Question about SanDisk Sansa e250 MP3 Player
Charging on AC
What charger can be use for ac charging.and what voltage can be use is it 110 v or 220 v.thank for your response
    Genius:
  • 1,019 Answers
The Charging Voltage Will depend On Your Countrys Existing Supply Voltage. If Your Standard Electrical Current ( In Home ) Is 110v Then You Would Use This.
******* Please Note:- MP3 And MP4 Players, only usually charge at a low current voltage Between 5-12 Volts.
Always ensure That You Have The Correct Adapter/Charging Lead For Your Appliance****
Failure To heed This Advice, Could Lead To Shock Or Fatality.
If you are In Any Doubt, Connect The Device To a PC Or Laptop With A USB Connecting Cable. This Will also Charge The device, as well as Being Able to transfer Data.
Mike @ Compurepair.
Posted on Feb 28, 2008
Hello, i just bought a Sky Force helicopter for my husband. i was wondering if i could buy a wall charger instead of using the remote for charging it. and if so how many volts and amp? thanks!
I am suspecting it would have come with a usb cable as well to charge the helicopter something like http://www.hobbytron.com/SpareUSBChargerForRaptorRCHelicopterZX35632.html
If this is the case you just need a usb charger
just type inot google usb ac adapter
(make sure voltage matches supply voltage if USA its 120V 60 HZ AC where as in England , Australia its 240V AC)
also check with hobbytron to see this charger suits the model helicopter you have
http://www.hobbytron.com/ChargingCordForGYROHerculesRCHelicopterZX35850.html
Dec 25, 2014 | Sky Toys
Tip
DISASSEMBLING AND CHARGER CHECKING
LENOVO S5000-F - S5000-H
Checking the Computer AC Charger
When you use the computer AC Charger to charge the tablet but no power is charged, see the instructions in this topic to check the computer AC Charger.
To check the computer AC Charger, do the following:
1. Disconnect the micro-USB cable from the tablet.
2. Measure the output voltage across the connector marked B of the micro-USB cable. Refer to the following figure:
For more pictures and description check the link bellow. On search tab type Lenovo
www.electro-medical.blogspot.com/
google.com/+AjinGopakumar
on Mar 07, 2015 | Lenovo S5000 7" Android 1GB 16GB
Tip
DISSEMBLING AND CHARGER TESTING
LENOVO YOGATABLET 10 HD+
When you use the computer AC Charger to charge the tablet but no power is charged, see the instructions in this topic to check the computer AC Charger. To check the computer AC Charger, do the following:
For more pictures and description check the bellow link. On the search tap type lenovo.
on Mar 07, 2015 | Lenovo Yoga Tablet 10 HD 59411049 - Silver...
Nc6000 multibay battery does not recharge
Perhaps remove the multi-bay battery, and let main battery charge all the way. Then reattach multi-bay battery, and see if it's recognized.
(Will charge)
That is AC adapter (Charger) removed, then remove multi-bay battery.
Plug AC adapter back into laptop, THEN plug AC adapter into power.
[You do Not want to unplug an AC adapter from a laptop, with the AC adapter plugged into power. Could be a power surge/voltage spike. Unplug AC adapter from power, when plugging into laptop, or unplugging from laptop ]
Main battery charged, unplug power to AC adapter, unplug AC adapter from laptop. Plug multi-bay battery in, then AC adapter.
(Then plug AC adapter into power)
Post back in a Comment.
Regards,
joecoolvette
Feb 28, 2013 | HP Computers & Internet
Fujitsu lifebook blinking battery led, bad ac adapter?
i would try purchasing a universal laptop charger on ebay and see if it works. they are under 25 bux. worse case scenario you will have a backup ac adapter. be careful plugging in other ac adapters because the polarity could be wrong or it could have to much amps
Jul 11, 2010 | Fujitsu LifeBook A6025 Notebook
Tip
Samsung TL205 Battery Charger Samsung TL205 Charger
With the most high-quality camera battery charger,
Description: Home Travel Charger
Input Voltage (AC): 100-240V 50-60HZ
Car Input Voltage (DC): 12-24V
Output Voltage: 4.2V/8.4V
Output Current: 600mA
Dimensions: 1.86" x 3.33" x 1.50"
Weight: 2.5oz (85g)
Color: Black
Features:
A. Direct Plug-In wall Samsung TL210 Battery Charger - No cable necessary
B. Samsung TL210 Battery Charger Output: DC 4.2V 600mA
C. 110-220 Volts - Works in every country in the world
D. AC Car Adapter - Charge your battery at home or in your car
E. Fast Charger 800mA - Charges most batteries in 60-120 minutes
F. LED Charger Indicator - Red light: needs charging, Green light: charging is complete
G. Samsung TL210 Digital Camera Battery with Manufacturer's 1 Year Warranty.
H. The Samsung TL210 Battery Charger is for charging your battery only. It does not work as AC adapter for your camera
on Sep 21, 2010 | Cameras
Just bought a second hand acer travelmate 4200. I have never owned a lap top. How do I change from using battery power to outlet power
On the left side, towards the rear is a DC jack. Plug the power cord in there. It should automatically start operating on AC power, and charge the battery.
Feb 24, 2010 | Acer TravelMate 4200 Notebook
Dell d610 latitude wont charge new battery
Hey,
First off, do you have a way to check the output of the ac adapter to ensure it's putting out the correct current?
If you've done that and have a multimeter handy, you can remove the battery, system off, and check the charge pins for current/voltage. I believe one of the end pins is neg (ground) and at least one of the other pins should show 2.6-3.6V, as well as other various voltages. If you fail to get any response at the charger pins, we'll need to look at the board circuitry, assuming again that the ac adapter is operating properly.
Good luck
Nov 26, 2008 | Dell Computers & Internet
No power, all buttons flash when connected to ac charger
if charger voltage is ok then it could be phones charging controler is not working. if phonebook is only thing you need could recharge battery directly from your charger and then save your phone book. cut off charging plug-connector from your charger make two bare wires and then apply red wire to battery "+" and blck to "-". 5min of charging will be enough to copy your data
Jul 21, 2008 | Samsung SGH-c225
About charging.
Just get a USB/AC converter. You can use the same computer cable to plug into the wall.
Paul
Mar 28, 2008 | Archos 604 WiFi Digital Media Player
SanDisk Sansa e250 MP3 Player Logo
88 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
