Question about HP Pavilion dv6000z Notebook
Mini dvds will my dvd reader read mini dvd-rw
  • trov Feb 28, 2008
    i am using a samsung cd-rom sn 124 drive on a lap top and are unable to read mini dvds does this drive support mini dvds
  • trov Feb 28, 2008
    why does my cd-rom not see the mini disc in drive
    Brigadier General:
  • HP Master
  • 3,614 Answers
Some DVD players simply don’t support these types of discs. Others may play VCDs or SVCDs only if the discs were authored with certain settings, which the VCD/SVCD/DVD creation software may point out. The same goes for DVD playback software, although the developer may provide a patch or plug-in to enable this functionality.
First, consult the DVD player’s documentation for VCD/SVCD support. If your DVD player allows firmware updates, as some DVD recorders do, try updating it. Update your DVD playback software if applicable.
Also, you may find that different burning software, even from the same developer, may make discs compatible with your player. For an Apex DVD player, as an example, we were able to create working SVCDs with NeroVision Express, but not with Nero Express. Both titles come in the Nero 6 and 7 Ultra Edition suites.
Try burning the disc at a slower speed. Also, certain brands of CD-R may work better than others for this application. Roxio says that some players cannot read recordable media at all. Other sources say that CD-RWs might work better in some players.
Read up on your disc authoring software’s settings for VCDs and SVCDs in its help file, settings menus, or support section of the developer’s Web site. Try different settings related to compatibility. If all else fails, try the ones that will make “non-standard” discs.
Posted on Feb 28, 2008
    Master:
  • 377 Answers
Yes of course.!
Cheers!
My combo drive is not reading CDs but reading DVDs perfectly
a different laser is used to read CDs than is used to read DVDs. The laser for you CD reader has most likely gone out of alignment. It's time for a drive replacement.
Dec 09, 2010 | LG (GCC-H23NB) CD-RW/DVD-ROM Combo Drive
I spent the last 4 hours trying to troubleshoot why my CD/DVD drive does not recognize DVDs. It recognize when I put a mini Driver and User Guide CD for SUB1.1 to Fast Ethernet converter but it doesn't...
That drive is only a CD reader and writer. It does not have DVD read or write capabilities. No amount of messing with it is going to make it play DVD discs. You will need to upgrade it to a drive that has DVD capabilities.
Mar 28, 2010 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
MACBOOK PRO SuperDrive Reads somes Recorded DVDs fine but some appear as empty while in other mas are fine
some pioneer dvd models have firmware upgrades to solve problems with some DVD brands - check your model and visit the pioneer components website - I have a DVD reader which worked better after the firmware upgrade - try this site http://esupport.sony.com/US/perl/swu-download.pl?mdl=PCVRZ44G&upd_id=1692&os_id=16
May 28, 2009 | Apple Genuine Pioneer "SuperDrive"...
I can burn cd's but not dvd's
Hello Rfd832,
What I see from the description is that the drive is a combo drive. Combo drives are CD-RW and DVD-ROM drives means
CD-RW = Compact Disk-Read Write
DVD-ROM = Digital Versatile Disk - Read Only Memory
so these drives can read and write CDs but can only read DVDs (Cannot write or burn DVDs)
If you want to be able to burn DVDs then you need to have DVD RW drive (either DVD+RW or DVD-RW)
You said that you are able to burn DVDs on other computer so please check the label on the DVD drive.. it should be DVD-RW/DVD+RW drive
Hope that helps.. :)
Thanks and Regards,
Srinivas
Apr 12, 2009 | HP (dc197x) CD-RW/DVD-ROM Combo Drive
Acer Aspire 3000 DVD/CD-RW drive
If its the DVD/RW CD/RW unit it will possibly have...
NTI CD/DVD Burner which is a part of the Arcade System .
Easy to use and stable as anything I have seen before,3
Fast n Friendly,Remembering the max ram is 2GB and
with all barrells loaded performs like a beautiful piece of art.
Also Nero is an old favourite too.
Producing your own dvds from scratch is a satifying excercise and amazing when you can see the look in everyones eyes,,,,
Yes - Impact is everything.
I found your answer,
Grab you machine and look at the symbols on the disk draw.
The device you have is a CD/RW-DVD Rom.
What this means it is a CD Writer and a DVD Reader.
This device will never burn DVDs.sorry
To write DVDs you will need to buy DVD/RW device.
I hope this helps ,please rate me thanks
May 05, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Dought
DVDs are produced in different formats for different DVD readers. Most modern DVD readers will read several formats such as the ones you have mentioned. However, you must make sure your DVD reader is compatible with the DVDs you want to use.
DVD+R and DVD-R are "write once" discs. DVD+RW and DVD-RW are rewriters, so you can write then erase, then write again.
Have a nice day :-)
Mar 21, 2008 | HP DVD Writer (ds703a) (DS703A) DVD+RW...
Mini-DVD playback
You can use Windows media and this has worked for me.
Aug 19, 2007 | Canon DC210 DVD Camcorder
Cannot read the min handy cam dvds
The disc needs to be finalized before you play it on other equipment. But to do this will render the disk unusable- If you intend to record over it in time, So it is best to copy the info across to the PC- burn that to a disk and finalize it then most other DVD players[Not all] will run it.
Aug 14, 2007 | Sony (1-796-388-13) DVD-RW Burner
HP Pavilion dv6000z Notebook Logo
134 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
