Question about Microsoft AccRepair DS2 2004 for Fr (1256549SF)
Sorting string can u help on my problem bec. i dont know how to do the sorting a string. for example: the user can enter a 10 names and then the computer will arrange alphabetically. i'l wait. thanks
  • Anonymous Mar 14, 2014
    Write a pseudocode to accept a user name as input, append the entered user name to the text, Hello, and then display the appended output to the user. For example, Hello Mark should be displayed as the output if the user enters the name, Mark.
If you are using windows XP, click the start button. Choose 'Run' , type : cmd
and press enter to open a dos command window. Inside the dos command window, type the command: sort
then press enter.
enter some names and press enter after each name like:
john
terry
bill
howard
arthur
gary
fred
^Z
Press control and z at the same time when you are finished and press enter. The names will be output in order
(In windows vista, just enter the command cmd in the search start and press enter)
To output the names to a file, type
sort > filename.txt
press enter and then do the same as above. The names will be in a file called filename.txt
Posted on Mar 11, 2008
Account Settings for Thunderbird
1)In Mozilla Thunderbird, from the Tools menu select Account Settings.
2)Select Email account, and then click Next.
3)Enter your name and e-mail address.
4)Select POP or IMAP as the type of incoming server you are using. 5)Your incoming server is pop.example.net for POP, or imap.example.net for IMAP. Click Next.
6)Enter your e-mail address for the Incoming User Name, and Outgoing User Name. Click Next.
7)Enter a name for your email account and click Next.
8)Verify your account information and click Finish.
Oct 15, 2014 | Mozilla Thunderbird
Username and passwords
THIS IS THE APPROPRIATE ANSWER OF YOUR QSN!!
A user is a person who uses a computer or networkservice. A user often has a user account and is identified by ausername (also user name). Other terms for username include login name, screen name (also screenname).
A password is a word or string of characters used for user authentication to prove identity or access approval to gain access to a resource (example: an access code is a type of password), which should be kept secret from those not allowed access.
Jun 20, 2014 | Computers & Internet
A java code for anagram
import java.io.IOException;
public class AnagramApp {
static int size;
static int count;
static char[] charArray;
public static void main(String[] args) throws IOException {
String input = "Java Source and Support";
size = input.length();
count = 0;
charArray = new char[size];
for (int j = 0; j < size; j++)
charArray[j] = input.charAt(j);
doAnagram(size);
public static void doAnagram(int newSize) {
int limit;
if (newSize == 1) // if too small, return;
return;
// for each position,
for (int i = 0; i < newSize; i++) {
doAnagram(newSize - 1); // anagram remaining
if (newSize == 2) // if innermost,
display();
rotate(newSize); // rotate word
// rotate left all chars from position to end
public static void rotate(int newSize) {
int i;
int position = size - newSize;
// save first letter
char temp = charArray[position];
//shift others left
for (i = position + 1; i < size; i++)
charArray[i - 1] = charArray[i];
//put first on right
charArray[i - 1] = temp;
public static void display() {
System.out.print(++count + " ");
for (int i = 0; i < size; i++)
System.out.print(charArray[i]);
System.out.println();
Nov 22, 2010 | Computers & Internet
Retrieving acess data which is password protected thru VB
You will need to use a connection string. But - before you can configure the string correctly, I'd need to know how the data is stored (Access, SQL, ODBC, etc). You can find examples online. Just know that you are looking for "Connection String." Here's two examples:
1. For MS Access (Jet files):
' Set up the connection string.
m_strConn = "Provider=Microsoft.Jet.OLEDB.4.0;" & _
"Data Source=" & strDestDBPath & ";" & _
"Jet OLEDB:Engine Type=5" ' NOTE: Use Type=5 for Jet 4.x.
2. For SQL database:
g_strADOConn = "Provider=SQLOLEDB;" & _
"Data Source=SERVER_NAME;" & _
"Initial Catalog=DATABASE_NAME;" & _
"User ID=mssql_userid;" & _
"Password=mssql_password;"
Apr 22, 2009 | Microsoft Visual Basic 6.0 for PC
Sorting string and numeric
One simple way to achieve this is using radio button function. Give the user flexibility to change sorting via String or Numeric. As the user clicks on String the result bottom of this option will change the sorting method using String. Otherwise, Numeric.
By the way, please be specific in posting your question. Include the development tools that you use. For example, MS Access 2003.
Regards,
Maha
Feb 04, 2009 | Intelligent Computer Computers & Internet
Dont know the password and user name
http://192.168.0.1
then type user name:admin
password is:admin or blank
then enable DHCP.then u can get ip automatically.
Nov 12, 2008 | D-Link AirPlus DI-524 Wireless Router
Changing to a secure setting
Go into your router's configuration page (see your router's manual for how to do this, it is an address that looks something like http://192.168.1.1). In there you want to find the wireless security section and change it to WEP security.
You will then need to enter a 64 or 128 bit WEP "key". This is your password to access the wireless network and the way you enter it is you enter a 10-character string (for 64 bit) or a 26-character string (for 128 bit) that contains only the numbers 0-9 and the letters A to F.
An example of 64 bit wep key is: 5145466d52
example of a 128 bit wep key: 3c2f2339483f2537373c57775f
Once you save your settings, your router should appear as a "secured" wireless network. When you try to connect, it will ask you for the key. Enter the same key you entered into the router.
That's it! The hardest part is finding the WEP section in the router's settings.
Jan 24, 2008 | Belkin (F5D5231V4-SN-PD) Router...
Slow web page loading
To setup and improve your wireless network’s signal, you can change your Wireless Network Name (SSID) and/or try using a different channel.
Changing your Router’s SSID and Channel
Step 1:
Access the router’s web-based setup page.
Accessing the Router’s Web-Based Setup Page
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router’s IP Address ("192.168.1.1" is the default IP of most Links-ys routers) then press [Enter].
Step 3:
A new window will prompt for a User name and Password. Leave the User name space blank, type in your router’s password ("admin" is the default password), then click OK.
Step 2:
When the router’s web-based setup page appears, click the Wireless tab.
Step 3:
Look for Wireless Network Name (SSID) and if it’s still set to ‘linksys’ change it to something unique then click Save Settings.
click the Wireless tab and select the Wireless Security tab.
Step 3:
Select WEP under Security Mode.
Step 4:
Select any number on the Default Transmit Key field to determine which key you’ll be using. In this example, we selected number one.
Step 5:
Select 64 bits on WEP Encryption
Step 6:
Type a wireless network password of your choice such as “MySecretKey,” then click Generate.
NOTE: You should come up with a password that is unique for your network and is a combination of numbers and letters up to 10 characters.
Step 7:
The result will be a string of random characters. Copy the resulting string since this will be the key to your wireless network.
NOTE: Do not give this key to anyone. This will be your wireless network’s key.
And click save settings..
Nov 28, 2007 | Linksys Wireless-G WRT54GX Router...
Computers & Internet Logo
79 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
