Bad sectors in hard disk
How can i repair bad sectors in harddisk of linux
  • awaisf Mar 13, 2008
    My 80 GB disk does not show any problems/bad sectors after Fdisk and partitioning but when data is placed in partitions it start to corrupt and show few bad sectors. please help me in regaining my HDD. Thanks
  • Anonymous Apr 19, 2009
    how repair bad sector
  • 1,006 Answers
Search in google.com for program BAD SECTOR REPAIR
Posted on Feb 28, 2008
D620 machine so slow i think its going to crash
if your machine responding very slow possibility in your harddisk repair of hard disk for bad sector (bad sector causing your speed problem and hanging of pc)
repairing of hard disk many tools available on internet you go any one of them
May 19, 2012 | E-Machines eMachines Desktop PC
Tip
I have tested several programs, but the program below, just really worked for...
Let's try to explain the question that grinds us all when in cams about the hard disk. Can we actually repair a bad block? Before of the answer you must find some information about what is a hard disk, how does it work, what are bad blocks. After that you must identify them because you will need the exact location of the affected sectors. After you have done that you must run a few steps:
- before you try to resolve the problem with the bad sector you must extract the data that was written to that block. To do this you must run a Recovery program that you can find freeware on the net.
- bad sectors are unreadable parts on your hard disk but the nature of them must not be always physically and that part of the platens to be destroyed. The bad sectors can be simulated by some programs. This means that some programs installed on your computer can interrupt the reading process on to another segment of the platens. That is in the most happier cases but the chances that the bad sectors are cause by this is less then 10 percent. In this case is difficult to resolve the problem because even the Scandisk or other identification programs used to discover bad blocks will give a rapport that nothing is wrong with your hard disk. The best way is to uninstall the latest programs applied to the computer.
- lets supposed that you have a 20 gigabits partition on your hard disk that has bad blocks. After the identification program it will indicate you where are the blocks situated on the partition. So this way you can isolate them in to another partition that you must never use again. Another scenario can be created and the bad sectors can be at the beginning of the partition in the middle of it and at the end of the partition. Know it's a little bit tricky because you can't just go on and create three new partitions to eliminate the bad sectors from use. In this case most of the new hard disk has a spare space available just for this type of scenarios. You must access the CASH memory of the hard disk and indicates to the hard disk that instead of writing down on the effected blocks it must write to the spare blocks.
- another to restore the hard disk is to use the low level format option. Many of you think that low level format is a program. Wrong, the low level format option is set for any BIOS and can be easily use if you know some command line programming. The low level format can take to be complete a very long period of time but in the most cases we can obtain marvelous results. Actually the low level option takes every cluster of the hard disk and identifies them again (throw a thermal process) and writes down on the memory of the hard disk what sectors can be written and witch blocks are un-writable. This procedure is the best that can be because it will need no effort from your side to try and avoid the bad blocks that already exists and the hard disk itself know where the bad blocks are.
In conclusion the bad blocks can't be fixed. The problem is a permanent one and we can only try to use the hard disk until it is broken down for good. But if you are having financial problem this is a best way to keep going with your old hard disk.
on Mar 12, 2011 | Computers & Internet
I got a maxtor ide harddisk which was already partitioned, i tried to format one partition for installing windows, but seems thare were bad sectors i tried to format all but it was not possible. Now the...
When a hard disk has bad sectors, the magnetic layer is worn out and the number of bad sectors will increase. If you keep using this hard disk you risk losing your data. This hard drive cannot be repaired, throw it away and get a new one.
Jun 25, 2011 | Computers & Internet
Compaq Desktop won't boot up.
Do you have your Vista installation disc? If so, you can boot from that and then run the Windows RE troubleshooter, which should be able to test your hard drive and maybe even try to repair it.
May 27, 2010 | HP Compaq Presario SR2010NX PC Desktop
Hard disk no open
Hello, may b your other harddisk mite hav sum errors in it. Hope its detected in windows, bt not accesable.
Try booting with any linux live CD (google "puppy linux", its just 90MB approx) and connect the harddisk. Now access ur harddisk from linux. If u still cant access it, then u should format it.
if it works in linux, then backup all ur improtant data and format it wit NTFS. Ur prob shud b solved!!
Jun 22, 2009 | Video Game Consoles & Games
Solve Bad sectors Problem?..????
irst connect your drive to computer then check its drive letter meand c: or d: or e:
then go to start > run> then type "cmd" then go to drive letter then type "chkdsk /r"
then it cheks your harddisk for eror.
Jun 09, 2009 | Western Digital Caviar SE WD1600AAJS 160...
Bad sectors of my hard drive
There's no concrete way, you can try these software:
May 27, 2009 | Western Digital WD Passport 250GB Portable...
Bad sectors
Use the following link to download the software, which helps u to detect as well as completly remove badsectors, but before u do tat, here is the answer for wat is bad sectors..
Hard disk drive is an integral part of every computer. It stores all your information. One of the most prevalent defects of hard drives is bad sectors on the disk surface. Bad sectors are a part of the disk surface which contains not readable, but frequently necessary information. As a result of bad sectors you may have difficulties to read and copy data from your disk, your operating system becomes unstable and finally your computer may unable to boot altogether.
When a hard drive is damaged with bad sectors, the disk not only becomes unfit for use, but also you risk losing information stored on it. The HDD Regenerator can repair damaged hard disks without affecting or changing existing data. As a result, previously unreadable and inaccessible information is restored.
ths is the software
A powerful hard disk tool that can detect and repair physical bad sectors on a hard disk drive surface and regenerate hard disk.
http://www.4shared.com/file/49739096/5f24d2c2/HDD_Regenerator_151_Full.html?s=1
Jul 17, 2008 | Microsoft Windows Server Standard 2003 for...
Bad Sector on Harddisk
Set defrag to run at boot up and it will resolve any bad sectors you have, and will write a new boot registry for you.
Jul 17, 2008 | Hitachi Deskstar 7K80 Hard Disk 80GB,...
Harddisk fault
Hello!
Just try scandisk, Right click your c: and then properties, in tools menu, click check disk or scandisk.
may this help.
melnavz
Mar 03, 2008 | Compaq Presario 5000 PC Desktop
Computers & Internet Logo
942 people viewed this question
David Payne
David Payne
