Question about Sony Cyber-shot DSC-W55 Digital Camera
Video mode problem
I don't know how to use the video mode and also to change the resolution.
  • 1 more comment
  • rossissy Mar 03, 2008
    the brand name is Nikon 8700.thank you for your answer.
    the brand name is nikon-8700.thank you for your answer.
  • aaron irving May 11, 2010
    I think we need at least a brand name, if not a model number. Most cameras have the "video" mode under the icon that looks like a film camera. Resolution settings are often on the screen display under menu - settings. A lot depends on the brand.
  • 68 Answers
You can find the user manual here - http://www.nikonusa.com/pdf/manuals/coolpix/CP8700_en.pdf
Resolution modes are found on page 32 (and instructions on the exact buttons to push).
Choosing video mode is found on page 51.
Posted on Mar 07, 2008
The brand name is Nikon 8700.thank you for your answer.
Posted on Mar 03, 2008
I cannot change my screen resolution
Boot up in safe mode and see if you can change the screen resolution. If not you are being limited by your graphics card (video card) and driver.
Turn off the computer, then hit the power button to turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Take the Safe Mode option and let it boot up. Safe Mode will look different to you, the screen will be darker and the icons bigger, this is normal. See if you can change the screen's resolution.
If you can't change the screen resolution, try downloading and reinstalling the video driver.
Get online and got to www.google.com In the google search box type: "Dell Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Download and install the Video drivers.
May 24, 2012 | Dell Computers & Internet
How do i fix if my computer scan is out of range
I am assuming you are talking about your monitor. What this message means is that your monitor can't handle the resolution your video card is set to. Re-start your computer and as soon as the first screen goes by (you know the one with all numbers and stuff) start hitting the F8 key. This will start the computer in safe mode which uses a very low resolution (usually 640 x 480). Once you see the display set the resolution to 800x600 which any display can handle. Re-boot and log in again and change the resolution to something higher. Test different settings. If you set one that is too high and you can't see the screen again don't touch anything as the screen will revert back to the previous setting if you do not confirm.
Hope this helps. If it does don't forget to give me a thumbs up.
Aug 29, 2011 | Dell P780 17" CRT Monitor
I want my monitor to work once again because it says cannot display video mode? i dont understand help me?
You didn't say which OS you're running. However, it looks like you need to restart your computer in safe mode. This URL explains how to get in safe mode. When the computer boots the video it will look a bit grainy and you won't be able to see the entire desktop without using the scroll bars.
Both XP and Vista don't allow you to perform such an operation through the regular procedure and, as a result, you will only be able to get a screen resolution of 800×600 with the consequence that some icons and programs won't be displayed correctly. This is because Safe Mode just loads only basic services and drivers which are strictly necessary for Windows to run.
Fortunately, by employing the following techniques, you can get around this restriction permitting you to get whatever screen resolution you want.
Windows XP:
  1. Right click on your desktop.
  2. Click Properties.
  3. Click the Settings tab.
  4. Under Screen Resolution, drag the pointer to the right (where higher resolutions are located).
  5. Click Advanced.
  6. On the new window click OK, without modifying anything.
  7. Done, you should have successfully changed the resolution settings.
Windows Vista:
  2. Click Personalize.
  3. Click Display Settings.
  4. Under Resolution, drag the pointer to the right (where higher resolutions are located).
  5. Click Advanced Settings.
  7. Done, you should have successfully change the resolution settings.
Aug 11, 2011 | Dell 1503FP 15" LCD Monitor
I have problem in my lg lcd monitor when start computer windows loading then il say out of range 53.5Hz/85Hz. i don't know how to solve that problem.
Sounds like the resolution is set to high which is why that message would come up. When you turn on your computer, keep pressing the F8 button. It will bring you to a menu. Choose "Safe Mode" and press enter. When you get into windows go into the display settings in the control panel. Then go ahead and set the resolution to 640X480. After you do that go ahead and restart the computer and let it boot up normally. That message should go away and once you get back into windows you'll have icons that look bigger then normal. At that point change the resolution to 800X600, if it takes that then try 1024X768 if you want to.
If after you are in safe mode and change the resolution and that error message comes up then you'll need to download the video drivers for your computer and reinstall them.
May 28, 2011 | Computers & Internet
Cannot Display This Video Mode!!!
Restart your computer Press F8 key it shows Startup option choose VGA mode and Select the resolution after getting your desktop
May 06, 2010 | Dell Inspiron 530 Desktop Computer
Like a lot of others. Black screen after 3 secs . Switch off, restart, a few secs off again any ideas ????
Your computer's video adapter may be asking for a resolution that is not supported by the monitor.
Start up in Safe Mode (Google it if you don't know what this is)
Change your display resolution to a low setting like 800x600.
Restart the computer and let it start up in Normal Mode.
The monitor should work now and you can change to a higher resolution so long as it is supported by the monitor.
Apr 17, 2010 | Computers & Internet
GX520 screen display message: cannot display this video mode
This means that the windows setting you have set can not display on your current monitor. There are two ways to fix this, one is to boot the computer in safe mode by pressing f8 after the POST screen and change the resolution and the other is to plug the computer into a different monitor to see if supports that resolution and then change the resolution in windows to a lower setting.
In case you don't know how to change the resolution in windows, follow below.
Right click on the desktop
Properties
Settings at the top
Move the slider to 1024x768
Click ok
Try rebooting. If that still doesn't work, try another resolution.
Oct 19, 2009 | Dell OptiPlex GX520 PC Desktop
My screen is showing message "Not optimum Mode, Recomended Mode : 1024 x 768 60Mhz. ?
you need to change your video adapter resolution to this one,if you can`t see nothing in normal moe login in safe mode(tap f8 on boot)and change resolution then restart
Jun 13, 2009 | Samsung SyncMaster 510N 15" LCD Monitor
Sony Cyber-shot  DSC-W55 Digital Camera Logo
48 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
