Question about EliteGroup PT800CE-A Motherboard
Not run when i turn on my pc it never turn on but the red light is there like it was loading and no beep then my monitor was blank...but sometimes it run and has a beep what could be the main problem of my pc?pls help me tnx!!!but the fan still running and restarting when you use it
  • 152 Answers
Memory module need for clean
clean with student erasor
check your smps {psu}
Posted on Feb 28, 2008
Blank screen, no signal to monitor, no HD light, no mouse light, no keyboard lights, no beep.
maybe it could be a frayed/broken wire leading to the visual/sound parts. if not then bring it to tech support and have them look at it
Dec 20, 2013 | Computers & Internet
When i turn on the computer the LCD show a green light and suddenly they turend in red light and then blank screen showen...what the saolution?
Your PC have display driver problem i am suggest you to run your PC without graphics card if you are you using graphics card.
if not then run your PC in network prompt mode and Re installed graphicsdriver.
Jan 25, 2013 | AOC 19LVWK LCD Monitor
Beeps half-dozen times then shuts down.
try ur windows disk,,put it in and go from there,,reformat if u have to,,or try sytem restore,,
May 17, 2009 | Dell Dimension 3100 PC Desktop
Lights 3 &4 stay on.
Computer beeping at you is usually a problem with the video card or memory. Try re-seating both and see if you still have the same problem. If you do, individually remove each component and power on to test if the beeps persist.
Jan 06, 2009 | Dell Dimension 9150 (DIM915MIN) PC Desktop
BLANK SCREEN-ACER ASPIRE 3661
You can check the little indicator light on the notebook.
If the hard drive was dead, that wouldn't cause the display to go blank.
If your problem was with your hard drive, you would still get the BIOS screen and then a message about being unable to load an operating system. So, I doubt if that is the problem.
My guess is that you have a relatively serious motherboard, video card, memory, or CPU problem.
When you turn it on, does it beep ? If so, how many times ? You can translate these beep codes at: http://networking.ringofsaturn.com/PC/beep.php __________________
Oct 22, 2008 | Acer Aspire 5610-4648 Notebook
Computer will not load anything
Turning you rmonitor on then your comp my monitor has a delay and if i dont turn it on before i turn my comp on or before i here the little beep noise my comp makes the monitor wont display anything.
Jul 14, 2008 | Systemax AOL Optimized PC (100607) PC...
Not run 1.1
There are a lot of things it could be. Is this a new build or some thing that you have been using that started acting up?. Start be removing all the cards in it that you don't need. Then remove all the cables from the drives. See if it will boot. If it does start adding the cards and drives one by one until you find the one that is causing the trouble. If it still don't boot then check out your cpu or power supply.
Feb 28, 2008 | EliteGroup PT800CE-A Motherboard
Pc problem 2 with beep when it run
Hello Jake Ponce,
You could power your machine down, and open the case. Then making sure you are grounded to the case (to prevent ESD damage), I would reseat all socketed hardware and plugs, such as Memory and graphics cards, PCI slot devices, etc... Unplug and re seat everything (especially anything that has been manipulated recently), then close the case and power it back up. It's worth a try and could very well solve your issue.
Good Luck.
Problem
there are many things that can cause this, first obvious causes would be bad ram, dead mainboard or hard drive.. i say dead motherboard due to the fact you say there is no post beep on startup, easy way to tell, remove all the ram, and turn it on, if it squeels at you, you know the motherboard still at least is somewhat operational, next thing try replacing the ram.
Pc problem
Sounds like the power supply may need to be replaced.
EliteGroup PT800CE-A Motherboard Logo
47 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
