Question about HP DeskJet 845c Printer
New colour cartridge but no colour print
I have replaced the colour cartridge but I cannot print colour. I have cleaned print heads and cleaned the the cartridge but no result. What can I do??
  • 26 Answers
Sorry but not much, there is a product on the market called nozzle rockett, it is the best i've used to free up a clogged print head, in AUS you can get it at any Cartrige World
Posted on Feb 28, 2008
One colour won't print. tried new cartridge but
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Aug 12, 2011 | Canon PIXMA MP810 All-In-One InkJet...
Printing colour is wrong, colours come out pink. Nozzle check indicates cyan colour is not printing. I have carried out cleaning, deep cleaning. I've cleaned the print head and finally just replaced the...
> replaced the print head
Did you replace the tri-colour ink-cartridge, or did you replace the print-head mechanism?
Are you sure that the CYAN part of the ink-cartridge is not empty?
Mar 09, 2011 | Canon i9900 InkJet Photo Printer
The colours on our HL-4040CN have gone all strange - when we perform colour calibration the colours go either red or green. All toners are new and the drum has been replaced recently as well. We do a lot...
Hi
We need to isolated the problem on what cause ink cartridge not print in color. When even you installed new cartridges, It is necessary to run the print nozzle to clean the print head. Also, please try to clean the print head manually by removing all the ink cartridges and rub the print head into a white paper with alcohol until ink flows and then return it back and run the print nozzle for 2 times.
Then try to print again.
If it does not help you, please let me know to give you more help.
Mar 03, 2011 | Brother HL-4040CN Laser Printer
Lexmark z615 only prints black and blue no other colour It is a new cartridge
The print head for the other colours may be blocked.
Try the clean print head maintenance a few times. You may need to replace the print head.
Sep 21, 2010 | Lexmark Z615 InkJet Printer
Printer won't recognise new colour cartridge
I got a new print head @ "staples" office supplies. It didnt cost me anything!!! Kodak had probs with the head, & gave a bunch to staples.....i changed the head, put in new inks, again...got a calibration to run...& things printed np!!!
Apr 14, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Colour cartridge does not print in red
Call tech support. I believe your print head is in need of replacement. Usually they will send you out a new on free - in 3-5 days. They are foreigners (tech support) but they are knowledgable and very helpful.
Feb 19, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printing colours
The color cartridge is faulty, you need to replace it.
If it is new ask a refund.
After putting a good cartridge do head cleaning.
Sep 03, 2008 | HP Officejet 5610 All-In-One InkJet...
Epson Photo R265 Lines every 2.5 cm
Check status monitor see if cartridges are low or nearly empty , if new or full take out all cartridges and soak nozzles upright in cleaning solution overnight , or untill ink starts to bleed out:
Dab dry and re - fit , make up a A4 paper page with 6 colour bands about 1" high x 8" wide and print about 4 to 6 pages ,
check which colours are poor , if improvement is observed run
again a few times:
If one colour is poor take out that cartridge and soak again for a few hours , try again:
If no improvement replace with new cartridge or use a cleaning cartridge ( available on-line ) :
Using the head-cleaning utility shortens the life of the printer as the printer is set to lock-out after a pre-set use of the cleaning facility: and will have to be re-set instore:
cx3200@tiscali.co.uk
Dec 17, 2007 | Epson Stylus R265 InkJet Photo Printer
Magenta ink colour
I had the same problem. Try cleaning the print heads. They tend to clog. Remove the cartridges, then remove the print head. Tilted slightly, it comes out easily. Run very warm to hot water over the print heads until they all run clear. Use a turkey baster to apply strong pressure to each head until it runs clear. Blow off the excess water with mouth or blow dryer. Insert into the printer and proceed to print. If that doesn't solve it, you might have a bad cartridge, but there isn't much that can go wrong with the cartridge. I have an ip4200 and an MP830. They have the same print heads and same cartridges. I have cleaned each twice and they work like new.
Sep 10, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
HP DeskJet 845c Printer Logo
150 people viewed this question
Ben Johnson
