Question about IBM ThinkPad R50e Notebook
Wireless Problem I have the problem activating my wireless LAN, and when I open the "Network Connection", there isn't any icon inside. What should I do? When I try to click on "Set up a home or small office network", after I have click the Next button twice under the "Network Statupe Wizard", on the third page of the "Network Statupe Wizard", it prompt this: "The wizard found disconnected network hardware." And I cannot proceed anymore after that. What should I do?
  • Anonymous Mar 06, 2008
    sir i have a problem when iam connecting to wireless network it wont connect to dhcp
    wht i do?
  • Snoopy668 Mar 07, 2008
    After having to reinstall the factory settings on my R50e, I have lost my wireless connection. Has anyone else had the same problem and if so how did you resolve it?
    Problem Solver:
  • 8 Answers
When u start your computer press f2 or f8 one that will have your computer info. look for wireless internet or something like that and check if it is on
Posted on Feb 28, 2008
IF its IBM Select Fn+F5 in wireless radio tab select turn on button for wireless Radio
    Genius:
  • 1,019 Answers
If your computer found Disconnected Network Hardware, then you should have a small icon at the bottom right hand side of the Screen, Taskbar. Click on the arrow pointing left. which will reveal all icons. If you have a tv screen with a red X on it. then your device is already installed, but has a problem or not setup correctly. Right click and Open Network Connections. right click on the item that relates to your hardware ( wireless LAN Connection ) see what options you have. Repair Connection/ et,c , From there you can Also troubleshoot the Device further. ** Do Not Rate this Post Until your Problem Is resolved**
I will assist you further if required, based on these conditions.
  • 26 Answers
Kanasai, sounds like the wirless adaptor is turned off, normally this is the result of the power settings sutting it down on batteries to conserve power. you should have a FN key combination to turn it back on , for example on my ASUS its the "FN" key and the "F2" key at the same time.
Basicly you can check the device manager to see if the wireless adaptor is enabled. then look at what software manages the wirless connection
How do I turn on an acer aspire wireless switch?
Sony's Sony Vaio laptop features built-in wireless LAN adapter that allows the computer to connect to any wireless access point. If you want to adjust the device's WiFi settings, you must use the proprietary software and hardware that comes preinstalled on the laptop and the Internet connection options that come with Windows. Once you have all of the correct settings enabled, you can have your laptop connected to a wireless access point without any additional applications.
Enabling Wi-Fi with Wireless LAN Switch b> Before you can connect to a wireless network or change any of your Wi-Fi settings, you must first enable the computer's Wi-Fi feature with the wireless LAN switch. This switch is located directly below the laptop's screen and is labeled "Wireless." Once you have located the switch, slide it into the "ON" position. b> Enable Wi-Fi in Vaio Smart Network b> Once Wi-Fi has been enabled with the wireless LAN switch, you must enable Wi-Fi using the laptop's proprietary wireless connection software, "Vaio Smart Network." To access this program, click the "Start" button in the computer's task bar and select the "All Programs" option. Select the "VAIO Smart Network" option to launch the program. Alternatively, you can click the VAIO Smart Network icon in the computer's task bar to launch the program. This icon is in the shape of a green button with two white arrows on it. Once in the application, click the switch to the right of the "Wi-Fi" heading to toggle it to the "ON" position. Windows Connect to a Network b> With Wi-Fi enabled, you must connect to the wireless network using the "Connect to a Network" feature that is a part of the Windows operating system. Click the network icon in the computer's task bar to bring up a list of the available wireless networks. This icon is in the shape of a computer and an Ethernet cable if you not connected to a network. If you are connected to a network, it is in the shape of signal bars. Select the desired wireless network from the menu that appears and select the "Connect" option. Enter the networks password if necessary and connect to the network. b> Network and Sharing Center b> If the wireless network that you want to connect to does not appear in the "Connect to a Network" window, you must connect to the network manually. Click the network icon in the computer's task bar and select the "Open Network and Sharing Center" option. Click the "Manage wireless networks" option, followed by the "Add" option. Click the "Manually create a network profile" option and type the network's information in the spaces provided. Place a checkmark next to the "Start this connection automatically" option and click the "Next" button to connect to the network.
b>
Feb 08, 2013 | Sony VAIO VGN-AR150G Notebook
I have sony vaio S. but the wirelees is not working no wireless host shown. how can i fix it?
