Question about Refrigerators
Badly condensating fridge - How do I stop it
I have a Westinghouse upright fridge/freezer (approx 200L). I've just switched it on after a year in storage. The freezer seems to be working fine, but there is water dripping from all over the inside of the fridge shelves and compartments - it's condensating very badly. Can someone suggest what might be causing this. By the way, I was given the fridge and put it straight into storage so I do not know what temperature it was set on before storage, or whether it had condensation problems before I got it.
    President:
  • Refrigerators Master
  • 2,651 Answers
Sounds as if you have a door not closing possibly. check your door seals, if refrig door doesnt seal all around your going to be getting warm air leaking in and will condense on the colder shelves and upper wall for sure
Posted on Feb 28, 2008
My Westinghouse model numberMRVC25V9DS9 fridge and freezer compartments are not cooling but all control lights are on and the interior lights are working. Does anyone know the answer please?
First assuming the compressor is operating clean the condenser and be sure the condenser fan is operating, if so and the condenser is not getting hot you need a service tech to find and repair the leak and recharge the unit.
Dec 10, 2014 | Westinghouse Refrigerators
Hi, Have a Westinghouse Fridge/Freezer BJ414BQ-RWZ, approx 14 years old. Has recently not keeping cool enough. Looking for tips on what I can do to correct. Tried turning a white knob on rear/base of...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 04, 2011 | Westinghouse Refrigerators
Hi, I've recently found that my westinghouse
if the back wall of the freezer is iced up the problem is most likely the defrost thermostat.
May 06, 2011 | Westinghouse Refrigerators
LG Fridge-Freezer model no. GR-T632DVQ The upper freezer lights works. The lower fridge light stopped working. When tested the light bulb works and is NOT broken. There is a combination double...
looking for a door for lg refrigerator GR-T632DVQ
if anyone can help me plz ring 0421203100
perfect fridge, had it for 10 years, door fell off today :(
i've been searching everywhere, *sigh
please help if u can
Mar 16, 2011 | Refrigerators
Westinghouse fridge/freezer (freezer on top) has suddenly stopped working (purchased December 2003). I can still hear something running (motor?!), any suggestions please?
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Oct 07, 2010 | Westinghouse Refrigerators
I have a service upright fridge freezer about 4-5 years old suddenly fridge half stopped working. The freezer half still on and freezer is on but not freezing as normal all lights are on ( internal)
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Aug 24, 2010 | Refrigerators
Red alarm light is on on Westinghouse upright freezer
Most probably during transportation either the coolant(previously freon gas) may have leaked out so the pressure on the cooling pipeline causing the red alarm because the compressor will overheat if the fridge is kept running at very cold thermostat readings and no effect of cooling the fridge will ultimately result in the compressor getting burnt. However fist have look at thermostat setting knob which could have loosened during transportation and just pushed into the spindle without knowing the correct angle, thus even though it looks as if on high cool but could also be the lowest setting..........sodeep
May 19, 2009 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Westinghouse fridge: no cool air circulating inside
Art, I need to get a little more information from you. Does the condenser fan under the refrigerator seem to work and blowing warm air from below and or behind the refrigerator? The motor feeling warm is OK. Only when too hot to touch on top. Needs to cycle also. When you opened the freezer did you hear the fan blowing? Thanks, JT
Apr 18, 2009 | Westinghouse Refrigerators
Kenmore upright fridge--freezer door drips when cleaning
Condensation has formed and frozen behing the door panel. You can live with it, or take apart the panel and dry it out - you may have to replace some insulation. Hope this helps!
Feb 07, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerators Logo
194 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
