Question about Toshiba TDP S3 Multimedia Projector
In focus dlp 420
I have just bought two new lamps for my projector, it fires up fans going and music palyed through speakers but the lamps wont light is there a rest button sequence
any help would be much appreciated
  • CRadan Apr 16, 2008
    I work in a school and have the same problem with one of our classroom projectors. Worked great before lunch...came back - no lamp? It has not been used 3000 hours by any means! (Maybe a couple of hundred?)
    Problem Solver:
  • 8 Answers
Or source and volume down for ten seconds
Posted on Jan 15, 2009
  • 563 Answers
Hi Barron
Yes there is , you can try holding down the Menu & Power buttons for a couple of seconds.
Posted on Mar 26, 2008
I have a Benq w710st DLP projector and when i turn the power on after a minute it turns off. The power button turns off and both the lamp and temp lights turn red. How do I fix this and can I do it my
New bulb is probalbly needed. You need to find out what zero means on that projector. The real problem is finding out why the cooling fan is not turning on. This is probably the reason that the temp light is coming on.
Jan 06, 2013 | BenQ W710ST 3D HD Short Throw DLP...
Acer x 1130 dlp projector not lighting but showing red light
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
any questions, feel free to contact me
have a nice day!
Sep 25, 2012 | Acer X1130P 3D Ready DLP Projector...
New lamp placement, fuse caught fire. Melted female and male connection
Sure but you have to go to the mfg for parts or where to go iinfo.
Sep 11, 2017 | Mitsubishi HC1500 DLP Projector
I have a infocus IN35 that at 100 hours burnt out a bulb. Thinking that it was just a bulb problem I bought a new bulb and it lasted 20 minutes. a t.v.repair shop said its probably the ballast that is the...
It is not a common problem. Ballasts rarely need repairs. Have you reset the lamp hours to zero after installing new bulb? If, yes to confirm about ballast please ask the TV repair shop man whether previously he had repaired any DLP projector. There is lot of difference in technology of DLP projector & TV (except DLP Projection TV). The problem could be in the projector main board. The lamp lights after getting Lamp ON signal from the projector main board. As the lamp ignites the ballast sends the signal of Lamp Lit. If the projector board senses that any blower/exhaust fan or colour wheel is not running then it will send a signal to Switch OFF the lamp. If you are tech-savvy then do as follows to check about lamp & ballast. Remove 5 pin connector from the projector. Connect projector to mains supply. Get a 5V DC power supply. Connect +ve to pin 3 & -ve to pin 4 of the ballast connector from this supply. The lamp should light. If it does not light then there is problem in the ballast (if the lamp is new). To give a chance you can check it for your lamp which lasted 20 minutes. Generally ballasts are made by OSRAM. You can get the ballast from OSRAM dealer. You will need the part number for that. Take out the ballast, it is there on it.
Apr 14, 2011 | InFocus IN35 Projector
Optoma hd65 projector new bulb wont turn on...cant reset timer!
I think it's a lamp driver issue from what I've seen others have gone through. I also read that if you go through the sequence of unplugging, plug back in, wait 20 seconds and try to turn on, multiple times, it will finally kick on and work. I just got mine to turn back on by doing this and waiting through the fan cycling without the light turning on. After the 4th sequence the light flickered. After the 7th sequence it finally turned on and is working. Now I can watch the Super Bowl and will look into replacing soon.
Jan 31, 2010 | Optoma HD65 DLP Projector
Projector
Check that you replaced the lamp in the right way, and also that the unit is well reassembled, you may also need to reset lamp counter from menu on some model.
Mar 07, 2009 | Dell 2300MP Multimedia Projector
Lp335 in focus projector lamp not turning on; spark switch gap is sparking
It could be the lamp. I have seen this many times on DLP'S. If the ballast is firing it which is usually around 600 volts or so, then i would say it is fine, and only needs a lamp. Let me know if that helped you. Later Jay
Jan 20, 2008 | Office Equipment & Supplies
Projector Lamps for the Toshiba TDP-MT8 DLP
Have you contacted Toshiba? They will sell you a new fan. It is possible the power supply has a problem. Bulbs usually have a 90 day warranty. Contact where you bought the bulb. Prices are dropping rapidly for new projectors. Yoiu can buy a new oen for under 500.00.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 07, 2007 | Toshiba TDP-MT8 DLP High Definition Home...
Toshiba TDP S3 Multimedia Projector Logo
66 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