Selecting the wireless function Follow the steps below to select the wireless function to be activated when you set the WIRELESS switch on your computer to on. Double-click (wireless switch icon) on the Notification area at the bottom right of the desktop.The Wireless Device Switch dialog box appears. Hints The appearance of the wireless switch icon changes depending on the selected wireless function. Point to the wireless switch icon to display the selected wireless function. Alternatively, you can right-click the wireless switch icon and select "show Wireless Device Switch settings" to display the Wireless Device Switch dialog box. Select the desired wireless function from "Wireless LAN" or "Bluetooth Device". Notes 5 GHz Wireless LAN is available on certain models only. You must select at least one wireless function to perform wireless communications. The 2.4 GHz and 5 GHz Wireless LAN functions employ different frequency bandwidths, thus are not compatible with each other. Checking the check box for both "Enable 2.4 GHz Wireless LAN" and "Enable Bluetooth Device" may cause poor communication performance or a connection loss due to electromagnetic interference. Click OK. The message "Setting up the wireless devices. Process may take several minutes. Please wait." appears first, then the Wireless Device Switch dialog box is closed, and finally the dialog box that describes what to do with the icon on the Notification area appears. Note While the message "Setting up the Wireless Devices. Process may take several minutes. Please wait." is displayed, do not: place your computer into power saving mode. turn off Windows or log off from the current user. turn on and off the WIRELESS switch. Confirm the settings and click OK. The dialog box about the icon on the Notification area closes. Hint If you check the "Don't show this dialog in the future" check box, the dialog box will not appear next time you close the Wireless Device Switch dialog. To analyze the network condition You can analyze the network condition if you select either or both of the wireless functions under "Wireless LAN" in step 2 above. Click the "Diagnose" button to start Windows Network Diagnostics. When the network analysis is complete, the result is displayed. If any problems are found, follow the on-screen instructions. Hint Windows Network Diagnostics is the function to identify problems the network has and present solutions to them.
Mar 01, 2011 | Sony Computers & Internet
I have a wireless connection but cannot open the browser. Another computer (laptop) is connecting fine on the same wireless.
If the Wireless Network Connection icon is at the bottom right of your Taskbar and has a red x, then right-click on the icon to bring up a pop-up window and in that window, left-click on View Available Wireless Networks. This will open a Wireless Network Connection window which will allow you to Choose a wireless network. If the window has the message "No wireless networks were found in range", then you will need to slide the spring-loaded switch at the right-front the netbook to the right momentarily and the message "Wireless LAN Enabled" should show in large green letters at the bottom of the screen. Then in the Wireless Network Connection window, left-click on "Refresh network list" item under Network Tasks. In about 10 seconds, a list of the wireless networks will be displayed which should include the name of your wireless access point (wireless router). Left-clicking on that list item will high-light it in blue. Now click on the connect button at the bottom-right of the window. If the list item has a lock symbol, a Wireless Network Connection pop-up will now show to ask you to "Type the key" otherwise for an unsecured or open access point, a connection should automatically occur without having to type any key. The Wireless Network Connection icon in the Taskbar should no longer have the red x and hovering the mouse cursor over it will show the Wireless Network Connection status. Hopefully, if this procedure has solved your problem, you should consider securing your access point to prevent unauthorized access of it. After securing, you will need to refresh the network list and then do a re-connect.
Jan 30, 2011 | Acer Aspire One Netbook 8.9" Notebook
Cannot the wireless internet setup
Hi kschmerer,
I understand that you are not able to setup the Wireless Network Connection in your Computer.
To fix this issue, please make sure that the Physical Wireless Switch on the Computer is turned ON and then try connecting the Computer to the Wirelss Network.
