Try these :For Windows XP
SOURCE: ASUS P5S800-VM mother board V Asus EN9500GT graphic card
you would need a new mother board or change the graphics card
SOURCE: P5S800-VM multimedia audio controller driver
Hi Mairaj, please click the link posted below. This is Asus download site for your board P5S800-VM. Suggest you bookmark this page in case you need another driver.
http://support.asus.com/download/download.aspx?modelname=P5S800-VM&SLanguage=en-us
Creat a folder on your desktop & name it Audio.
Click the + sign next to Audio. If you are using Win XP home or Pro download,
Realtek ALC655 AC''97 Audio Driver V3.66 for Windows 98/ME/2000/XP(WHQL)/2003.
File size 24.17MB. Save file 32b366.zip in the folder you created.
The file 32b366.zip must be uncompressed before you can install it. If you do not have winzip please download this program for free from the link below. Install winzip into your PC.
http://www.download.com/WinZip/3000-2250_4-10003164.html?tag=pop.software
Once the file 32b366.zip has been uncompressed you can install the software.
If you have more questions feel free to ask.
Good Luck & have a Great Weekend!
Mike
SOURCE: I have an ASUS P5S800-VM Motherboard socket LGA775
To answer your question, yes it's possible.
I'm sure you wouldn't like it if I left it at that, so I'll explain a bit more.
It's about as simple as this: The processor you want to install into the motherboard is for an LGA 775 mobo such as yourself. Therefore, it should have no problems when you put it in.
Hope I was of assistance.
SOURCE: need driver motherboard asus p5s800-vm
Drivers for your P5S800-VM Motherboard can be downloaded thru manufacturer's Support site:
Just select the correct Operating System you are using and you're good to go.
Hope it helps.
SOURCE: ASUS P5S800-VM Motherboard integrated RTL 8100 C
I know Asus motherboards well. The P5S800-VM motherboard uses, Realtek 100/10 Mbps Ethernet Controller. (Its not a card) it is intergrated into the motherboard. Download and install, Realtek RTL8100C Ethernet Device Driver V5.505.1004.2002 directly from Asus. Open the link provided below;
http://www.asus.com/product.aspx?P_ID=ZcyLktAZjt2bXqgs&content=specifications
Open the dropdown menu and click on you're operating system. There you will see a list of drivers. Click the + sign next to word LAN. You'll see the driver for RTL8100C. Download and install.
Cheers'
Mike
