We have two Sony DVD RW 720A(s). We have had absolutely no problem burning movies for the past 2 years. As of late, we have had multiple problems burning movies. I can't even recall the last time we were successfully able to burn a movie. The CD burner works perfectly fine, but when you attempt to burn a movie, it will say "copy completed" - we use 1 Click Copy - but if you try to watch the movie, toward the end of the disc, it will start getting choppy and freeze. You can actually see a spot on the bottom of the disc where something went wrong.
Sometimes, it will say "copy completed" and the disc won't play at all. And at other times, the disc will act like it burned okay, but there will be less than half of an inch of content on the bottom of the disc, so it definitely isn't right.
Our PC is up to date on everything. We have Windows XP. Everything else is working great... it's just the DVD burning part of it... We're really confused....
when direct burning from that is from one DVD RW DRU -830A to another , after three or two minutes...
(More)
when direct burning from that is from one DVD RW DRU -830A to another , after three or two minutes it shows burn process failed at 16x (22,160KB/s) How to correct it ?
I know that both the Sony DVD RW DRU-720A and Sony DVD RW DW-D22A and working fine. They show up in...
(More)
I know that both the Sony DVD RW DRU-720A and Sony DVD RW DW-D22A and working fine. They show up in the my computer. I can put any kind of media in both drives and nothing happens. I can put an OS cd in the drive and reboot the computer and be able to reinstall the OS from the cd. It seems like the issue is in XP not the drives. Any ideas on what might be the cause of this? This is a fresh install of XP Pro with no updates installed yet.