You can locate the Physical Wireless Switch on the front side of the Computer. Please move the switch toward right side to turn it ON.
Once the Physical Wireless Switch is turned ON, please try setting up the Wireless Network Connection.
If you are not able to to connect to Wireless Network Connection after switching on the Physical Wireless LAN Switch, try using the Wireless Switch Setting Utility.
To enable the Wireless Network Connection using the Wireless Device Switch Utility, please double-click the Wireless Device Switch icon on the right corner of the Taskbar. Then in the open Wireless Device Switch window, please click to check the box next to Enable 2.4Ghz Wireless LAN.
This should fix the issue.
Please post back if you have any questions or require further assistance.
Thanks for using FixYa.
Dec 07, 2010 | Sony VAIO VGN-AR150G Notebook
Hello, my laptop cannot connect using wireless even though i have pressed fn & f2 keys, the bluetooth icon is activated i.e. turns blue but theres no sign of wireless network..what could be the issue...
Hi, if you are using windows XP, check for your control panel, look for network connections, and then on the LAN or Highspeed internet portion, check if there is an icon for wireless connection, if there's none, the driver of you wireless is not installed. If there is, right click the icon and then select enable.
Jun 16, 2010 | Dell Latitude D410 Notebook
My toshiba laptop does not work on a lan. The icon
When you look at the Manage Network Connections link on the Network and Sharing Center you do not see
Local Area Connection?
Do you see Wireless Network connection?
You need to check the device manager to see if the card has been disabled.
It should show two entries with no red or yellow marks. One for wireless (WLAN) and one for wired (Ethernet)
Apr 11, 2010 | Computers & Internet
Wireless lan disabled. where is button to enable
for windows XP - go to control panel - network connection - eneble wireless LAN
for windows vista - go to control panel - network and connect sharing - manage netwrok connection - right click wireless icon then enable
for windows 7 - go to control panel - network and connect sharing - manage netwrok connection - right click wireless icon then enable
Mar 28, 2010 | HP Pavilion dv5tse Notebook
So i have my desktop set up online, but i want to get my laptop hooked up as well and i have a router. how do i hook that up to?
On the right bottom corner of your screen, you should see a message/icon about wireless networks.
Select the icon and you should see a list of wireless networks. Select your network, add your password (if you set up a password) and you should be connected.
Open your browser.
Hope this helps.
Sep 08, 2009 | NetGear WGR614 Wireless Router
Unable to activate wireless lan
TRY GOING TO START, START SEARCH TYPE WIRELSS DEVICE
LOOKE IN DEVICE MANAGE FOR WIRELESS FOLDER
INPUT DEVICES
AS SO CHECK THE FOLLOWING FOLDERS ALLOWING COMMUNICATION BETWEEN THE LABTOP AND THE WIRELESS DEVICE AND THE COMPUTER.
NETWORKING AND SHARING FOLDER
PROBLEMS AND REPORTING
SECURITY FOLDER
SYNC CENTER IF YOU HAVE ONE
WINDOWS DEFENDER
WINDOWS FIREWALL
THE LAST 2 PROGRAMS IN THE LIST ABOVE CAN STOP THE DEVICE FROM WORKING.
YOU WANT MORE HELP I WILL HELP YOU IF YOU HAVE THE SITE CONTACT RODGANDYSR@GMAIL
ROD
May 12, 2009 | IBM TP R51 - P M715 1.5GHZ 256MB 40GB...
My laptop cannot connect to my local network (LAN)
Assuming you initially set up the router using the wired lan adapter and lead, enabled DHCP in the settings. First stand right next to your router; Dells wireless is a little tempremental, go to control panel and in there should be Dell wireless monitor, open this up refresh it and see if it finds any wireless networks, if so try to connect. Dissable your wired network lan adapter. Go to the properties of your wireless card and on the TCP/IP line click properties again and ensure that obtain an ip address automatically is selected, press ok and restart the pc.
Sep 20, 2007 | Dell 1470 (W9284) 802.11a/g/b Wireless...
IBM ThinkPad R50e Notebook Logo
250 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
