NEC 19'' LCD monitor power on but screen blank
NEC monitor 19 in LCD blue button light goes on but screen come on for a few second then goes blank
  • 3 more comments
  • pmichaud Feb 29, 2008
    I tried a new LCD monitor and everything works so it must a faulty monitor problem maybe something to do with a bad inverter ... because the light on the unit works the screen appears for a few seconds and goes black... I tried all the menu button nothing works...
    thanks... again
    jp
  • pmichaud Mar 02, 2008
    I tried a new monitor and it work fine with my PC I tried the faulty LCD Monitor and got a brief Icon and then it went gradualy black till I shut it off again it did the same again maybe a capacitor or something like that... ???
  • Barbara Hecht May 11, 2010
    Lots of things can cause this. What OS are you using?
    When you start your computer (with the monitor turned on) is it on until it hits Windows?
    -If so, restart in Safe Mode and under Device Manager - uninstall all monitors, reboot in normal mode and Windows will reinstall what it needs. Remember to not set your resolution/refresh rates to high for the monitor you have.
    -If you have the type of video cable that can be flipped around (same connection type on both sides) - remove cable from PC/Monitor and flip and re-seat both ends.
    -Try a different power cord on the monitor (assuming you have the type that uses a standard cord).
    -If you are using any type of power strip - remove the strip from the equation and plug the power for the monitor directly in a wall outlet.
  • Anonymous Mar 17, 2014
    Identical to solution 1. Have an Optima 19" LCD monitor running on XP latest service pack. thanks Col
  • Anonymous Mar 22, 2014
    when I go onto bbc news or sport after a few seconds it goes to a white blank screen
    Master:
  • 474 Answers
Just make sure it doesn thave a built in Power save mode, sometimes these are defaulted to be on and its just going to sleep.
Posted on Mar 02, 2008
    Problem Solver:
  • 9 Answers
Here are a couple of suggestions...
-If so, restart in Safe Mode and under Device Manager - uninstall all monitors, reboot in normal mode and Windows will reinstall what it needs. Remeber to not set your resolution/refresh rates to high for the monitor you have.
-If you have the type of video cable that can be flipped around (same connection type on both sides) - remove cable from PC/Monitor and flip and reseat both ends.
-Try a different power cord on the montor (assuming you have the type that uses a standard cord).
Posted on Feb 29, 2008
If you have a video card it may not be working anymore.
    Problem Solver:
  • 7 Answers
Check cabling it may be loose
  • 20 Answers
If you can try it on another unit , If it still does not work, Then the most likely culprit is a bad power supply. If you know any thing about soldering replace the capacitors they are probably bad but being that these things are being built so cheap.It could also have a bad inverter. not repairable by average dude.If you open it be careful and do not attempt unless you feel comfortable with a solder Iron.Hope this can help you Good Luck. www.IrionsTVshop.com board re builders.
  • wayne Ezyk
    wayne Ezyk Mar 02, 2008
    After reading the solutions put on others I regret to inform you they are a wast of time. I have been repairing for years and encountered this problem about 100 times it has always been the monitor. By your description. If you tried it on another monitor no go, What else would you expect. Two computors same results as I said, Its in the monitor. Not for a beginner. I wish I could give you a simple answer that would work for you.But EXPERIENCE tells me.Monitor
I have 2 of these monitors with the same problem. On power up the green led will light & remain on but the screen remains black. On one of the monitors the screen will light up for a few seconds then...
The inverter that turns on the back light may be bad - it's suppose to create the high voltage pulses to fire the CCFL back light lamps. Apparently the back light turns on after a few seconds however, it cannot stay on because the inverter might be bad. If you connect a known external CCFL lamp to the to the inverter output you can isolate the inverter.
Dec 26, 2010 | NEC MultiSync LCD2010 20.1" LCD Monitor
Multisync LCD 1700V turns on then screen goes blank and shuts off
Does the power light stay on? If so, you have an inverter problem. If the power light goes off, you have a power supply problem.
Sep 02, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Pavilion f1903 silver goes blank seconds after turning on.
The monitor you have has bad components on the circuit boards inside.
This is a classic problem with all LCD monitors.
I rebuild them on a daily basis so I recognize the symptoms.
I would suggest finding someone who can do component level repair on the circuit boards inside.
I also suggest not trying to repair yourself as there are many breakable components to them as well as components inside that do not like static electricity discharges.
May 17, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
NEC MultiSync lcd 2010 monitor blank screen
This is the common bad capacitor problem. The caps have died inside, and they can be replaced. If you have basic electronics skills, you can go in, order replacement caps, and unsolder and resolder. If you can't do it yourself, you can take it into a shop.
Here is a link to the Cap plague that explains what happens in detail. But I repair these all the time with that symptom.
http://en.wikipedia.org/wiki/Capacitor_plague
Apr 02, 2009 | NEC MultiSync LCD2010 20.1" LCD Monitor
Hp1903 blank screen
power shortage maybe...try to plug your monitor on the other power supply,,be sure that your monitor is compatible on the voltage it required..
Aug 04, 2008 | HP vs19 (Silver) 19" LCD Monitor
Monitor goes blank less than a second after turning on.
Beautiful screen, lasts about for a few minutes, goes black. Power button still green. If I turn it off, and then back on, it works again for a while. Any ideas?
May 11, 2008 | Mag Innovision LT982s 19" Flat Panel LCD...
Nec flat screen goes blank after 20 seconds
i got the same prob.supposedly its the cap(capacitor) ,the one for the power suppy near the cord input.im getting my shit fixxed.and i will let you know.
Sep 24, 2007 | NEC AccuSync LCD72VX LCD Monitor
DiamondPoint V71LCD Not displaying image
The LCD screen may be burned out. There's whats called an invertor board and there is an electronic ribbon strip on the LCD itself. If you look very carefully you can probably see a faint image on the screen. The LCD screen will need replacing. Before doing anything with this monitor, try it on another computer first and if you can try another monitor on your computer. Other than that, there really is nothing you can do but replace the monitor.
Jun 27, 2007 | NEC-Mitsubishi Nec Display Solutions...
Computers & Internet Logo
184 people viewed this question
David Payne
David Payne
