Question about OKI MICROLINE 280 Elite Matrix Printer
Form feed length for 280
How do we reduce the lenhth of the form feed from 12" to 11"
  • 152 Answers
Change in your computer driver setting
if you using windows xp
click to
start
settings
control panel
printer and fax
select your printer and right click
properties
in general menu
printing preferances
change here paper size
select letter 8.5" 11"
Posted on Feb 29, 2008
Machine does not appear to have a button to sew in reverse
try these suggestions
Reduce the stitch length to zero. The machine will stitch in place and form a locked stitch
1) rotate the material and sew over the same stitching. Leave the needle down in the work and raise the presser foot, then turn the fabric around.
2) decrease the stitch length to very small for a few stitches
OR
3) hold the fabric and prevent it from feeding at the beginning and end of a seam, which makes very short stitches
4) stitch about 1/2", raise the needle and presser foot, return the fabric to the beginning position and stitch over the first half inch of seam again. Do the same at the end
Jun 17, 2015 | Euro-Pro Sewing Machines
Problems with Printing Special Size Forms
you have to chk the setting on the print setup.
Jul 04, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Paper Feed Problem
Try changing the exchange rollers (Feed, pickup, and retard rollers)
Mar 27, 2014 | Canon DR-7580
The printer feeds to much papper
The first thing you need to do is to check the paper size selected in the application you are printing. If you are printing from a Windows based application you WILL find that the paper size selected in the application you are printing from is set to A4.
On the printer you can set the paper size in the following way;
  1. Power the printer ON holding down the SETUP button to unlock the menu, release SETUP when the printer finishes initializing
  2. Put the printer OFFLINE press SETUP
  3. Press the button under MENU
  4. Press the button under NEXT until you see FORMLEN (if you do not see FORMLEN select the PAPER option it may be a sub menu for PAPER)
  5. Press the button under TRACTOR 1
  6. Press the button under LINES
  7. Use button 2 to reduce the number of lined to 18 (3 inch x 6 lines per inch)
  8. Press the button under SET to save the setting
I am assuming the form length is 3 inches, if it is 1.25 inches this may be outside the specification for the printer and you may not be able to select this it is also not dividable by 6 lines per inch
Oct 25, 2012 | Tally T2240/24 Matrix Printer
Oki 321 turbo in PPR emulation mode, does a form
Generally the form feed character is sent by your software. Try setting the page length in the printer setup to be the length of one label.
Sep 28, 2009 | OKI MICROLINE 321 Turbo Matrix Printer
Printing a label 4x 1 7/16
Try setting the page lenght using the printer panel
To do this, enter MENU mode by pressing SHIFT+MENU
press GROUP button until prints REAR feed or BOTTOM feed ( depend on where you load the forms from )
Press ITEM button until it prints form length
Press SET to change length as required
To exit, repeat SHIFT+MENU
All the best
KM Hoo
Feb 11, 2009 | OKI MICROLINE 590 Matrix Printer
IBM 4232 Printer Problems
in the PRINTER SETUP menu there will be FORMS DEVICE
select and set
Continuous Forms — F1 or F2
Dimensions
Forms Min Max
Width 3in - 15in
Length 3in - 14in
Nov 05, 2008 | IBM 4232 Matrix Printer
Oki microline 280 feeds paper continiously after a file print, and won't stop till i pull power cable
First, reinstall the driver and be sure it's the correct driver for this printer. If you drive a word document does it do the same? If not, chanses are the db application is constantly sending form feeds to the printer and the printer will do whatever it's told to do. Try a different printer setup in the db application.
Aug 27, 2008 | OKI MICROLINE 280 Elite Matrix Printer
Feed and Tear Off position problem
You can give this a try. This will alter the top of form setting.
http://www.profitmonster.com/printers/ml320tb.html
Let me know if this helps.
Mar 27, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
TALLY T2250 PRINTER
It sounds like there is 12 inch form length (or may be A4) selected on the computer system. The data from the system will take precidence over the 11 form length set on the printer.
If using Windows, ensure the Printing Preferences in the pritner driver are set to 11 form, Also check Printer Properties for a paper size ensure this is set to 11 inch
On the 'System' check the paper size selected within the application (if available) Check this is set to 11 inch form length
Check document margins to ensure these are not reducing the 'printable area' on the page. If availabe to a Print Preview on system to see what the document looks like.
If your application outputs raw data to the printer, check the number of lines per page assming printing at 6 lines per inch you can fit 66 lines on an 11 form. Check no more than 66 lines are per page, it sounds like 72 might be being sent befor a Form Feed in the data. (there may be a 1 line top margin set on the printer)
Finaly check the top margin setting on the printer to ensure it is set to 0 so you have the full 66 lines available on a page on the printer I think you would be looking to set the FORM ADJUST to 0 to adjust the top margin
Feb 22, 2008 | Tally T2250 Matrix Printer
OKI MICROLINE 280 Elite Matrix Printer Logo
360 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
