is this ups a sine wave output or modified sine wave output. Thanks
The manual states when running on AC, it is the same sine wave ouptput that comes in. When running on DC, it is a modified sine wave.
Nov 30, 2010 | Opti -UPS BackUp-Time 525BT (UPS-525BT)...
Frequency Inverters DC-AC
I highly suggest you invest in a good quality inverter. For most equipment either pure or modified sine wave is fine. I would suggest you install a line conditioner after a UPS for any computer products. The line conditioner stabilizes the voltage much more closely than a UPS will.
As far as building your own, I've taken apart a lot of UPS models which have a DC-AC converter in them and they are filled with lots of heavy heat sinks, transistors, resistors, capacitors, etc. You can usually find these very cheap since the batteries die but the converter is fine. Check the input voltage of the original unit and start from there to make one easily that has everything already assembled with minor modifications.
Jan 15, 2018 | Xantrex Technology Ags Harness Cable...
Sir, Print coming out like a sign wave..
sir i have a canon ir3300 machine its print clarity and neetness
but the problem is coming print out is in a waves how can i solve this
Dec 18, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Monitor 2400 heater will shut down when I run My generator
A UPS unit might work. Electronics need steady clean power.
Dec 18, 2008 | Intel CASE 350W PWRS ALLIED W/ 24PIN +...
Out of range
Try lowering your refresh rate from 85hz (or higher) to a lower value around 70hz.
This usually will correct out of range issues.
Jan 28, 2008 | Liquid Video L17LCD2 17" Flat Panel LCD...
Monitor problem
Your request for the exact problem will require a signal injector and use of an oscilloscope or even more test equipment. One possible cause is the contrast set to minimum.
Sep 16, 2006 | LG Studioworks 440SI 14" CRT Monitor
SAMTRON 55V 15" CRT Monitor Logo
71 people viewed this question
Top Samtron Computers & Internet Experts
Daniel Sweetlin
Daniel Sweetlin
Level 1 Expert
pankaj rautela
pankaj rautela
Richard Lilja
Richard Lilja
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
