Question about Sony ACY-BR81/OB
Grinding PSP joystick
I am having problems with the joystick on my PSP slim.
I had this problem with the first PSP slim I bought and I returned it for another and here about 2 months later, same problem.
It feels like it is grinding against the plastic on the inside and makes kind of a "halting, stuttery" movements when you try to use itwhich can be quite irritating, especially when playing games like "wipeout pure" as you cannot properly control your vehicle.
Is there some way it can be lubricated, like with powdered carbon graphite or something?
Or maybe taken out and modified?
Thanks in advance for any advice offered! :)
  • David Roberts
    David Roberts Mar 13, 2008
    Yeah, I went ahead and did that a couple of weeks ago.
    Found a reasonably priced one on e-Bay that I ordered, but am still waiting for the arrival.
    I took the faceplate off to locate the joystick and to check the placement of everything, and yes, it is quite easy to remove and replace...I also have a really nice micro screwdriver set that I bought at an electronics store which helped considerably.
    I even managed to remove the warranty sticker with no damage using a hairdryer to heat the sticker so that the adhesive would release easier, so hopefully this will not render my warranty void.
    Anyhow, I appreciate the advice!
    Thank you :)
  • camdek May 11, 2010
    Eiswulfe
    I have another issue with the Nyko Theater Experience. You modded it for the PSP slim? Can you e-mail me the instruction to mod it?
You have to replace the joystick. do not use graphite as it will conduct accross the track. You need a thin philips srewdriver to remove 5 srews one under the label that says do not remove label in battery compartment.once all srews are removed cover pops out and its very easy to replace unit. Look on ebay for replacement joystick for SLIM MODEL PSP.
Posted on Mar 11, 2008
Analog stick broken
The following website does PSP analog joystick repairs. You can click on the "SEND US YOUR PSP FOR REPAIR" link on the following page:
PSP Slim PSP 3001 PSP 3000 Analog Joystick Assembly
Dec 04, 2013 | Sony PlayStation Portable (PSP) Console
Anyone replaced the Slim analog before?
You are risking to damage your psp using the wrong part, if you want to proceed in this way cut the rubber with a cutter. My main suggestion is buying right controller for your psp.
May 18, 2008 | Sony PlayStation Portable (PSP) Console
Tip
How to Replace Analog Joystick on PSP-2001
If your PSP's joystick won't go in a certain direction -- or characters walk by themselves, this part needs to be replaced. It is sold at the website all the way at the bottom for $16.95 and they can do this repair job for $18 more! However, it's not very difficult. Here are the steps:
Step 1. Open PSP. There are 2 screws on the top of the PSP.
Step 2. There are 4 screws behind the PSP and one on the bottom, as circled in the picture.
Step 3. Remove the faceplate and locate the PSP 2001 Analog Assembly. It is held into the console by 1 black screw, as circled in the picture.
Step 4. Remove the black screw and pry the joystick out of the PSP as shown below.
Step 5. It is important that you remove this clear silicon piece from the old joystick and install it into the new one. Its purpose is to communicate the movement of the joystick from the assembly to the motherboard. It sits between the assembly and the motherboard.
Step 6. After you transfer the piece, pry the motherboard slightly up as you slide the new assembly back in place as pictured.
Step 7. You will need to pry this piece up to slide the assembly into place so that it is seated. Replace the black screw and close it back up.
RELATED ITEMS
PSP-2001 Analog Joystick Assembly
Precision Screwdriver Set
to open PSP, PS2
PSP PSP-2001 Motherboard Silicon/Rubber
on Apr 14, 2010 | Sony PlayStation Portable (PSP) Slim...
My psp 2006 slim got bricked when i upgrade to gen-d3
Your PSP is got problem when your upgrade it to gen-d3. Kindly return it back to your previous software. There are so many consumers get the same problem with you.
Regards
Feb 16, 2011 | Sony PlayStation Portable (PSP) Slim...
The analogue joystick isnt working properly. the character wanders off in wrong direction on its own.
simple, get a replacement joystick module and install it on your psp. i did a couple. the psp really isnt that intimidating to take apart. compared to an xbox 360 or playstation
Dec 01, 2010 | Sony PlayStation Portable (PSP) Slim...
I have 2 psp slims with broken joysticks
Find the model number underneath the battery. You can get replacement joystick depending on the model on ebay. Then follow a disassembly guide, this one is good http://www.llamma.com/PSP/repair/complete_psp_disassembly.htm, and while being VERY careful with the screen (they crack very easily) you can remove the bits you need to and put a new joystick in.
Nov 28, 2010 | Sony Video Game Consoles & Games
PSP joystick woes...
try tightening the face plate more where the nub is. if ts not tight itll cause an intermiddent contact and not wokr right. if this dont work, you fried something w /static from your body. try geting a new metal chassis
Jul 18, 2008 | Sony PlayStation Portable (PSP) Slim...
New psp anolgstick won't work
try to clean where the copper makes contact. then tighten up the screws and connections.
Jun 14, 2008 | Sony PlayStation Portable (PSP) Console
Analog stick
then it is a internal fault is it under warranty if so id take it back and try your analog stick on the replacement one then your see if it your machine or the analog ?
Feb 09, 2008 | Sony PlayStation Portable (PSP) Console
Computers & Internet Logo
234 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
