Question about Refrigerators
Refrigeator not cooling i had a relat replace on it 2 wks ago an staryted to work nicely an now i have the same problem not cooling
  • juany Mar 12, 2008
    yes that is what happen the compressor was not working.. anyways this handyman came over replace the relay for $85.00 and it only work 10 days .. so i had to buy a new refrigerator and now i have a new relay on my kitchen drawer and the handy man wil not l take it back a total reap off.
    i would like to know what is a overload relay?
    President:
  • Refrigerators Master
  • 2,651 Answers
Overload start relay for your compressor replaced???if so sounds like a bad compressor( which probably broke initial overload relay)
Posted on Feb 28, 2008
How do I determine and fix what is wrong with 2008 model whirlpool frig that the freezer I noticed first all food unfrozen then a couple days later refrigerator not cooling can hear running but contin
I ned more information to answer your question. What model do you have? This is very important to give you the correct information you seek. Thanks
Sep 16, 2014 | Whirlpool Refrigerators
P0440 engine stopped
That code is an emissions cannister leak and is not related to the engine failure. IT is most likely the crank shaft sensor that is bad.
Apr 08, 2014 | 1999 Nissan Maxima
Motor just shut down, drove about 5 feet
Wow almost sounds like the Timing is way off.
Today's Lawn equipment.. as you say.. nice colorful ornament.
Jan 04, 2014 | Garden
Yukon XL was first showing Reduced Engine Power, then Oil Gauge quit working, now car is running hot
Might help, disconnect negative terminal from battery for 10 minutes, if the compute is getting weird readings this will reset it and maybe help.
Dec 09, 2013 | 2005 GMC Yukon XL
The light in the refriderator has no power getting to it and the temp display has no light showing
You have a Whirlpool refrig and it has a bad control board . This board is located behind the refrig , on the left side at the bottom , inside a plastic housing . This housing is held on by 2 screws at the bottom left . Remove the housing and the control board inside . Replace the board and reinstall the housing . It costs about $ 80.00 . When you go to get the part , take the complete model number with you so you get the correct board . This board controls the light for the refrig AND the lights for the control knobs PLUS other parts which work ok relating to the cooling .
Sep 23, 2010 | Refrigerators
I had cooling fan assembly reparied 2 wks, ago.
No replacing the cooling fan would not require replacing the thermostat although a good mechanic would have recommended you have the system serviced. At 80,000 miles you need a complete cooling system service. Drain, flush, replace thermostat, fill with a 50/50 mix of antifreeze & distilled water, and bleed air from system. Also have them check the function of the water pump and replace if it is suspect or has any play in the shaft.
May 24, 2010 | 2004 Chrysler PT Cruiser
I just had a tuneup 2 wks ago my coolant light
Bring the vehicle to Autozone and have then scan the ECU for codes . If your handy repair the items the codes are addressing.
May 20, 2010 | 1998 Volvo S70
Refrigerators Logo
310 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
