Question about ViewSonic VX2245WM LCD Monitor
Monitor flickering monitor flickers cannot find refreshrate
  • 4 Answers
Do a debug and re-install the video driver.
If doesn't work , let me know.
~Nitin
Posted on Nov 29, 2008
Flickering monitor, but laptop functions fine
Flickering monitor but laptop functions fine
Might be a bad monitor or the wron driver. Check your monitor on another computer, if still flickering, you should take it to repair.
Jun 24, 2015 | Computers & Internet
Tip
How to get rid of screen interference
Have you ever had a wired interference on your screen:
NOW IT ENDS!
There are couples of easy steps that will solve your problem!
1. Look out for any Electromagnetic field emitting devices next to your
monitor and move themaway(like phones, big magnets, speakers...)
2.Make sure that the monitor's plug, is well plugged and notmoving around.
3. On some systems, it is possible to reset therefresh rate of the monitor to line frequency (60 Hz) without serious sideeffects. More often, though, this will result in a sacrifice of resolution, andin almost all cases, the jitter will have been traded for flicker (the refreshrate has been increased by the monitor manufacturer to avoid flicker - the eyecan detect a refresh of the image at 60 Hz). Further, if the backgroundmagnetic fields are strong enough, even setting the refresh rate to 60 Hz willnot remove all of the jitter.
4. If all above doesn't work, and you can't stand the interference simply buyand LCD screen and never have these kind of trouble again.
on Jun 09, 2011 | Computers & Internet
Dell desktop monitor screen flickers.
The monitor is about to go bad. Replace it. Borrow a monitor from a family member, neighbor or friend just to see if the flickering stops. If it does stop your monitor is bad. If the borrowed monitor flickers, you will need to replace your Video Card in the computer.
May 01, 2012 | Dell Computers & Internet
My monitor is flickering
Flickering on the screen can be caused by defective hardware in the computer or by improperly installed software monitor may flicker and goes into rolling state due to dust, overheating after a long continuous usage,loose circuitry or due to some electromagnetic interference with other like tv , UPS, large speaker systems etc.
FIX :
1.Try Re-installing your Video driver
2 If it is possible, connect a different monitor to the computer. If the flickering disappears, it is a fair indication that the monitor is defective, otherwise go to the next step.
3. Set up the computer and the monitor on a different place in your house. If the flickering disappears now, it is most likely an interference caused by something in the original location. Check for devices which can cause interference.
4. If the flickering persists, check the setup of your system. If available in the setup, make sure that the option Monitor Type is configured as Colour Non-Interlaced.
If you don't think any above possible reasons for the rolling or flickering state of your monitor then we recommend you to get your monitor checked by the monitor company at their respective service cente
Sep 01, 2011 | LG Studioworks 700S 17" CRT Monitor
Hi, i need help with my monitor, it makeing some really strange interferences and i need help
Hi yaniv336,
if you need more help, check out my guide!
My BenQ G2220HD Monitor flickers. I've tried my level best to solve this problem but could not get rid of the flickering.
Try connecting it to a different laptop/desktop, to see if the flickering "follows" the monitor. If not, then the video-card in your computer is the problem -- try connecting another monitor to your computer, to see if the flickering still happens.
Sep 02, 2010 | BenQ G2220HD Monitor
Dell 2005FPW Monitor Flicker problem
The flickering is most likely the florescent backlight having a hard time starting, Just like in a light fixture, as it gets old, it takes longer to warm up to get full functionality.
If under warranty, contact Dell for a replacement, if not, then when it becomes untenable, replace the monitor. Prices are dropping drastically, an new 20 or 22 In can be bought for about $150 or less
Aug 08, 2009 | Computers & Internet
Flickering monitor
Flickering screen display
Flickering on the screen can be caused by defective hardware in the computer or by improperly installed software, but it can also be caused by interference from external devices. The following examples describe situations in which your screen could start flickering:
  • Screen starts flickering because of interference caused by devices which generate magnetic fields, for instance:
    • a TV set
    • a laser printer
    • another monitor
    • fluorescent lights
    • hidden power lines
  • Apart from interference, an incorrect setting in your system CMOS setup can also cause flickering. On some systems it is possible to distinguish between interlaced and non-interlaced monitors. The setup of your system should always be colour non-interlaced.
  • Proximity to the monitor of fans, air-conditioning units or other devices with rotating motors.
  • The number of devices using power from the same electrical line. Are you overloading the plug?
  • Monitor placed on an unstable surface.
  • Improper video drivers, this is a software problem, see section B
  • An improperly configured or a defective video card.
Sep 30, 2008 | E-Machines E17T 17" Flat Panel LCD Monitor
Monitor flickring
  1. Flickering screen display
      • a TV set
      • a laser printer
      • another monitor
  2. Reinstalling the video drivers
    1. Start the computer.
    2. Click Start, select Settings, and click Control Panel.
    3. Double-click the System icon.
    4. Select the Device Manager tab in the System Properties window.
    5. Make sure that View devices by type is selected and locate Display adapters and Monitor in the list.
    6. Click the plus sign (+) in front of both items to get a list of installed devices.
    7. You need to remove every device by highlighting it and clicking the Remove button and OK when the warning message appears.
    8. After doing so for both items, they should disappear from the list.
    9. Close the Device Manager by clicking OK, and you will return to the Control Panel.
    10. Double-click the Add New Hardware icon.
    11. Click Next, select Yes when it asks "Do you want Windows to search for your new hardware?", and click Next twice to start searching for new hardware.
    12. This will take a few minutes and, after it is finished, you will have to restart the computer. Windows 95 or higher will automatically set up the correct monitor and video drivers.
    13. If the screen is still flickering, click Start, select Settings, and click Control Panel.
    14. Double-click the Display icon and select the Refresh tab.
    15. Change the Monitor Refresh Rates until the flickering disappears.
    16. If the flickering remains, go to step C.
  3. Troubleshooting
    1. If it is possible, connect a different monitor to the computer. If the flickering disappears, it is a fair indication that the monitor is defective, otherwise go to the next step.
    2. Set up the computer and the monitor on a different place in your house. If the flickering disappears now, it is most likely an interference caused by something in the original location. Check for devices which can cause interference.
    3. If the flickering persists, check the setup of your system. If available in the setup, make sure that the option Monitor Type is configured as Colour Non-Interlaced.
Dec 24, 2007 | E-Machines E17T 17" Flat Panel LCD Monitor
ViewSonic VX2245WM LCD Monitor Logo
179 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
