Question about Canon FAX-JX200
Caller id i don't see this menu
Press menu
use up and down to select<data registration> then press start
use up and down to select <caller id> then press start. the lcd displays <off>
use up and down to select <on> then press start
press stop to return to main menu
Posted on Apr 17, 2008
How do i turn the voice off n my panasonic 6.0 phone
How do I turn off the Talking Caller ID on my phone? To turn off Talking Caller ID on the base;
  1. Press [MENU] [#] [*] [1] [6] [2]
  2. Press the [?] or the [?] button to turn the base Caller ID on or off.
  3. Press [ SAVE ]
To turn off Talking Caller ID on one of the handsets;
  1. Press [MENU] [#] [1] [6] [2].
  2. Press the [?] or the [?] button to turn the handset Caller ID on or off.
  3. Press [ SAVE ]
Note that the base and each handset are programmed individually.
Jan 16, 2018 | Panasonic Lands Phones
How do i. Turn the voice off on my panasonic 6.0 phone
  3. Press [ SAVE ]
  3. Press [ SAVE ]
How can i turn the voice off on my panasonic 6.0 plus phone
Press [ SAVE ]
Press [ SAVE ]
How do i make my phone number visible to my callers when calling from a Vtech phone
Caller ID
If you subscribe to caller ID service, information about each caller appears after the first or second ring. If you answer a call before the caller information appears on the screen, it will not be saved in the caller ID log. The caller ID log stores up to 50 entries. Each entry has up to 24 digits for the phone number and 15 characters for the name. If the telephone number has more that 15 digits, only the last 15 digits appear. If the name has more than 15 characters, only the first 15 characters are shown and saved in the caller ID log. Review a caller ID log entry Press CID when the phone is not in use. Scroll to browse through the caller ID log. When the desired entry appears: Press repeatedly to show different dialing options. Press 1 repeatedly if you need to add or remove 1 in front of the phone number. Press or to dial the displayed number. Dial a caller ID log entry When the desired entry appears, press or to dial. 1. 2. 1. 2. 3. 4. 1. 2. 3. • 1. 2. • • 3. • Save a caller ID log entry to the phonebook When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Phonebook then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a caller ID log entry When the desired caller ID log entry displays, press DELETE. Delete all caller ID log entries Press MENU when the phone is not in use. Scroll to Caller ID log and then press SELECT. Scroll to Delete all and then press SELECT twice.
Call block
If you subscribe to caller ID service, you can set the telephone to block unknown calls and certain undesired calls. The call block list stores up to 20 entries. Block unknown calls Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Calls w/o num, and then press SELECT. Scroll to choose Not block or Block, and then press SELECT. Add a call block list entry 1. Press MENU when the phone is not in use. 2. Scroll to Call block, and then press SELECT. 3. Scroll to Block list, and then press SELECT. 4. Scroll to Add new entry, and then press SELECT. 5. Enter the number. • Use the dialing keys to enter the number (up to 30 digits). 6. Press SELECT to move to the name. 7. Use the dialing keys to enter the name (up to 15 characters). Additional key presses show other characters of that particular key. 8. Press SELECT to save. 1. • • 1. 2. 3. 4. Review call block list Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Block list, and then press SELECT. Press SELECT to choose Review. Edit a call block list entry When the desired entry displays, press SELECT. Use the dialing keys to edit the number, and then press SELECT. Use the dialing keys to edit the name, and then press SELECT to save. Save a caller ID log entry to call block list 1. When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Call block then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a call block list entry When the desired call block list entry displays, press DELETE.
Mar 15, 2016 | Vtech V CS6419-2 DECT 6.0 Cordless Phone,...
How to I change caller ID setting on LG olympus S
I don't know exactly what you mean by caller ID SETTING, but I guess what you want to do is change you caller ID right? if that is what you want to do call your service provider and have it set up
Aug 05, 2011 | LG Optimus Black Smartphone
My phone ringer is off and I don't know how to turnit on
You may follow the steps below.
1. Press the caller ID-volume ( 6 or 5) button to scroll to the RINGER VOLUME sub-menu.
2. Press mute/program button to enter the menu. SET RINGER 1HI 2LO 3OFF shows in the display.
3. Use the touch tone pad on the handset to select 1, 2 or 3, or use the caller ID-volume
( 6 or 5) button to scroll to your selection. HI is the default setting.
4. Press the mute/program button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
May 12, 2011 | GE Lands Phones
I have a Nokia e71, and everytime I call someone the caller ID on the person's phone says "private caller". How can I change this?
Telephone settings
Select Menu > Tools > Settings > Phone.
Select from the following:
• Call — Define general call settings.
Call settings
To display your phone number to the person you are
calling, select Call > Send my caller ID > Yes. To let
the network determine whether your caller ID is sent,
select Set by network.
Nov 13, 2009 | Nokia E71 Smartphone
I only seem to get Caller I.D.records for calls to line 1
Go into the menu option under set up and go step by step and it will bring you to caller id option. There , you should be able to turn on the caller id for both lines. I just went through this with my parents phones. after you do it you wont believe how easy it was.
Jan 01, 2009 | GE 25865 Cordless Phone
My caller id wont show when i call someone
go to the call menu and then go to caller id menu ... it is turned off .... turn it on and the problem wud b solved
Oct 05, 2008 | Motorola Mobility RAZR V3m Cellular Phone
KX-TG6052 two handsets. Can't get Talking-Caller ID to turn off!
to turn the talking caller id off go to the menu press 0 then * then 4, then press 0 again to select off.
to turn the ringer on the handset back on, go to the menu, prees 1, 1, then press 1 for a low ringer, 2 for medium and 3 for high.
Mar 15, 2008 | Panasonic KX-TG6052B Phone
Canon FAX-JX200 Logo
old marine
old marine
