Question about Samsung SyncMaster 753S 17" CRT Monitor
Factory setting Dear Noggin , My samsung syncmaster 15GLi moniter is suffering a color tech. prblem i want to open the factory setting of it .And set the R.G.B
    Scholar:
  • 101 Answers
Right click on your desktop and choose properties. This will take you into the display settings. Look at the adapter settings for your display driver and the RGB settings should be in there.
Posted on Feb 28, 2008
Mac mini is not showing the display(moniter using syncMaster 940bw moniter)
try to adjust the resolution settings of your mac mini using other monitor.It works for me
Sep 14, 2011 | Samsung Computers & Internet
My moniter's setting has changed by me. plz resolve it.
if you fint it difficult to readjust the moniter settings just install the display driver once more it will be alright plz vote
Feb 27, 2011 | Samsung SyncMaster 793DF (Silver, Black)...
When i plugged in my samsung fx2490hd moniter it doesnt display correctly...the borders are not right as it is extended more than usaul...when i look on my adapter staus it says its a generic moniter :( i...
there nothing problem with this you have to only readjust the settings in LCD moniter a switch named AUTO can be visible clicking that button can readjust all the setting with one click thnx PLZ VOTE
Feb 21, 2011 | Samsung SyncMaster FX2490HD 24 inch...
No green color
Dears,
It happens due to either the PC settings or the monitor (hardware) settings. Would advise you to select menu from the monitor and do a factory setting do a quick check by using paint. The other option here is to access the color management in the control panel, there select the RGB values appropriately Hope this solution helps !!
Nov 09, 2009 | Samsung SyncMaster 700 (White) 17 in.CRT...
My monitor's color is mixed with the color yellow
There is an option on the monitor to reset colour to factory default. Just bring up the on screen menu by pressing the left most button at the botton. Use the button next to this to highlight the colour settings which I think is the 5th or next to last option down. You will then see the option to reset colour and various other factory default settings. Happy computing
Jul 21, 2009 | Samsung SyncMaster 940N Flat panel Monitor
Window does not expand to entire moniter
right click mouse
select Graphic Properties
select Display Settings
select Display Expansion
select Full Screen (No Border)
Mar 24, 2009 | Samsung SyncMaster 205BW LCD Monitor
New moniter too dim.
Good morning! Please review the operations manual of the unit, taking note of set-up settings value requirements. best regards.
Mar 20, 2009 | Samsung SyncMaster 920NW Monitor
My acer laptop with windows xp will not allow me to select the optimal resolution for my samsung moniter. How do I fix this?
The Samsung SyncMaster 730b is a 17-inch analog and digital TFT-LCD monitor delivering crisp, clean text and bright, vivid colors. This display offers a 600:1 contrast ratio, 300 cd/m2 brightness, 1280 x 1024 resolution, 160/160 degree viewing angle, scanning frequency of 30-81 kHz horizontal and 56-75 Hz vertical and 0.294mm pixel pitch
The SyncMaster 730b display offers the option of using either a digital or analog interface for viewing images and text. The Digital Video Interface (DVI) ensures a shaper, cleaner image and a more accurate representation of the original video source. Since video starts out digital in a PC graphics card, the digital output is directly interfaced to the digital input of the LCD panel and always provides the optimum quality image. In addition, no adjustments are required with a digital display, even when randomly changing resolutions. Input connectors for this display include 15-pin D-sub and DVI-D. Available in black, the SyncMaster 730b delivers a maximum of 16.2 million colors. The monitor is Windows Plug and Play DDC 2B compatible
The important stuff here would be the following:
(1) 30-81 kHz horizontal and 56-75 Hz vertical
(2) SyncMaster 730b delivers a maximum of 16.2 million colors
(3) 1280 x 1024 resolution
nVidia card settings should not exceed these monitor parameters. The monitor is not designed for more performance output without increasing liability toward failure. ?. Put your card settings, under the nVidia tab, at the following:
(a) Refresh rate set at 75 Hz
(b) Set colors at 16 million
(c) Set resolution slightly less than 1280 x 1024
It?s quite possible your monitor is at fault, but start with its optimal parameter settings for the display card first. The display card probably exceeds the monitor?s capabilities. Hopefully, this will stabilize your PC session and the blank outs cease if hardware is not faulty
May 23, 2008 | Computers & Internet
Samsung syncmaster 713bm hoe can i reset it to factory settings?
Im not so sure but i downloaded the pdf and it should be in the menu open from the monitor
http://downloadcenter.samsung.com/content/UM/200506/20050602113228171_BN59-00420Y-02Eng.pdf
Apr 01, 2008 | Samsung SyncMaster 713BM 17" LCD Monitor
Pinkish Color on Monitor
Most likely it is your VGA cable gone bad. I remember doing a warranty call for HP once, I was the third tech to go out and replace a motherboard. When I got there, I found out that the cable was bad and it was giving everything a blue tint. I would certainly recommend replacing the VGA cable. I bet if you wiggled the VGA (monitor) cable on the back of your computer, it will come and go.
Jun 09, 2007 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Samsung SyncMaster 753S 17" CRT Monitor Logo
549 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
