Question about Nokia 3650
Reformat i have nokia 3650 and when i try to reformat it using *#7370# it does not completely reformat my phone... it just resets the setting... my contacts are not even erased... what should i do?please help me.. thanks
  • johnrexter Mar 31, 2008
    it does not solve the problem either
    Problem Solver:
1st backup any file you dont want to lose, then remove your memory card and then format your phone by pressing together the call key, * key, 3 key and the on/off key.
Posted on Jun 18, 2008
    Guru:
  • 167 Answers
Try to remove your memory card firts before you format it...
Posted on Mar 04, 2008
How to reformat the phone memory of nokia e5-00
you can perform a full format by pressing *#7370#
then enter your security code, if not changed before, 12345.
Note: all data will be lost.
Nov 13, 2011 | Nokia E5 Cell Phone
I forget my code to reset the setting of my phone E63
Careful, it will erase your personal data on the phone.
You can try to restore to factory settings by dialling *#7780#
or you can
Reformat your phone by dialling *#7370#
or you can go to your local diller to reflash the phone
Oct 05, 2011 | Nokia E63 Cell Phone
How to reformat it
I found on this site:
http://www.filesaveas.com/3650.html
We accept no responsibility for use of this code. It is undocumented, not supported by Nokia and should be used at your own risk.
The soft-format code for Series 60 phones is *#7370# . You enter this code as you would enter a phone number in the Phone application. It performs a format of the Internal drive - All data will be lost if you use this feature.
s60reset.gif The method of performing a hard-format, i.e resetting it completely to factory defaults and removing all data, is as follows:
  1. Switch off the phone.
  2. Hold down the following three buttons: Green (call answer) button, * button, and '3' button
  3. While holding these buttons, press the power button and switch on the phone
  4. When the message 'Formatting' appears on the screen, release all of the buttons
Note that you shouldn't switch the phone off or remove the battery when performing either of these operations, and it's advised that the handset has a reasonable amount of battery charge before performing a format/reset.
Mar 12, 2011 | Nokia 3650
I want to format my nokia 6300
Press *# 7370 # and it will be formatted.
Jan 12, 2011 | Nokia 6300 Cellular Phone
How to re format and put key code plss help
First Format your MMC: Menu > Extras > Memory > Options > Format mem. card > Yes.
Note: It is very important to format your MMC before you format your phone!
Then format your phone by typing *#7370# on main Phone screen.
Phone will ask: “Restore all original phone settings? Phone will restart.” Press ‘Yes’ and enter your Lock code (default is 12345).
Tip: Formatting takes several minutes so you’d better connect your Nokia 3650 to a charger to ensure that your battery doesn’t get empty in the middle of formatting.
Note: All your created access points and mailboxes will be lost so take a note of them. And all application settings will be reset.
E.g. In Camera, image quality is set back to normal and memory in use is set back to phone memory. And also in Messages, memory in use is set back to phone memory, etc. Also backup your contacts with PC Suite or a program like Contacts Manager.
Nov 11, 2009 | Nokia 3650
Reprogram my nokia 3650
reformat the card on your pc then placed it back in the phone.
Jun 01, 2009 | Nokia 3650
Reformat 3650
no hindi kaya mag sariling program ang phone mo kailangan sa computer sa twister device, or jaff device kailangan mo mag punta sa cell phone tecnician dun mo pa format para ma reset ang phone mo
Sep 26, 2008 | Nokia 3650
How to reformat manualy a nokia 3650?
type *#7370# then 12345 for the security code
sexy-ym
Sep 02, 2008 | Nokia 3650
Nokia 3230 start-up failed
have you tried reformatting it??
try this
12345 is a standard code and 00000, but if you change it and you have forgotten your unlock code, you'll just have to reformat it
key combination which is used to hard reset the phone (similar to #*7370). It is useful in some cases, for example when the phone cannot reboot.
The trick is
Hold down the following three buttons: Green (call answer) button, * button, and ‘3′ button
When the message ‘Formatting’ appears on the screen, release all of the buttons...
reformatting your phone will delete all your data and also will restore all the defaults of your phone, and any corrupted application will be reinstalled, but if the formating doesn't work, you'll just have to re flash it, the safe way is to go to a near repair shop of your phone and have then to re flash your phone,
Aug 28, 2008 | Nokia 7610
SOS PLEASE
maybe u have a virus on your phone,, try this, but it will reformat ur phone and all the data on your phone will be gone!\,
key combination which is used to hard reset the phone (similar to #*7370). It is useful in some cases, for example when the phone cannot reboot. The trick is by switching off the phone then press and hold Call key (Green key) + * key + 3 key + power button for a couple of seconds
but all your data will be lost
Aug 23, 2008 | Nokia 6600
Nokia 3650 Logo
78 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
