Printer no black
Brother MFC 210C not printing black. Have reseated cartridge, replaced cartridge, cleaned 10 times. Colours fine, black blank.
    Scholar:
  • 45 Answers
Hi hedleygb,
I recommend that you make absolutely sure that you are following the correct procedure when you are installing the print cartridge. For this I need you to follow the instructions at
http://solutions.brother.com/mfc210c_all/en_us/options/us/
(click on the View PDF File link, especially the part about removing the new print cartridge's Cartridge Cover before installing it in your printer)
If you've made sure that you're following the correct procedure during the installation of the cartridge and the printer still won't print black, I recommend reinstalling the printer on your PC with the latest drivers. To do this you can follow the following steps;
(if these steps aren't sufficient for you to do the reinstallation, feel free to give me more info about the operating system you are running on your PC in the comments of this problem, so that I can give you more detailed steps on how to perform the reinstallation).
  1. Uninstall your printer's driver from your PC's operating system (e.g. Windows)
  2. Download the latest drivers for the MFC 210C at
    http://welcome.solutions.brother.com/BSC/Public/Templates/DownloadTop.aspx?NRMODE=Published&NRNODEGUID=%7b66D791E0-6EB2-410E-9602-7BFFA80A61D3%7d&NRORIGINALURL=%2fbsc%2fpublic%2feu%2feu_ot%2fen%2fdlf%2fdownload_top%2ehtml%3freg%3deu%26c%3deu_ot%26lang%3den%26prod%3dmfc210c_all&NRCACHEHINT=NoModifyGuest&prod=mfc210c_all&reg=eu&c=eu_ot&lang=en
    At Step1: Select Type select Driver
    At Step2: Select OS select the operating system you run on your PC (e.g. Windows XP or Windows Vista)
    At Step3: Select Language select your preferred language
  3. Reinstall the printer using the guidelines as documented in the printer's manual, which can be downloaded at
    http://welcome.solutions.brother.com/bsc/public/eu/eu_ot/en/doc/manual_index.html?reg=eu&c=eu_ot&lang=en&prod=mfc210c_all&type2=5&flang=English&dlid=
Feel free to contact me again via the comments of this problem if you need more information.
If you have completed the above mentioned troubleshooting processes and the printer's problem hasn't been solved this could indicate a hardware malfunction of one of the printer's components. In which case the printer should be serviced by a IT technician at a PC repair workshop.
I hope you find this info helpful in solving the problem with your printer and thanks for using the FixYa service
Kind regard
Posted on Mar 01, 2008
BROTHER MFC-210 PRINTING IN BLACK INK POOR QUALITY BUT COLOURED INK FINE. USING INK MANAGEMENT TO CLEAN PRINTER NOT HELPING. HAVE TAKEN OUT AND REINSTALLED BLACK CARTRIDGE WITHOUT IMPROVEMENT. WHEN...
Try cleaning the black printer heads several times in a row, at least 5 times then print a black document with best quality setting.
Press the ink button, then down to select select cleaning and then press menu/set and menu/set again to select black.
Dec 19, 2009 | Brother MFC 210C All-In-One InkJet Printer
Blask not working. cleaned 10 times and also changed cartridge.
wash with water your printer head withen 4 hours then clean soft ware black cartridge print ok
Jul 29, 2009 | Brother MFC 210C All-In-One InkJet Printer
Cyan ink won't print on Brother MFC-665
talked to Brother, cost to much to fix, replaced the printer.
Dec 24, 2008 | Brother MFC 210C All-In-One InkJet Printer
Borther mfc210c black ink not printing even after cleaning
if your brother machine is within warranty, give the tech support a call. if not,replace the black cartridge with a new one. it may be a defective cartridge that you have or if you are using refilled cartridges, it will also give the same problem
Nov 18, 2008 | Brother MFC 210C All-In-One InkJet Printer
Black doesn't print
I have same problem. Found if I remove and replace the black cartridge before I send a print job it will work. Be interested to know if that works for anyone else.
Oct 17, 2008 | Brother MFC 210C All-In-One InkJet Printer
MFC 215 BROTHER MULTIFUNCTION PRINTER
reseat / reclamp cartidges then perform printhead cleaning
Sep 07, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-210C won't print
I have cleaned, retested and new ink and it still will not print Black
Jul 11, 2008 | Brother Multi-Function Center MFC-240C...
Brother mfc 210c printer
Check ink cart if it is well placed into the ink cart assy. Do the cleaning procedure by pressing INK skip the arrow-button down until CLEANING is displayed. Press start mono (blue button). After cleaning cycle you are asked by machine to print a quality test sheet. Do so and follow display instructions. Do the cleaning procedure a max of three times! When there still is no BK the printhead either is clogged or dryed out. Sorry, this cant be fixed anymore.
Oct 09, 2007 | Brother MFC 210C All-In-One InkJet Printer
Printer not printing
Unfortunately, like most multi cartridge ink jet printers when one ink is empty the printer will cease printing regardless of whether you just want to print in black and white and you have plenty of black ink left. I have heard of people tricking the printer into believing the cartridge is full by placing coloured tape etc in front of the ink sensing device but I am not sure how the Brother senses the ink levels as i have some aftermarket ink cartridges for mine which seem to be completely non-opaque (unlike the originals). The need to have colour cartridges in even if you only ever print with black ink is good news for Brother as the MFC-210c uses a large amount of ink during it's routine cleaning cycles (that you cant stop) and will empty all 3 cartridges in under 6 months without ever printer a single drop of colour ink. Sorry about all the bad news, at least your not alone......
Dec 28, 2006 | Brother MFC 210C All-In-One InkJet Printer
Computers & Internet Logo
94 people viewed this question
David Payne
David Payne
