INDESIT LAVABIANCHERIA WIA 82 (EX) 60 HZ
THERE IS A POWER FAILURE FROM THIS PRODUCT. I HAVE ONLY USED THIS 6 TIMES FROM THE TIME IT IS BOUGHT BY MY HUSBAND IN DUBAI, UAE AND HAVE A CARGO HERE IN THE PHILIPPINES... IT IS CHECKED BY THE AUTHORIZED TECHNICIAN OF INDESIT HERE IN THE PHILIPPINES... AND THEY NOTICED THAT THERE IS AN EXPLOSION FROM THE BOARD INSIDE... HOW CAN WE DETECT IT? THERE IS NO DIAGRAM INSIDE THE LEAFLET OR MANUAL... COULD YOU PLEASE GIVE US A DIAGRAM OF THE CONTROL BOARD OF THIS PRODUCT?
  • 26 Answers
Hello Novs,
The only you can get a diagram of your machine is from a service technicain or from a service center.
I hope this information helps,
Spurs21
Posted on Feb 29, 2008
    Problem Solver:
  • 12 Answers
This sounds like a case where the Philippines use a 50hz power source and maybe you use 60 hz in UAE? If that is the case then getting 6 loads out of it is kind of amazing. The way these things are these days it is better to buy a new or used one since the cost of a new main board and a technician installing it correctly....might have to have a certain software update to it, it is just not worth the trouble. Besides, more than one thing might have blown. You replace one and it still might not work or the real problem will blow the board again. Unless you are a highly qualified technician on this particular unit it is probably best to chalk it up to a lesson learned.
Posted on May 19, 2012
In moving I am unable to find the AC charger and plug cord for my Electric Houdini. This is brand new - never used !
What voltage is the AC ? 120V 60 Hz ??
Found this but it is for 120V 60 HZ
http://www.rabbitwine.com/replacement-parts/adapter-6-volt-2925-series-647771.html
however if your AC power is 240 volts 50Hz you need to keep looking !
What is an electric houndi - is it a electric cord screw ? this is my guess ?
Important note the 6v DC and the 80mA current rating on power AC- DC pack. If there is any marking on your Houdini similar make sure voltage is 6v DC and current is 80mA or less .
suggest you contact rabbit wine if your ac is 240 Volts and is not 120v 60 hz on the www,rabbitwine.com web site contact link or if DC voltage does not match. Or for advise on if it matches your device.
Feb 02, 2018 | The Computers & Internet
System failure in my laptop ??
Remove the battery from the computer and plug in the correct charger and see if it will power on. without the battery. if so turn off and put battery back in with power connected see if it powers up.
Oct 29, 2007 | HP Compaq Presario 730US Notebook
Hi the clock is set for 60 Hertz, What about countrys with 50 Hertz in voltaje?
50 Hz means the electric generator rotates 50 times per second.
And then electricity oscillates or reverses polarity 50 times per second.
Products rated for 60 Hz will not operate correctly with 50 Hz power.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Feb 16, 2014 | Coralife Power Center DayNight Timer or...
Confusion installing drivers on Dell Latitude 120L laptop running XP
to run duel screens you will need a graphic board that has 2 outlets
I run a nvidia board and it has a dvi and vga outlets connected to 2 monitors
open up the control panel and go to display
that will show 2 screens and they will be identified as 1 and 2
the printing will be for one screen and it will say -make this my main screen
further down will be a dropdown box that will have extend screen
click on that
as for the screen size or pixal settings click and drag the slide button up to the top and click on apply
any way in that display section you can move and click on different settings to get what you want, always apply to fix the settings selected
it will come back with a message --do you want to retain the settings and if you are happy --click on yes
regardless of what you choose , you can always reset at a later time
Feb 26, 2017 | Aoc Monitors AOC e2752Vh Glossy Black...
I have a Simply Perfect For The Home brand Microwave Oven that I bought from the U.S. Military post here in Schweinfurt, Germany for $50 I live on the economy in my own apartment. The microwave is a 120...
