Question about Cell Phones
I can not find the place to put the sim card and the battery. Nobody show me how to put it together. Everybody was so busy there they gave me the box with everything in and I don't know how to transer the sim card or put the battery.
U should see manual which is there in the box provided by them when u purchased the cell.... if u cant fix such poor problem u better dont use cell phones!!! ;-)
Posted on Feb 28, 2008
How do I activate my new phone?
It's the same throughout all brands.... Remove battery cover or any cover holding sim card and/or SD card.
Locate the position the sim card is placed and insert it correctly. Do the same with the SD card if you have one. Put the device back together then switch on. The phone will check your sim card and connect to your network provider (if phone is unlocked to all networks) you will find out quick enough if the phone is locked to another provider, it won't work !
Assuming it pairs with your network, the on-screen instructions will tell you how to proceed, like any email accounts etc that you want synchronised with your device. It should automatically load your previous contacts and will install some updates automatically too.
These are generic instructions for the average type phone, read any manual you have carefully. but this is the general way..... good luck.
One more thing....make sure the device is charged.
Jan 05, 2015 | Cell Phones
Sim card busy;
nokia asha 305 plzzzzz format code give me
Nov 01, 2013 | Nokia 101 Dual Sim Flashlight Music Mobile...
My cell phone screen flickers when in a call and wont let me do anything
take out battery and sim card ,put battery back in without sim card turn phone on leave 5mins then take out battery without turning phone off put it back together turn phone on "just needs updated"
Jun 27, 2013 | Cell Phones
Sim card in a panasonic cf-h2
To insert Sim Card in a Panasonic CF-H2, you need to open battery compartment 1 and remove battery, you will see where the Sim Card inserts, place the sim card gold side up in the depression. Slide sim card down the depression toward the sim slot, slide down till it clicks in place. Re-insert battery 1. Sim card inserted.
Mar 22, 2013 | Panasonic Toughbook CF-H2ASFAZ1M 10.1" LED...
I have an SciPhone i68 4G. It is a dual sim phone. I tried putting my T-Mobile sim card in with a Vectone sim card and I found that I was having trouble with the battery. It would turn off even when I was...
TO SEXYBABE008 -I HAD THE SAME PROBLEM YOU ARE HAVING. THERE ARE TWO SLOTS FOR THE SIMS CARD- THEY ARE ON TOP OF EACH OTHER- IF YOU ARE ONLY USING ONE SIMS CARD- PUT IT ON THE TOP SPOT WHEN INSERTING IT- THIS WORKED FOR ME- THE BATTERY HAD NIOTHING TO DO WITH.
Mar 01, 2011 | Cell Phones
How to remove the sim card?
Quick start guide
Your Nokia E75 is a business device that adapts to your
free time, as well.
Read these first pages to get started, then use the rest
of the guide to explore what new features Nokia E75
brings to you.
SIM card, battery,
charging, memory
card
Put the pieces together, and get started with your
Nokia E75.
Insert the SIM card and
battery
1. To open the back cover of the device, with the back
facing you, unlock the back cover release button,
and lift the back cover.
2. If the battery is inserted, lift the battery in the
direction of the arrow to remove it.
3. Insert the SIM card. Ensure the contact area on the
card is facing the connectors on the device and that
the bevelled corner is facing the top of the device.
4. Align the contacts of the battery with the
corresponding connectors on the battery
compartment, and insert the battery in the
direction of the arrow.
Jan 22, 2011 | Nokia E75 Cell Phone
WHY DOES MY PHONE SAYS INSERT SIM
try taking SIM and battery out placing it back in an powering on.
If you try this and it still does not work you may need a new SIM card. Take it to a local dealer they should have a new SIM they will put your number on it and you will be back in business.
If the new SIM doesn't not work you will now know it is your Phone, which means time for a new one.
good luck
Mar 27, 2010 | LG CF360 Cell Phone
My LG VU is not reading my sim card but when i put Sim card in another phone is works
The sim card goes in the other way. The cut should be on the bottom left facing up. Try it and see if it works.
Jan 24, 2009 | LG Vu CU920 Cellular Phone
How do i insert the simm card?
most sim cards are located under the battery. remove the back of the phone, then remove battery, you should see a place for the sim card, just slide it in but make sure you put it face down and the right way round, theres usually a little diagram showing the correct way
Sep 06, 2008 | Cell Phones
Help!!!
Hi I got the same phone today.
I assume you are trying to install the SIM card as you stated and not the memory SD card as some are talking about.
My manual just shows a picture!
Take out the battery hold the phone with the bottom toward you look at the hole where the battery was.
On the bottom of the square there is a slot in the middle that the SIM card slides into.
THE NOTCH ON THE SIM IS TO THE BOTTOM LEFT CORNER.
Place the SIM card flat against the bottom of the hole where the battery was with the notch as stated and slide it down towards you into place. The SIM just about disappears into the bottom edge of the battery hole. Thats what my manual showed about inserting theSIM card.
Haven't inserted a SD card yet.Hope this helps.
Aug 05, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Cell Phones Logo
47 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
