Question about RIM BlackBerry Pearl 8100
Blackberry pearl My blackberry pearl's up volume button will not work at all. Is there another way to change the volume? And I tried to use Radioshack headphones with a headphone jack and it wouldnt work either!
  • pt88 Mar 04, 2008
    It works! You saved my phone from being thrown out the window. Thank you!
  • Anonymous May 09, 2009
    i cat get the volume to go up whenlisteningto msic tho
Oh you just saved my phone- thanks so much
Posted on Feb 27, 2009
I had the same problem and had to change the Default Call Volume from Previous to a percentage. This will get the volume up and you can use the down volume button to adjust the volume lower.
To get to this option:
Select Call Log.
Click on the pearl and select Full Menu.
Select Options and then General Options.
Change and save Default Call Volume.
Posted on Mar 03, 2008
Cannot hear caller from blackberry pearl 8100
try going to the settings on your phone and go to volume. Not the side buttons. Hoped that helped.
Jul 09, 2010 | RIM BlackBerry Pearl 8100
Volume is very low
If the volume is still low after increasing it via the button on the side and the unit is still under warranty...return it for a replacement.
Cheers!
Dec 29, 2009 | RIM BlackBerry Pearl 8100
Ringer Not Working Properly
i would check your profiles. usually the default setting for the load profile is for it to vibrate twice and then ring, so that usually only gave you two rings to answer the phone after it vibrated twice. make sure that within your profile setting that you have it to ring with a tone, and make sure you have a volume selected. i would also use blackberry desktop manager and perform a back up or sync of your blackberry, and then perform a wipe handheld. the wipe hand held feature is in your options---security---general settings---and then press your options button (right of the trackball) and select wipe hand held. you will type the word blackberry and then it will wipe the handset. after it resets try the volume before you restore it, if you still don't have volume your speaker is bad.
Nov 05, 2009 | RIM BlackBerry Pearl 8100
My blackberry pearls volume isnt working very well how do i fix it
the button might be worn i recommend you bring to a technician let him analysis the situation and tell you if the button needs to be replaced or not
Jun 14, 2009 | RIM BlackBerry Pearl 8100
Low custom (individual) ring volume
This is not a B/B fault, unfortunatley the person who recorded the ringtone has recorded it at a low level, import into a wave/mp3 studio program and alter the recorded levels.
That is if you have tried the following:
Select Speaker Icon on the front screen of your 8100 (top right) press pearl in, scroll down to advanced, select the current profile (this is defaulted to Normal). Scroll to Phone and press pearl in.
Change Volume to High, if it's already on high, try the option above.
Gadget
May 27, 2009 | RIM BlackBerry Bold 9000 Smartphone
I can not hear anything on my pearl when I answer the phone
when in the call push the volume button on the side of the blackberry
May 20, 2009 | RIM BlackBerry Pearl 8100
Blackberry 8320
On the right hand side of your blackberry click the top button!
Failing that, from your desktop go to
Profile
Loud
Activate
In this menu press your blackberry button and you have a shorter menu - Choose Edit
Which of the volume levels do you want to turn up, you will see a list - volume - Choose from escalating to mute.
Apr 27, 2009 | RIM BlackBerry Pearl 8100
Volume Control on a Blackberry 8100
you need to go to profiles then advanced select the profile loud,vibrate,quiet or normal then select phone and update the options for tune,volume etc.
Mar 21, 2009 | RIM BlackBerry Pearl 8100
Too loud!!
You can hit the arrow button to make sure your on the main screen there should be an icon with a loud speaker either in top right corner of main screen or by pressing the blackberry button. Then selecting the volume button. If this doesn't work send me some clarification and I will Troubleshoot further.
Dec 30, 2008 | RIM BlackBerry Pearl 8100
RIM BlackBerry  Pearl  8100 Logo
660 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
