Question about O2 Xda Atom Exec Smartphone
WIFI Problem i can't enable my Wifi, pls. help me about this or just need to know how to restore the factory setting
  • 2 more comments
  • raghuprasads Aug 23, 2008
    cant enable wifi on o2 xda atom exec. when clicked on the wifi option in the wireless manager nothing happens
  • ongrg Nov 16, 2008
    i having the same problem too...
  • Anonymous Jan 07, 2009
    I Have THe SAme Problem
  • frixine Apr 29, 2009
    i cant enable my wifi problem
    i just restore factory setting
Me to i cant
Posted on Mar 01, 2008
Forgot the password of my pocket wifi how to recover it
The Pocket WiFi has a reset button making it easy to restore it to factory settings. With factory settings restored, you can connect devices to your Pocket WiFi using the original Wi-Fi password it came with.
Jun 30, 2016 | Computers & Internet
Have irulu tablet with android tablet and I can't get it to connect to Internet. I turn it on on but it will not highlight or work at all
When you go to settings -> Network settings -> do any WiFi networks appear? Are you able to hard wire your tablet with a Ethernet cable? You may need to factory restore if your WiFi drive has been corrupted. Are you able to physically remove the battery? If yes then remove the battery and hold the power and volume buttons at the same time for 45 seconds and then re-insert the batter and power the device on, make sure you WiFi is Enabled/turned on, and attempt to connect to a known working WiFi source if you cannot hard wire the tablet. It is very possible your network card had died and you may need a replacement tablet as its very expensive to replace a NIC (network Interface Card) on a tablet as they are proprietary.
Please let me know if you require further assistance,
Hhank you
Hunter Quinn
IBM Helpesk Supervisor
Feb 15, 2016 | Tablets & eReaders
My samsung galaxywant give alerts or ring
Setting/sound/volume/ 4 sliders, set these to max.
Ensure your Sim card is inserted correctly and you have network coverage.
Enable WiFi. Enable mobile data(network charges will apply).
Download Samsung push service from the app store ...should already be installed.
If all fails. Backup your phone on a computer or cloud service and restore factory settings (last resort) ensure all your contacts are saved to your Sim card.
Contacts/settings/import/export to Sim/all.
Settings/backup / Restore factory settings.
May 30, 2014 | Cell Phones
My asus transformer pad will not connect to wifi. I have done the factory reset and it will not even list a wifi list to connect to.
Obviously your WiFi is not enable. Check your settings and make sure your enable your WiFi. Then you will be able to see all computers (WiFi) around you.
Nov 02, 2013 | ASUS Transformers Pad Infinity TF700T
How do I get my net book to use wifi? I usually connect to broadband and want to use wifi in my hotel? It does not show any available networks. Do I have my security settings too high, or do I just need to...
First of all you may want to decide to check out if the wifi connection is disabled or enabled.
If you go to system settings, in the network area you should be able to see if the wifi card is enabled. If is not enabled you may want to right click on the wifi icon connection and click on enable.
If this was the issue you know should be able to see and display all available networks in your area
Aug 03, 2011 | Acer Aspire One Netbook
Dear sir i bout netger g router but wirless not working pls help me
make sure your wifi driver is updated, router firmware updated, router/wifi settings properly configured including WAP/WEP or security key. You may also want to make sure wireless zero config on WIndows is enabled and set to manage the wifi connection.
Aug 31, 2010 | Nokia Computers & Internet
Same problem
Reset your router to factory default settings for that press RESET button for 10 seconds it is in back side of router then all settings defaults.Then configure your router with below method then all messup will be fixed. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on WAn settings and set wan settings as internet service provider settings. Then click on wireless settings then enable wifi also enter SSID name and enable broad cast turn on wifi . If you want to secure wifi then enable WEP in wireless security .Enter code it is your password to connect wifi. Let me know if you need further assistance. Thanks for using FixYa.
Aug 03, 2010 | Computers & Internet
Internet access with wireless
Assuming that your laptop has a built-in WiFi Networking card (or even a USB or PCMCIA WiFi adapter), normally its a matter of setting your Network configuration to "Auto obtain IP address automatically". This could be done in your Control Panel/Networking Connections, right click on your wireless Networking, click on Properties, highlight Internet protocol (TCP/IP), click on the Properties button and tick "Obtain...".
In some instances you might need to key in the WEP or WPA security key if it has been enabled and set in your WiFi router, though it has been known to slow down connections. If on the otherhand the router has its MAC filter enabled, then you would need to add your laptop's WiFi MAC numbers to the list that the router would allow access to.
Should the above be not corrective of your concern, pls post back with the make & model of your router, laptop, and the WiFi adapter if external/add-on. Knowing your Operating System would also help.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 09, 2008 | Computers & Internet
O2 Xda Atom Exec Smartphone Logo
223 people viewed this question
Top O2 Computers & Internet Experts
zurysk8
Level 1 Expert
xxxxxx xxx
Jax Planet
Jax Planet
Are you an O2 Computer and Internet Expert? Answer questions, earn points and help others
