Question about HP Photosmart 3310 Printer
Unable to close Lid
I opened the lid to change an ink cartridge and now it is STUCK...I am unable to close it with normal pressure...Is there a latch or catch somewhere that I am missing? HELP!!
  • Lee Lee Feb 28, 2008
    That is what we are guessing.....can't really see anything broken or loose or disjointed. Is it repairable? Planning on taking it in to Best Buy today to see if it can be fixed...Please let me know if you have any ideas
  • Lee Lee Feb 29, 2008
    Thank you....I took it in, it was the 1st time any of the technicians saw this problem...they ended up "breaking" the hinge and then just putting it together again...no charge...I guess that is better than charging me....A spring got loose...oh well, it still works.
    Thanks!
    New Friend:
  • 3 Answers
Bon je fais mon feedback aussi pour ceux qui ne comprennent pas l'anglais. J'ai ouvert par inadvertance ma HP photosmart a fond, je parle pas du petit couvercle de scan, mais de la grosse ouverture la ou on met les cartouches... et MERDE ! elle voulait plus se refermer ! Surtout ne pas forcer, mais bon en general ca donne l'impression de quelque chose qui bloque, donc une personne normale ne va pas forcer. La solution (que j'ai trouvee sur ce site, merci) c'est de se procurer du WD40, ce lubrifiant bien connu, et d'en arroser les charnieres. En manipulant doucement votre imprimante, vous allez voir, elle va se refermer gentiment au bout de dix minutes. Quel soulagement ! (et pardon pour les accents qui manque, ce site ne les prend pas, nul n'est parfait)
Posted on Sep 21, 2013
    President:
  • 2,072 Answers
Sounds like the hing on back is broken. Look on the back of the cover, there will be 2 hinges holding the scanner on. Probably a piece of plactic broke and is hanging up one of the hinges.
Possibly a small spring.
Posted on Feb 28, 2008
  • Rick Kasper Feb 28, 2008
    Hi.
    Sorry I have been out. But yes, That should be a very simple fix.
    I have never seen a feeder itself break. Just something to do with the hinging. I would take it. Seems very fixable to me.
  • Rick Kasper Feb 29, 2008
    Thank you very much for letting me know. Those springs in those hinges aer difficult to see, since they are sealed.
    And nice to see they did not charge you.
    There are a lot of very honest people in service that realize that customers are in the same " make a living" mode as they are.
    Glad it's resolved for you.
How to change the ink of printer Epson stylus Office BX300F. Show me in the computer to change the ink in printer now.
Turn on your printer and raise the lid or press the cartridge changing button. Wait for the cartridge carrier to slide out.
Lift the cartridge holder lid, and the cartridge will pop up for removal.
Carefully remove the tape from the ink opening on the bottom of new cartridge.
Insert the new cartridge into the cartridge carrier. Make sure the new cartridge is oriented the same way that the old cartridge had been.
Close the cartridge holder lid and press the cleaning button to charge the cartridge.
Close printer cover.
Watch here full details:-https://www.youtube.com/watch?v=8gL5xoiDenA
Still unable to change the ink, you should go to customer support at +1-800-243-0051 ' +1-800-243-0019
May 05, 2017 | Epson Office Equipment & Supplies
How to change printing cartridges
Here's how to change your cartridges: 1 Make sure the printer is on. 2 Lift the scanner unit. The print cartridge carrier moves and stops at the loading position, unless the printer is busy. printmastert_25.jpg
3 Press down on the cartridge carrier latch to raise the cartridge carrier lid. printmastert_26.jpg
4 Remove the used print cartridge. Note: If you are removing both cartridges, repeat step 3 and step 4 for the second cartridge.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
You may also refer to this link: How to Set Up the Lexmark X3600 or X4600 Series All-In-One
Apr 04, 2011 | Lexmark X3650 Printer
How to change the ink of an epson stylus sx215
press the index sheet button and the scan button at the same time, you then get setup menu. use" >" to select "change ink cartidge". the ink cartidge will move to the opening position. lift the grey plastic clip at the back, and it will open towards you. then they just pull out
Jan 07, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Printer (HP5650) has full ink cartridges.window sez almost empty
That is normal, the printer "sees" the cartridges by their serial number, so when you pop in a refilled cartridge, the printer thinks you have put in old cartridges and continue to show low ink level. When you pop in a new one, with a new serial code, the ink level will reset, showing that the cartridges are full again.
You can try this:
1. Open printer lid so cartridges move to center of carriage.
2. Lift clamp and remove black or color cartridge from the holder.
3. Place cartridge on table with copper contact strip facing you.
4. Carefully place a strip of clear plastic tape over the four contacts on the upper left corner of the cartridge.
5. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position.
6. Open lid and remove cartridge again. Remove tape from left side and place tape over four contacts at upper right corner of cartridge.
7. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position again.
8. Open lid again, remove cartridge, remove tape.
9. Reinstall cartridge and close lid.
Printer will now recalibrate. Once the process is complete the ink level meter should be reading full again.
Doesn't always work, but you can try.
Here are links, so you can see:
http://www.misterinkjet.com/hp56reset.htm
http://www.misterinkjet.com/hp57reset.htm
Hope that helps!
Dec 22, 2009 | HP Hewlett Packard Deskjet 5650 InkJet...
I cant close the lid of my
Same thing happened to my printer last night (never happened before) and I too am looking for some release latch....so frustrating and I don't want to force it closed...
Nov 10, 2009 | HP Photosmart 3310 Printer
Changing ink cartridge
Mar 07, 2009 | Epson Stylus C86 InkJet Printer
I have a Sentry Safe H4300. I put a few important papers in it, but am unable to open it again to put more papers in it. Please Help! Thank you. Ruth Jackson
I have a H4300 Safe. To open the safe...
1) Unlock it with the tubular key
2) With one hand, push down on the lid (moderate pressure should do & preferably close to the latch area).
3) While still pushing down with one hand, use the other hand to squeeze the red latch button and lift up.
You can't open the lid by just squeezing the red latch button and trying to lift up. It won't. You need to push down, then unlatch, then lift.
Works everytime for me,...hope this helps.
Aug 04, 2008 | Sentry Fireproof Safe
Ink Cartridge
Make sure the power is on when you open the lid. The cartridges should move into the center so you can get to them. If they don't, close the lid, remove the power supply and reinsert it. Turn the printer back on and try again.
Sep 23, 2007 | Lexmark P4350 All-In-One InkJet Printer
Close top
try a power flee....by unplugging all power cables , removing cartridges etc and wait for 2 mins and them replug the cables and reinsert the cartridges..... lets see if that resolves hte issue
Jan 22, 2007 | HP DeskJet 5150 InkJet Printer
HP Photosmart 3310 Printer Logo
731 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
