Question about EliteGroup PT800CE-A Motherboard
Not run 1.1
When i turn on my pc it never turn on but the red light is there like it was loading and no beep then my monitor was blank...but sometimes it run and has a beep but sometimes it restart when you use it what could be the main problem of my pc?pls help me tnx!!!but the fan still running
  • enigma pulp Feb 28, 2008
    hope somebody could help me with this thing i need an specific answer to my problem
  • 32 Answers
There are a lot of things it could be. Is this a new build or some thing that you have been using that started acting up?. Start be removing all the cards in it that you don't need. Then remove all the cables from the drives. See if it will boot. If it does start adding the cards and drives one by one until you find the one that is causing the trouble. If it still don't boot then check out your cpu or power supply.
Posted on Feb 28, 2008
My 1 year old computer has a black screen but u can hear the computer running help....
Are you getting any beeps while your computer starts up or when it has already started? If yes, then refer to the following HP Support page to get details about different types of beeps and the respective issue they indicate:
http://h10010.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&dlc=en&docname=c02222922#N315
If you are not getting any beeps, you can start troubleshooting the issue by first checking the connectivity and performance of your monitor. To do this, refer to the steps below:
1)Make sure that your monitor has power and the power light on it turns On when power is supplied to the monitor. If the light stays Off, turn Off the power supply- unplug and plug the power cord- reseat the power adaptor connection on your monitor's end- turn On the power supply. If the monitor's light glows, see if the computer still shows the blank screen. If yes, follow the steps ahead.
2)If your monitor is of flat panel LCD type, unplug its power cord and wait for around 30 seconds so that the electronics in your monitor are reset. Now reconnect the cord and turn On the monitor.
3)If you are still facing the blank screen issue, disconnect all the connected devices to your computer except mouse, keyboard, and monitor. Also remove memory cards from card reader slots (if any) and thumb drives connected to your computer (if any).
4)If the above steps do not resolve your issue, you can try (if possible) to connect your monitor to another video cable (if it is detachable) for testing purpose.
If the issue still persists, you can refer to the HP Support links below to troubleshoot your issue:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02217843&tmp_task=solveCategory&cc=us&dlc=en&lang=en&lc=en&product=5296671#N69
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c03561545&tmp_task=solveCategory&cc=us&dlc=en&lang=en&lc=en&product=5296671
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c03518095&tmp_task=solveCategory&cc=us&dlc=en&lang=en&lc=en&product=5296671
GuruAid.com
Jul 07, 2014 | HP Black Envy TouchSmart 20-d13w...
When i turn on the computer the LCD show a green light and suddenly they turend in red light and then blank screen showen...what the saolution?
Your PC have display driver problem i am suggest you to run your PC without graphics card if you are you using graphics card.
if not then run your PC in network prompt mode and Re installed graphicsdriver.
Jan 25, 2013 | AOC 19LVWK LCD Monitor
I turn on the ps3 and it attempts to load it comes
Try a video reset. Make sure you have your video cables plugged in.
1: Turn the system to standby/off (where only the red power light is on).
2: Hold the front power button till it turns on beeps twice and shots back off, release button.
3: Turn system back on normally.
Dec 21, 2009 | Sony Playstation 3 (PS3) Console
BLANK SCREEN-ACER ASPIRE 3661
You can check the little indicator light on the notebook.
If the hard drive was dead, that wouldn't cause the display to go blank.
If your problem was with your hard drive, you would still get the BIOS screen and then a message about being unable to load an operating system. So, I doubt if that is the problem.
My guess is that you have a relatively serious motherboard, video card, memory, or CPU problem.
When you turn it on, does it beep ? If so, how many times ? You can translate these beep codes at: http://networking.ringofsaturn.com/PC/beep.php __________________
Oct 22, 2008 | Acer Aspire 5610-4648 Notebook
Computer will not load anything
Turning you rmonitor on then your comp my monitor has a delay and if i dont turn it on before i turn my comp on or before i here the little beep noise my comp makes the monitor wont display anything.
Jul 14, 2008 | Systemax AOL Optimized PC (100607) PC...
Not run
memory module need for clean
clean with student erasor
check your smps {psu}
Feb 28, 2008 | EliteGroup PT800CE-A Motherboard
Pc problem 2 with beep when it run
Hello Jake Ponce,
You could power your machine down, and open the case. Then making sure you are grounded to the case (to prevent ESD damage), I would reseat all socketed hardware and plugs, such as Memory and graphics cards, PCI slot devices, etc... Unplug and re seat everything (especially anything that has been manipulated recently), then close the case and power it back up. It's worth a try and could very well solve your issue.
Good Luck.
Problem
there are many things that can cause this, first obvious causes would be bad ram, dead mainboard or hard drive.. i say dead motherboard due to the fact you say there is no post beep on startup, easy way to tell, remove all the ram, and turn it on, if it squeels at you, you know the motherboard still at least is somewhat operational, next thing try replacing the ram.
Pc problem
Sounds like the power supply may need to be replaced.
Black screen
The beeps are probably BIOS beep error codes. Through a series of long and short beeps the computer communicates computer problems that occur early in the startup processes. It's likely the problem isn't your monitor but something in your computer box itself. If you can tell us what the pattern is we can start diagnosing your problem. We'll also need to know the manufacturers name, the specific model computer you have and what operating system you are running.
Feb 04, 2007 | Microsoft Realsync DS771 17 Black LCD 8ms...
EliteGroup PT800CE-A Motherboard Logo
29 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
