Question about Acer NSK8458AN Keyboard
Acer Key Board
How do i get the numbers lock key to come on a boot up
  • 640hawk Mar 05, 2008
    number lock will not unlock!
  • 20 Answers
You need to go into your bios - normally press DEL when you first power up.
This is related to your motherboard not your keyboard.
Might be worth identifying your motherboard and visiting the manufacturers web site. Or look in the manual if you have it
Posted on Feb 28, 2008
Unlock number lock
On a laptop, the "Num Lock" key has a function slightly different than the one it performs on full-d desktop keyboards. Activating "Num Lock" on a laptop usually transforms a set of central keys, including many letters, into number keys, allowing typists used to entering numbers on a keypad to type efficiently. While on desktop keyboards "Num Lock" usually has a dedicated key, on laptops it often shares a key with another function on MacBooks, for example, it shares the "F6" key and you must hold down the "Shift" or "Fn" key to activate it.
Look for the "Num Lock" key on your laptop's keyboard. This is usually near the top of the keyboard. If the key says nothing on it except "Num Lock" if that's the only function the key performs you can just press it to activate the lock; a light will probably go on somewhere to indicate that "Num Lock" is on. If the key has multiple functions, you'll have to hold down a different key while pressing it. Hold down "Shift" and press "Num Lock" if the writing saying "Num Lock" appears above some other writing on the key, the way various symbols appear above the numbers on the keyboard's number row. Hold down "Fn" and press "Num Lock" if the writing saying "Num Lock" appears in a different color often light blue that's shared by the "Fn" key.
Feb 28, 2013 | Acer Aspire Computers & Internet
Cant figure out what motherboard the ax1420 ur12p has?
easy boot up pc press pause key on key board and not the bios number that gets displayed on bootup. google search the bios number and it should tell you the type of motherboard you have.
You can press the key to go into the bios settings and note the bios number from the settings also.
Feb 01, 2013 | Acer America Acer AX1420-UR12P...
Touchpad not working acer aspire 5732Z
Just check for the key combination on your key board (ex. Fn + F4 or F5..depends on the what key was designed for the touchpad), the touchpad might be locked.
If it is not locked, reinstall the touchpad driver, but it this still doesn't work, boot to Safe Mode to check if it does. Touch pad still not responding in Safe Mode would mean hardware failure.
Hope this helps.
Jun 16, 2011 | Computers & Internet
Some of the keys on my keyboard are producing wrong symbols not all of them mostly tge right hand side of the keyboard for example when i press the letter 'o' it produces /6 and the p produces -* how do i...
this means that your number lock is turned on.
there is a Fn key on the board. hold that and look for the number lock key and press it. each system is different so it will be either NumLk, NumLock, or a 1 with a lock symbol. Acer generally places this on a F key many times F7.
Jun 03, 2010 | Acer NSK8458AN Keyboard
When I press certain keys like P I get 6
This is yoru number lock function
look along the "F" key row for the NumLk or picture of the number 1 in a square. then hold down the Fn key on the lower left of the board. press the "F" key that corresponds to it and this will disable it.
Feb 18, 2010 | Acer NSK8458AN Keyboard
Just bought Acer laptop (series 5517) and the keyboard appears to be locked. How do I unlock it??? Please help 9/27/09. Thanks!
DOES THE MOUSE WORK OK?
If not, re-boot and press the [F8] key to get into the "Safe Mode" screen. See if the keyboard works in Safe Mode.
If so, go tothe Control Panel and select "keyboard" and update the drivers.
If not, then re-boot and select the [F8} key again, but choose "Start computer in last known good configuration"
If it still doesn't work, but the mouse does, then the keyboard is disconnected or the connector is loose; open 'er up and connect it.
Sep 28, 2009 | Acer 91.63X07.001 Keyboard
Key board my o types 6 how do i change this
The num lock has been pressed.
I don't know which Fn key you need to press to turn off the number lock. Look at the Fn key for a symbol - number pad, press this and it should release the number lock.
Have a look at your manual for this infomation.
Jul 12, 2009 | Acer Extensa 5620 Notebook PC
Cant find the number lock key on my acer 6920 laptop
I think for your laptop the number lock key is a second function... Try holding down the function (Fn) key and pressing the F11 key, hopefully that will turn your number lock on/off.
Nov 23, 2008 | Acer Aspire 5100 Notebook
Key board
Press and hold the blue fn (function) key then press the nmlck(numbers lock) key. This enables or disables the numeric key feature.
Jul 23, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Keyboard Fn key
Try hooking up and external key board see if that works ok, and if it does you may want to try to find a new or used key board for your laptop. The key board may be shot, It should be fairly easy to change to a new board, Hopefully That will help you diag. the problem..
Jan 06, 2008 | Acer Aspire 5630 Notebook
Acer NSK8458AN Keyboard Logo
147 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
