Question about NetGear DG834G Router
Trying to install Netgear Router DG834G on Vista and failing!!
I'm trying to install my netgear wireless modem router (DG834G) on my vista-run laptop and having lots of problems!
Managed to get a fair way of the way through the installation CD, but in the end it tells me my computer has more than 1 network adapter, it requires a wired ethernet network adapter (which is the yellow cord I have plugged in I think??), that I can't use a wireless adapter, and to click the wired adapter I'll be using.. only I can't click on anything!
It then took me eventually to a page to put in my IP address and the DNS addresses, which I did, but then it tells me that something is wrong and to check those addresses and check the cables etc. etc.
Originally the computer did something automatically about my IP address - I think making it the same as the router?
I'm really lost, don't know what all these things mean!! Should I do things manually rather than use the cd? (I don't know how to do that either!)
  • morgan16 Feb 29, 2008
    Thanks Tony!
    Turns out there was some type of problem with the phone company also, so I'm waiting for them sort themselves out, then I can get back to sorting my router out!!
    Really appreciate your help :)
  • 38 Answers
Don't bother installing the router with the cd.
There isn't any drivers your computer needs, it just installs cr*p.
You will, however have to set up your router they didn't send it to you already set up.
If you bought your router from your ISP when you took out your broadband, its probably already set up. Simply plug the router in, plug it into the phone with a microfilter in, and watch the green lights on the front. If the 'internet' or 'dsl'light lights up green, it should mean your router is already set up.
Now, you should be able to connect to the internet by plugging the yellow lead in. if you can, then your router is definately set up.
Now you just have to set your wireless up. To do this you need to search for wireless networks. If you know how to do that , then locate your one (it will probably be called netgear something) click it, and click connect. If it asks for a network key, look for a sticker on the router, and it should have your network key printed on it.
Hope this helps. I've been a little vague in places but i'm not sure of your level of understanding
Regards
Tony
Posted on Feb 28, 2008
  • 57 Answers
SOURCE: Can't get internet access through NetGear DG834G Router
You have to configure your router...
If your ISP provided you with IP Address, enter the assigned IP address, subnet mask, gateway IP address anbd DNS IP address for your broadband router.
If you connect to the Internet using an xDSL Modem and your ISP has provided you with a Password and a Service Name, then your ISP uses PPPoE to establish a connection. You must enter the required information.
Hope this could help..
Mon =)
Posted on Nov 16, 2007
  • 19 Answers
SOURCE: NETGEAR DG 834G ROUTER
Could you give me some overview of the topology of the network your trying to install the router on? (How it's all connected, and the ip addresses of the machines and other routers on the network (if any)) ?
Posted on Nov 30, 2007
  • 101 Answers
SOURCE: Netgear DG834G Setup
Hi Tradeboy,
This link should walk you though it, step by step!
http://www.geekgirls.com/windowsxp_home_network.htm
If you are using Vista, you will probley want this link, too. Click on Network icon.
http://windowshelp.microsoft.com/Windows/en-US/default.mspx
In the past I have found the biggest issue with networking is firewalls, so I suggest you disable them just for testing and setting up your network.
Good Luck
Posted on Jan 11, 2008
  • 38 Answers
SOURCE: netgear DG834G v3 Installation
connect the yellow (or blue?) ethernet cable to your computer, this should connect to the router (router should be ON)
Now, in internet explorer type 192.168.0.1 (this should be the defualt gateway for the router on default settings.
Now you're into the router, there should be a setup wizard button in there.
See if you can set it up using that
Regards
Tony
  • 35 Answers
SOURCE: Netgear DG834G with xbox360
Connect to the Router,
Under the Security tab, select Services, then add, give it the name XBOX TCP/UDP, set start port as 3074 and end port as 3074, set type as TCP/UDP, click apply/ok. Do this again, giving it the name XBOX UDP, start port 88, end port 88, type UDP, then apply settings.
Now go to Firewall under the Configuration tab, under incoming click add, now select the service XBOX UDP/TCP from the drop down menu. select forward to specific IP address or similar and type in your Xbox's IP address e.g. 192.168.1.5, click log never, then apply ok. Do the same for XBOX UDP and your again click apply. That's it! you've successfully opened the necessary ports on your Router and told your Router that any incoming info on those ports should be sent to your Xbox.
Posted on Mar 19, 2009
Cannot contect
Who setup the dg834g router?
If it wasn't setup for wireless .. then you need to do that ..You must
login to the router (ip address by default is 192.168.0.1)
The admin password is password.
Jan 12, 2009 | NetGear DG834G Router
Setting up a lan and internet thru MTNL triband
I suggests you to go for Linksys. It's a good product when it comes to wireless internet. Linksys router must be plugged in to the modem. On the back of the router, you can plug the vista on port number 1 then your win XP machine can go wireless at the same time.
Sep 16, 2008 | NetGear DG834G Router
NETGEAR WIRELESS
reset the router...see if the laptop will see your access point..if it sees any access points at all....if it dosent then reinstall the wireless card. what version of windows are you using ?
Feb 28, 2008 | NetGear DG834G Router
Installation CD
Netgear lists these items to check.
http://kbserver.netgear.com/kb_web_files/N101234.asp
There is not really a driver needed, you just need to log into the router and adjust the appropriate settings.
See the installation and setup guides on Netgear's sight.
If you give me the link you are attempting to download, I'll help get you the file.
Jan 16, 2008 | NetGear DG834G 54 Mbps 802.11g Wireless...
Problem linking my wireless laptop into newly installed network
you may have to turn on the wireless feature in the router.netgear will help you to fix it.go to their site or call them for help.
Jan 07, 2008 | NetGear DG834G Router
Netgear DG834G router
Are you getting any internet?
Are you using Windows Vista?
Oct 19, 2007 | NetGear DG834G 54 Mbps 802.11g Wireless...
Netgear setup
You have to connect to the router with ethernet to get onto the configuration page. what i think what you have to do is to get a lan card and install it.
Oct 16, 2007 | NetGear DG834G Router
Connecting to a netgear DG834G with vista
so u r triying to login to ur netgear router>check with conn>connect the pc through the lan and login to the net gear and configured ur w/l part and dis the laptop restart and check
Oct 12, 2007 | NetGear DG834G 802.11G Wireless ADSL...
NetGear DG834G Router Logo
399 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
