.When selecting a wash cycle, nothing happens.Machine doesnt fill with water and makes no noise.After several minutes the prewash and wash lights flash.I have checked the manual and it instructs to call the engineer.Any suggestions as the call out and repair charge would almost buy a new machine?
Comments:
Feb 28, 2008
- Update.Cleaned filters and emptied water from machine.Drains clear and machine started the cycle.It now stops and both lights flash again.When opening the machine is filled with water.Heater is working.It appears to not be draining.Is there such a thing as a drain valve or something I have overlooked.
Mar 10, 2008
- Thanks for all the help but no success.Tried everything suggested but no joy.Many thanks anyway
I,d suggest Paying The $19.99 fee, on this site to get premium assistance. You,ll have technicians queuing up to solve your problem. And You,ll Have Solutions Within An Hour.
****** Please Do Not Rate This******
This Suggestion Is Information Only.
Good-Luck Mike @ Compurepair.
Comments:
Feb 28, 2008
- Hi,
Your actual drain valve is the pump.
Located on the underside of the Machine.
this is usually connected to The drum via 1 Rubber Hose.
To the pump, then another Rubber hose to the outlet water/waste pipe.
If the pump has any debris/badge/coins/hairgrips Or bobby Pins et,c it will not Spin and empty the water. this is all relevant, to the machines Cycle of events.
Mike @ Compurepair.
Was this helpful?
Yes
No
Solution #2
posted on Mar 16, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Same fault as above, followed your guidelines, leaned and shook machine forward and backward, seems to work a treat.
on any cycle dishwasher drains, then fills but does not wash - is it the main motor or could it be...
(More)
on any cycle dishwasher drains, then fills but does not wash - is it the main motor or could it be the motor start cpacitor?
When I turn the d/washer on the main switch, The pump starts trying to pump and the first cycle...
(More)
When I turn the d/washer on the main switch, The pump starts trying to pump and the first cycle light starts to flash. That is as far as it will go through cleaning cycle! I've unplugged and tried to reset but always the same problem? Thanks
My dishwasher is approx 10 yrs old works fine but does not clean - the filters are cleaned out and i...
(More)
My dishwasher is approx 10 yrs old works fine but does not clean - the filters are cleaned out and i have put a dishwasher cleaner through it
The light that indicates the salt is always on, despite that i done it twice. Plus the dishes dont...
(More)
The light that indicates the salt is always on, despite that i done it twice. Plus the dishes dont come out clean and often covered in a white powdery substance. Any ideas. I havent use it much because of it. it is such a waste of money. Thank you
