Question about Acer Aspire 1640Z Notebook
Wont come on
My daughter took a flight and when returning home she tried to powerup her notebook but it will not come on. The power supply light is steady green until plugged into the notebook and then it blinks (steadily) and is not as bright. the notebook worked fine before her trip and while she was there she did not use it at all. she did check it as baggage at the the airport on the return flight. she has no manual or disk for it either. she gave it to me and said if I get it to work its mine...help! MY SYSTEM DOES NOT COME UP BUT WHEN I PRESS CTRL-ALT-DEL, IT SHOWS SOME PROCESSES BUT THE PC IS NOT WORKING
I have same problem with HP Compaq Presario V6000. LEDs are lit. Cooling fan stops after a short while. A faint click sound can be heard soon after switching. I tried Ctl Alt Del. But no joy. I gone through the troubleshooting in web. Found follwing remedies.
1. Hardware problem. 2. RAM to be re-seated. Cooling fan to be cleaned. 3 Probable BIOS problem. But I have not yet tried all these. Awaiting to procure proper tools. Thank you Baby Antony
Posted on Mar 01, 2008
My mom gave my daughter Casio ctk551 keyboard adapter has power and we've tried batteries keyboard will not come on noticed a little rust on back plate took off clean with dry cloth nothing any sugges
Rust is an indication that the unit has water or moisture damage. The keyboard should power up using batteries or the adapter. Is the adapter is one supplied by Casio? Perhaps the batteries were/are put in the unit in the wrong direction or polarity? Take the batteries out completely and then try the power adapter. If this fails, I suggest returning the Casio for a replacement.
Dec 27, 2014 | Casio Music
Power light is on no status light wont power up tried new bulb.
Did you ever find a solution to the no-powerup? My HC1100 has started doing the same thing.
Apr 11, 2011 | Mitsubishi HC1100 DLP Projector
Lights come on but no fans or powerup
Please follow the steps below.
1. Please removed the battery and unplugged the power supply.
2. Held down the power button for 45 seconds.
3. After 45 seconds reinstalled the battery and the power supply and pushed the power button and if it works then you don't need to replace your motherboard.
4. Else try it couple of times or up to five times before it worked if worst comes to worst.
Thanks
Aug 26, 2009 | Acer Aspire 5050-3242 Notebook
My laptop will not powerup .....
so does the laptop turn on at all with just the battery in. or is the battery got a charge
Apr 15, 2009 | Acer Extensa 5420-5687 Notebook
Laptop Dead, Wont power up
its power button doe not work please change it as soon as possible
Apr 14, 2009 | Acer Extensa 5420-5687 Notebook
Laptop won't power on
Check the power light indicator if it work when turnig on the laptop. If doest work replace the power supply
Feb 12, 2009 | HP Compaq Presario V2405us PC Notebook
Oshiba Satellite A55-106
Can be because power supply is not correct supply or give incorrect supply voltage causing battery to drain or not charge fully,battery can be caput aswell, some laptops doesn't start if battery isn't conditioned properly. JJ
Sep 15, 2007 | Toshiba Satellite Pro 6000 Notebook
Wont come on
The fact that the light on the power supply is a brighter green and them dims when plugs is certainly a key factor. I would say there are three possible problems. 1) The first problem to check is by far the easiest. Try removing the battery from the laptop and then hooking up the power supply. Do you get the same result. If it works then replace the battery. Problems two and three are unfortunately a lot harder to tell without having a spare power supply. Not to sound stupid but you've either got a problem with the power supply or laptop. If it is the laptop then you'll likely want to toss it out as you would need to send it off for repair. If it is the power supply then that can be replaced fairly cost effectively. Places like best buy and radio shack sell universal power adapters for laptops which could be used to test for the power supply being the issue. Perhaps you could bring it to the tech bench at best buy and ask if they have an adapter you can try before you buy. Radio shack might also let you do the same thing. If all else fails, perhaps you could return the adapter if you purchased it and it didn't solve the problem. Good luck.
Sep 04, 2007 | Acer Aspire 1642WLMi Notebook
Won't power up.
Check or replace the circular bios battery. Its a small round disc type about the size of a quarter.
Jul 26, 2007 | HP Compaq Presario V2000 Notebook
Acer Aspire 1640Z Notebook Logo
42 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
