Question about Kodak EasyShare V550 Digital Camera
Camera won't turn on after wrong ac adaptor was used, battery is OK
I have a V550. My son put the wrong AC adaptor in the camera to charge the battery. The battery will still charge, but the camera will not turn on. I had the battery checked out and it's still good. I also tried a new battery with no luck. Is it worth having it looked at for repair or is it most likely to cost no than it is worth?
  • graywo Oct 11, 2008
    I have same problem when pluged 12v adaptor from DVD instead 5v for Kodak.
    They said in repairshop that main board dead and it'll cost more $100 to make camera good. Now for this price I can buy 8MP Samsung brand new...
    Scholar:
  • 51 Answers
Probably likely that the circuitry is damaged and that getting it replaced would be more than you could get another for.
Try eBay for a cheap one, perhaps missing the charger and accessories.
Posted on Feb 29, 2008
My sony handycam DCR-TRV340E is not charging at all, dont know if its to do with the battery or the AC power adaptor
First, check that the camera switch is in the off (charging) position.
If this is OK, Check the battery output connections for voltage: use a multimeter.
To check the charger, put a load resistor across the output terminals (about 1000 ti 2000 ohms) and again, using a multimeter, check there is a charging voltage. Alternatively, if the camera operates OK with the charger attached and switched on the charger is OK, AND, the problem is then in the charging circuit from camera to battery. If the battery checks OK as in the beginning, then you will need a Sony repair man who needs to know all the results from your testing above.
May 27, 2014 | Sony Handycam DCR-TRV340E Digital...
I lost my camera charger and i wont to put some pics up but it wont turn on what should i do
you need to purchased a charger or 5V AC Adaptor for the camera. sing this 5v AC adaptor you can charged the camera or Turn On the camea
Nov 15, 2009 | Kodak EasyShare M853 Digital Camera
When i go to charge my kodak M863 camera (in the wall or by USB) the green light flashes and then the red light blinks 3 times. please help this is the first time charging my camera.
You can used the USB cable to charged the camera, But some of the M863 camera will not take charged usign the USB cable., I strongy suggest used the AC adaptor just make sure the AC adaptor is 5V ac adaptor it will only charged using the 5V adaptor., About the flashing green it indicates camera is charging just wait for the solid green light it means it fully charged
You may purchased also a special charger for your battery(KLIC-7001)- cahrer model is K8600-C. i think the price of this charger is around $29.00
Nov 14, 2009 | Kodak EasyShare M863 Digital Camera
My Kodak m1033 will not stay on. Once I press the power, the screen is blurry and then it shuts off.
If your using the battery which is included on the box the KLIC-7004 try to clean the 3 metal contacts of your battery using a clean dry cloth. hen charged the battery using AC adaptor or USB cable., Now if this not work, Try to turn On the camera using the AC adaptor if you experienced same problem it means the your camera is defective, But if you can turn On the camera using AC adaptor It means the battery is the cause of the problem
You may call tech support toll free 1 800 235 6325 ext 12
Nov 13, 2009 | Kodak EasyShare M1033 Digital Camera ...
Lost Power to camera
well you should lurn from this,,only use the charger that comes with the unit,,,im sorry to tell you this but you more that likley have done your camera in was the charger you pluged into your camera the same voltage and polarity as the cameras normal charger?
if it was in revers you would have cooked the camera
Nov 05, 2009 | Kodak Easyshare 1725043 M893Is Digital...
HAVE A KODAK 8.1 MODEL M893 CHARGE IT WHEB YOU TURN ON IT'S ON YOU GO TO TAKE PICTURE IT SHUTS OFF
Are you suing the recommended battery KODAK Li-Ion Rechargeable Digital Camera Battery KLIC-7001? If no please purchase KLIC7001
Now in case you are using this KLIC7001, How do you charged the camera or battery? USB cable or AC adaptor? If your using USB cable actually some of the M893 will not charged using USB cable you need to update the firmware or download the firmware before you can successfully charge it using the USB cable
Now if the AC adaptor make sure when you plug the adaptor theres a light indicator on the camera and charged the battery for 4hrs., and still the camera will shuts off everytime you take a picture please call kodak toll free 1 800 235 6325 have your camera repair. Gudluck!
Nov 05, 2009 | Cameras
Battery won,t charge
the price of KLIC7001 $29.00 try to purchase the battery at wallmart target or at kodak.com/go/shop.,
how do you charged your camera USB cable or AC adaptor? if USB cable make sure that the Cable is working fined and the USB port of a computer is not defective., If the AC adaptor., try to clean the 3 metal contacts of your KLIC7001 using clean dry cloth, then charge it again. if its failed., try to test first the camera itself using different KLIC7001 if its not charging it means the problem is on the camera not the battery
Nov 02, 2009 | Kodak EASYSHARE M1063 Digital Camera
MV730i video camera not used for 6 months. How do I recharge the battery? Will connecting the camera to the Canon mains adaptor automatically charge the battery? Do I leave the camera in the off...
Connect your AC adaptor into CAM and set to off position and make sure the amber light will on to indicate the system is charging OK
Nov 30, 2008 | Canon Cameras
Lost AC Adaptor Fuji Finepix F20
Go to a reputable Fuji supplier, or www.fujifilm.co.uk
Nov 05, 2007 | Fuji FinePix F20 Digital Camera
Kodak EasyShare V550 Digital Camera Logo
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
