2000 daewoo nubira gets no heat.
No heat, fan blows, but car still gets no heat. 2000 Nubira sedan
Chances are the heater controls have been disconnected they may feel like they are turning properly at the dials but they may have been broken or disconnected...
look under the dash along the centre console, you will be able to see the pull'ies and the ajoning mechanisms, while you are still under the dash turn the dials and you should be able to see the mechanisms move as you do it... check they are all connected.
sometimes there are 2 visable in the centre from the drivers side
and often one passenger side or behind the glove box.
Posted on Feb 29, 2008
My 2000 Daewoo nubira over heated and now won't start.
blown head gasket or even warped cylinder head are possibilities.
Apr 22, 2015 | 2000 Daewoo Nubira
Where is cramshaft located on deawoo nubira 2000
Look here V, reasonable mechanical knowledge is required to repair the engine.
2000 Daewoo Nubira engine diagram Google Search
Mar 25, 2014 | 2000 Daewoo Nubira
What's your problem?what does trouble code p0463 relates to for a 2000 daewoo nubira ?
p0463..... fuel level sensor A circuit high input...... thats the problem
Dec 28, 2011 | 2000 Daewoo Nubira
Need diagrams to replace a heater core on a 2000 Daewoo Nubira
Go to your local parts place and ask for a print out.
Nov 10, 2011 | 2000 Daewoo Nubira
Need timeing belt diagram for 2000 dawoo nubria how to instill
CLICK HERE and HERE for timing belt information on the Nubria
Thanks for using FixYa
Aug 03, 2011 | 2000 Daewoo Nubira
Daewoo nubira 2000 was working fine until the
replace the idle speed controler.it not cheap,
Mar 10, 2010 | 2000 Daewoo Nubira
No interior heat in my 2000 daewoo nubira
3 possible issues here,
the first is that your thermostat is stuck open, when this happens the air will barely be warm, luke warm at best, replacing the thermostat will fix this problem
the second, is that you have low coolant levels, when your coolant levels are way low, your heater core doesn't get the proper amount of coolant (if any) and the system blows cold air instead of heated air.
The third and final possibility, is that your heater core has clogged up (usually happens when stop leak or some type of radiator sealant is used) when this happens you can feel warm air when accelerating (test this by gently reving the vehicle and holding the rpm's when it is in park and holding your hands over the defrost vent to check for heat.
If you can tell me what symptom your vehicle is having I can help with instruction on how to fix it thanks cnc_couple@live.com
Jan 09, 2010 | 2000 Daewoo Nubira
How can I replace a freeze plug on a 2000 daewoo nubira?
Yes, use a quality replacement and tighten to get a good seal. They hold forever.
Dec 27, 2009 | 2000 Daewoo Nubira
Change alternator on daewoo nubira
first you need to remove the belt . there are only several bolts to remove the alternator . there should be a diagram on the panel by the hood prop rod to show the belt route
Feb 18, 2009 | 2000 Daewoo Nubira
I am looking for the paint code of a daewoo nubira 98 sedan. it is not located where it should be on the vehicle. its the green colour
Although Daewoo cars no longer exist, many other dealers have ' taken them under their wing ', locate your local dealer and give them a call and quote the reg number and they will give you any info you want......from your colour code to the radio code. good luck.
Aug 12, 2008 | 2000 Daewoo Nubira
149 people viewed this question
 Grubhead
Grubhead
