Humax F2-1002 digital box to receive free to air satellite tv. Back in February Optus B3 channel was superceded by D2 as providing our tv service. No change to position was required but new settings needed to be entered into the box. In order to scan in the new channels, the old channels needed to be deleted. The instructions said to go into Menu> then Edit Channels> Edit Channel Lists> then give password 0000> then select Group> select Optus B3 > then Select all. I get to the step of selecting the group but only 2 options are available at this point - TV or radio, not the Optus B3. Can you advise what I have done to muck this up so that it won't programme?
techman
  • 3130 Answers
SOURCE: Panasonic PT-47WXD63G
If you have a problem with the convergence, believe me, going into the service menu and trying to correct it will only give you large headaches, DO NOT USE THR SERVICE MENU UNLESS YOU ARE A TRAINED TECH!!!! Doing so can result in a complete and total failure of this TV set. I service menu is not for any major changes in any adjustment. It is not the cure all. If your convergence all of a suddenly shifted, it is not a service menu issue. Your problem is the convergence amp IC's. Good Luck
Posted on Aug 12, 2007
SOURCE: Re-programming for Optus D2 satellite
what brand of set top box do you have?
Posted on Feb 05, 2008
SOURCE: Grundig colour tv lost digital channels
go to menu, digital setup, then auto tune all the channels again. it worked fine for me :D
Posted on Apr 04, 2008
Slinteriors
  • 8617 Answers
SOURCE: auto channel select not picking up all channels it should be.
You need the signal board. You can get one at the following link.
http://servicemanuals.vstore.ca/
Posted on Jun 01, 2009
stonephoenix
  • 563 Answers
SOURCE: When I try to set
It sounds like your TV is on a different input. If you watch your cable from an external cable box, and this box is plugged into your TV using wires that are yellow, red, and white, or red, blue, green, red and white, you're currently watching TV on a different input than the one used for the antenna. Channels in a TV are controlled by the tuner. The tuner is the silver, threaded, post on the back of a TV, DVR, converter box, or VCR, that you plug an antenna or cable wire to. The tuner contols channels while the other inputs on your TV carry a direct signal like a computer to a monitor. So when you use something other than coaxial cable to connect cable to your TV, you can't access the channel menu while on that input. To access that menu, change the TV's input or source to TV or stop when you see a channel number on the screen. You have to be on the TV or tuner input in order to access the channel menu. If you're on any other input such as, S-Video, AV1, AV2, component (Yp Br Cr), HDMI, etc. you will not be able to do a channel scan. You have to be on the right input or source.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Jul 27, 2009
How do i set up freeview on tv
How do set up TV with Freeview built in
Freeview is not a satellite provider. It is an off-the air provider, meaning you need to have an antenna to receive Freeview channels. Either you need a digital converter box or a TV with a build in converter.
About Us
Jun 09, 2014 | Televison & Video
I have upgraded to Windows 7 and also a new Gigabyte GA-H61M-D2-B3 Motherboard. 4GB DDR Ram I have plugged my Cambridge Soundworks SW320 in but I only get some sound, eg all music and back ground sound is...
Gigabyte GA-H61M-D2-B3 Motherboard supports 2/4/5.1/7.1-channel HD audio, whereas Cambridge Soundworks SW320 is 2.1 (only). Hence, the PC should be configured to provide 2.1 Channel output. The audio of your system may be configured to 2.1. So, please check the Realtec Audio sound manager/ configuration from the control panel or from tray (near clock) and set it to 2.1 (2 Channel Stereo Output).
Moreover, audio on your PC may be running on default HD Audio Drivers. So, you may also download/ install the latest drivers for Gigabyte GA-H61M-D2-B3 Motherboard.
(Refer to download section at the bottom of the page). After installing audio drivers, you would be able to configure the audio.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 13, 2011 | Creative Labs SoundWorks SW320 Computer...
Will i need a converter box for this tv?
If you want to receive off-the-air broadcasts (i.e., you have no cable satellite system), then yes, you'll need a digital tuning adapter. This set has only an analog tuner.
If you are on a cable system, you might not need a converter box, but it depends on your cable provider. Some systems still offer basic cable service without a box, and you can see what channels you'll pick up with the TV set for "cable" tuning. Other systems require a digital converter box or "digital transport adapter" for any reception. You'll need to check with your cable provider to find out.
Feb 27, 2011 | RCA F36648 36" TV
I have Humax IR-ACE II It hangs when I reset
E-66 FTA services are blocked Your subscription has expired and your decoder has blocked all channels including free to air channels To renew your subscription call your dealer or customer service, see details on ART Info Channel
Mar 15, 2010 | Televison & Video
ACIDENTLY DELATED ALL CHANNEL FROM MY HUMAX, NOW I CAN NOT GET CHANNEL BACK I HAVE ENTERED CORRECT FRQ/SYMBL ETC DETAILS.
1 - The correct sequence for  all channel data input: a.satellite name; b.frequency; c.polarisation; d.data/symbol rate; e.fec. Did you respected that for every single one?
2 - If yes then is the signal strength for each frequency above 80% ?
3 - Did you scanned all satellites after you have loaded the data?
Oct 04, 2009 | Humax Televison & Video
I have a sony trinitron wega tv model number KV-32FS120 and I was wondering if it is digital ready or do I need to get a converter box
This television receiver has only an analog broadcast tuner and will require a converter box after February 17, 2009, to receive over-the-air broadcasts with an antenna because of the U.S.'s transition to digital broadcasting. Analog-only TVs should continue to work as before with cable and satellite TV services, gaming consoles, VCRs, DVD players, and similar products.
Jan 06, 2009 | Televison & Video
Digital reception
If you do not have cable/satellite ,Yes
Dec 11, 2008 | Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
Is My TV ATSC or NTSC?
Yes, you will need a converter box if you are currently getting TV off-the-air with a rooftop or indoor antenna. This TV does not have a digital tuner. You don't need a box if this set is being used on a cable or satellite system (unless your service provider tells you otherwise).
Dec 10, 2008 | Philips TV Tuner Video Capture PCI Card -...
Jan 24, 2008 | Coship CDVB2000E
Televison & Video Logo
118 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
