Question about HP Officejet 5510 All-In-One Thermal Printer
Computer is saying the hp officejet 5510 all in one priter has a paper jam but it does't so i cant print
My computer is saying that the hp officejet 5510 all in one printer is having a paper jam but I don't see any paper stuck what do i do? HELP
  • 3 more comments
  • Anonymous Mar 24, 2008
    The omputer says there is a jam. There is no jam. I click okay and paper is fed out with no printing. Each time I try to copy the paper will feed into machine and rigth before the printing process should occur there is a clicking nooise and a noise in which it sounds as if the paper or machine part is not meshing correctly.
  • Anonymous Apr 08, 2008
    Printer says Add paper and will then hit OK. does not clear the problem, remains unable to print.
    Looked inside as best I coud, all seems OK
  • EDYTKA Apr 08, 2008
    My HP 5510 all in one printer keep saying paper jam, but there is nothing jamed inside. Tried to reset by turning power off then on again, but it keep saying paper jam. Please help!!!
  • Anonymous Mar 19, 2014
    My hp officejet 5510 stopped working. I sent it for repair. Could the maintenance man use my hp 5510 to get copies of papers that I printed in the past from my computer. does hp officejet keep in its memory information of papers that it printed in the past from the computer after it completed printing.
    My hp officejet 5510 stopped working. I sent it for repair. Can the maintenance man use it to print copies of the papers that I printed in the past from my computer using this hp device.In other words, does the hp officejet 5510 keeps in its memory hidden copies of the papers it completely printed from the computer in the past.
  • 152 Answers
Paper out sensor not working it's possible
Posted on Feb 28, 2008
HP 5510 says clear paper jam. There is no jam
You could try unplugging the printer from the wall outlet, wait a few seconds then replug. Often times HP printers require a memory reset to clear up problems. There is no need to unplug from the computer, just the outlet.
Jul 17, 2010 | HP Office Equipment & Supplies
I just replaced the black cartridge for an hp officejet 5510 and removed the color cartridge because I did not have a replacement for it. Will it work without the color cartridge in? ALso, I put paper in...
This printer will not work with either cartridge missing or out of ink. Remove the paper and look very closely at the paper tray to locate the paper sensor switch. Make sure that when you insert the paper it trips the switch. Check to see if a small piece of paper has jammed in the switch area and is not allowing the sensor to move. Also look at the entire paper route and make sure that there is nothing jammed in the path. Let me know if you need more help.
hardrocko
Thanks for using FixYa and the generous rating.
Mar 13, 2010 | HP Officejet 5510 All-In-One Thermal...
HP 5510 All In One. Error message Paper Jam when printing photo paper 8X10. There is no paper jam. Plain paper runs right through.
Have you changed the paper properties to reflect that you are using a heavier weight paper?
If not, then the printer might not be set right for the paper you are using and that can cause the problem you are seeing.
Dec 05, 2009 | HP Officejet 5510 All-In-One Thermal...
Paper jam hp 5510
Look in the rear of the machine for an access door.
Jan 04, 2009 | HP Officejet 5510 All-In-One Thermal...
My printer won't print from the computer command; it will print fax or copy a paper.
MY PRINTER WONT PRINT FROM THE COMPUTER. IT WILL COPY A PAPER, BUT NOTHING FROM THE COMPUTER COMMAND.
Nov 04, 2008 | HP Officejet 5510 All-In-One Thermal...
Paper jam
I have an HP 5510 All in one, and mine did the same thing. There was a plastic fingerlike thing that had hung up just to the right of the printhead, preventing it from moving. I removed the cartridge and managed to get the part unstuck with a screwdriver.
Oct 20, 2008 | HP Officejet 5610 All-In-One InkJet...
Paper jam, but i just hooked it up??
the paper MUST be dry and non slick, other wise the mechanism can't handle it..
Nov 19, 2007 | HP Officejet 5510 All-In-One Thermal...
Paper jam
i have an hp office jet 5510 and its not print and it keep on saying cartiage is jam , the timeing is all mess up the leg that bring the paper out keep on coming up whilethe cartiage is going across is there a way of reset the print to get back the timeing
Nov 01, 2007 | HP Officejet 5510 All-In-One Thermal...
Printer installation
ok how is the computer hook to printer ,
(usb? or serial cord) ?
what operating system are you using
and what software are you using for print drivers
let me know and i can help you in greater detail but here is a link to hp for your printer
i hope this is somewhat helpful
feel free to reply back if you cant get it working im shure i can help
richard from chicago
http://h10061.www1.hp.com/ccsearch/search?pname=HP+Officejet+5510+All-in-One&opname=HP+Officejet+5510+All-in-One&qry=I+am+having+trouble+with+the+computer+recognizing+the+HP+Officejet+5510.++What+can+I+do%3F&method=prodFinder&ctry=us&lang=en&dlc=en&sni=311255&search=0&submit.x=0&submit.y=0
Oct 31, 2007 | HP Officejet 5510 All-In-One Thermal...
HP Officejet 5510 All-In-One Thermal Printer Logo
903 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
