Printer Problem I have a Kyocera FS1010. Unfortunately, yesterday a member of my staff just turned the printer OFF in the middle of a print. It obviously jammed. The paper was removed. But the printer is still saying jammed. I have completely removed all cables, checked all areas, cancelled all documents but the light is still flashing a jam. What do i do this has been going on now for 2 days. I am desperate to print off all my orders? HELP
    Master:
  • 377 Answers
Be sure that there no more piece of paper still inside, and be sure that there no part of the printer is obstructing the other part to move.
Posted on Feb 28, 2008
  • 28 Answers
Hi there... our copier in the office is also kyocera... and i also encountered that same problem before.... try to check all areas of your machine especially those that passes the paper... maybe it's still has a piece of paper stuck in it thats' why... that's always the problem of kyocera machine... it is so sensitive...
Why does our Kyocera Taskalfa 181 keep displaying a "Print mode error" message?
It is usually because you have the machine set up as A4 and the your documents or printer driver set to 81/2 X11(American letter size) size paper ,to override this ,got to the menu system button in the top left of the operation panel ,scroll down to printer setting in one of those menues you'll find A4/letter override turn it on and you'll get rid of the problem .
Apr 21, 2015 | Kyocera Office Equipment & Supplies
Hi, am having problems configuring my Kyocera fs1010 to us usb port. How do I go about it??
please try with LPT cable and check ... please explain about your clearly what error you getting or how you configuring printer ....please post your comment ....
Dec 16, 2009 | Kyocera Mita FS 1010 Laser Printer
Kyocera Mita FS1010 fault
check your user guide... it will explain this error... or contact kyocera customer support...
Jun 25, 2009 | Kyocera Mita FS 1010 Laser Printer
I have Kyocera FS1010 printer and previosly it was configured with one IP, so I accessed with that through IE and resetted all to change IP add. Now it is showing that 0.0.0.0 only and I am unable...
you can configure it but its too confused the way to do it, you u have to play with the arrows to configure the ip address. let me know where you located or if u have any email address so i can walk you through.
Best Regards
Mar 19, 2009 | Kyocera Mita FS 1010 Laser Printer
Connect Kyocera Mita FS-1010 to Macbook (OS X 10.5)
in FS1010 printer usb port avilable u can connect the printer through usb port .
please delet ur printer driver and reconfigure it . use a usb cable to connect the printer it will work.one more u can put ur printer in network
Dec 23, 2008 | Kyocera Mita FS 1010 Laser Printer
Fs1010 printer driver
Here is the updated driver page for your printer:
Just pick your operating system.
http://www.kyocerasupport.co.uk/index/download_center.false.driver.FS1010._.EN.html
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 03, 2008 | Office Equipment & Supplies
Kyocera FS1010 first page only half printed
I found this solution. Worked a treat. I took the printer apart and applied felts to the solenoids (the felt normally used for the bottom of cup coasters).
See the Success post in this thread...
http://www.copytechnet.com/forums/kyocera/15980-kyocera-fs1010-delayed-printing-1st-page-2.html#post55451
This manual helped too...
http://www.freeprintermanuals.com/PM/Kyocera%20FS-1010%20Parts%20Manual.pdf
This is the post...
Success
A solution has been found. Thank you to Steveauh (Townsville)
Kyocera in their wisdom have used a foam insulator on the 3 solenoids that disintegrates over time regardless of use.
  1. Open the right side of the printer
  2. Disconnect all connections to engine board
  3. Remove engine board
  4. Remove plastic guard (white)
  5. remove all 3 solenoids
  6. Replace all pads on the solenoids that come up against stops
    Registration Solenoid has 2 pads (1 against the solenoid frame and the other on a stop arm, the others just the frame pad)
  7. Keep thickness to around .4 - .5mm Too thick on register arm will cause early printing.
  8. Reassemble
And that is it. The arms were being magnetically delayed due the metallic contact. It seems to be a regular problem in this chassis FS1000 to FS1030.
Jun 23, 2008 | Kyocera Mita FS 1010 Laser Printer
Mac iBook G4 to print on my Kyocera FS1010
well...you need to get drivers from either apple.com or kyocera.com
Mar 23, 2008 | Office Equipment & Supplies
Kyocera Prescribe programming
hi, I think that You must set parameters for line space,or character space.Also set parameters for margines,L1L2,etc...
have You prescribe manuals? if not, You can download it from Kyocera web site,section downloads.
Nov 27, 2007 | Kyocera Mita FS-1030D Laser Printer
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