Just as a NOTE: When I bought my Panasonic microwave from AAFES, before I took it home, they sent it through their maintenance department to adjust the internal voltage. Power for the US is 60 HZ. Power in Europe is 50 HZ. Long Technical Explanation shortened: there's more energy (Heat) in 50 Hz than 60HZ especially when used in anything that uses high power. AAFES adjusted the internal power down to compensate and keep from blowing up the unit. Look for a fuse inside. Replace it, then ask AAFES to reconfigure the product for lower power or 50Hz.
Also as a note, many, dare I say most, clocks from the US count the HZ to count time. So if your US clock, say on your coffeepot timer, looses time overseas; it's probably losing 4 hours a day (do the math: 50 hz/60hz=83.333_%. 83.3_%*24 hr=20 hrs or 4 hours lost). So, if your time is set for 7AM coffee start, when you get that cup of coffee at 7:10AM, set your clock forward to 11:10 AM; or at 7PM, make sure it actually says 9PM. It will loose enough time by the next 7AM to be correct.
Aug 11, 2011 | Microwave Ovens
Whats the resolution setting for a L1715s monitor
The LG L1715s can support resolutions between 640 x 350 up to 1280 x 1024 @ 75Hz. The recommended resolution is 1280x1024 at 60Hz. The manual is available here: http://www.lg.com/uk/support/product/support-product-profile.jsp?customerModelCode=L1715S&initialTab=warranty&targetPage=support-product-profile .
The preset modes are:
VGA: 640 x 350 @ 70 Hz, 720 x 400 @ 70 Hz, 640 x 480 @ 60 Hz
MAC: 832 x 624 @ 75 Hz, 1152 x 870 @ 75 Hz
VESA: 640 x 480 @ 75 Hz, 800 x 600 @ 60 Hz, 800 x 600 @ 75 Hz, 1024 x 768 @ 60 Hz, 1024 x 768 @ 75 Hz, 1152 x 900 @ 65 Hz, 1280 x 1024 @ 60 Hz, 1280 x 1024 @ 75 Hz
I hope this helps.
Feb 10, 2011 | Computers & Internet
Ki need help programing my p that i bought used also i olnly have some of thehcodes for toulare county (porterville) thiat is where i live.... can yuo help me? thanks, kary ro 82 scanner
Before you start programming you'll need a list of frequencies (not codes). For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
That site also contains a lot of other useful scanning data, including links to users groups.
To program a known frequency into the scanner:
1. Power the unit ON.
2. Press the PGM key.
3. Enter the desired channel number (1-200).
4. Press PGM again.
5. Enter the frequency, including the decimal point (ex: 462.365).
6. Press ENT to enter the data into memory.
7. Repeat steps 2-6 for other channels.
More detailed programming instructions can be found in the scanner operating manual which you can download/print here:
http://support.radioshack.com/support_electronics/doc69/69887.pdf
Bill B
Jun 29, 2010 | Radio Shack Pro-82 Scanner
What type of graphics card to buy for an emachines EL1600
Take the card back - take the pc tower with you - take the cover off and show the sales man where you need the card to fit - you do not have PCI slots - sorry - but there is a pc video card that will make you happy - just get one made for your set up-
Apr 02, 2010 | Computers & Internet
SR573... Does it support NTSC/PAL?.
There's no mention of either NTSC or PAL in any spec sheet.
This link leads to Onkyo and the rear view of the amp lacks the voltage selector.
http://www.onkyousa.com/model.cfm?m=TX-SR573&class=Receiver&p=s
The manual for the similar model SR575 says the North American model does not have the voltage selector. Too bad. Under the general specs for the variants of this family of receivers they list the following power specs. I have no idea where you have to go to buy one from the "Others" group.
Power Supply North American: AC 120 V, 60 Hz
European: AC 230 V, 50 Hz
Others: AC 120/220-240 V, 50/60 Hz
AC 220 V, 50/60 Hz
Some aliases for the SR575=
TX-SR505
TX-SR505E
TX-SR8550
TX-SR575
You could do what I did over 30 years ago. Join the Army, go overseas and buy one in the PX. Every HiFi product we bought in the PX in the 70's had the dual voltage feature.
Apr 07, 2009 | Onkyo TX-SR573 Receiver
Power supply
no it should not but if it does yuo should be able to replace the mains filter to a higher power filter
Aug 19, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
808 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
