Question about Akai PDP-4216M 42 in. Plasma Television
Monitor display had problem .
Only tv's left side have picture, other side have over 20 different colors signal-lines . When turn on tv the AKAI brand , only can display [black color] other half-side only display KAI brand . Need take to repair to solve this problem . All other function system are OK.
  • mucmhucky Apr 05, 2008
    My Akai PDP4206EM has picture and sound but the picture is not showing the right colors or I should say the picture is discoloring. Any help on how do i fix this. What part(s) do I need to replace? Thank you.
    President:
  • 778 Answers
Hello Lunhoo,
Your TV should still be in warranty. If so, yes you should take it in for repair. Even if it's not in Warranty, Akai may have a special warranty extension for your TV. Check it out.
Good luck.
Posted on Feb 28, 2008
How do I fix akai TV model #lct2785ta? TV screen remains blank and black, after I power it on.
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Mar 15, 2015 | Akai Televison & Video
NFL52w4100 has a sluggish reaction on the left side of my tv and a darker picture on the right side of tv and will fix itself every so often and then go back to this picture
- Flickering screen
- Dim screen
- Slow start
Apr 07, 2014 | Televison & Video
IN MY AKAI 20" COLOR
check your speakers if good, there are fusible resistors found at the power line of the amplifier section of the circuit maybe its open check also the transistors if good or bad if it is driven by an I. C maybe your I. C is busted replace I. C
Dec 22, 2010 | Akai 20" TV
I have A three year old AKAI 42 inch plasma tv---PDP4273M1---Mostly used as PC monitor. It was working just fine when I turned it off. When turned back on the next day, the on indicator light came on and...
Check to see what input setting the tv is on. It could still be looking for a signal from the pc input connection and no pc is hooked up thus getting no signal. Have the device you are trying to display on the tv connected and turned on and cycle through the inputs on the tv until you get a signal.
Sep 07, 2010 | Akai PDP-4216M 42 in. Plasma Television
AKAI LCT2016 20" LCD TV- Dosn't Resize picture properly
U can't fix this problems.Omly replaced board.The Tuner main board have dead componnents.Tries Shopjimmy.com,Ebay.com to buy a refurbish Main Tuner signal board for replacement.
Feb 20, 2010 | Akai LCT2016 20 in. LCD Television
Black & White picture for DVD
When using the Component outputs on the player, make sure they are enabled in the player menu system (or sometimes there is a rear panel switch and sometimes both), as most players default the Component outputs to off. Even when the Component outputs are off, you will often get a color-distorted signal out as many players share circuitry between the various outputs.
May 19, 2009 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Picture on AKAI 54 inch HD ready tv is not square.
akai is not a good brand of tv to start with they seem to have alot of problems and finding parts is impossible to do
Oct 16, 2008 | Akai PT5598HD 55" Rear Projection...
Pitcture is Wavy
Sounds like the tuner is going.
Dec 05, 2007 | Akai PT4799HD Rear Projection Television
Vertical Lines / Color Differences at edge of Analog vs HD Picture
EXACTLY-YOU HAVE THE USUAL "AGING" CRT PICTURE.THIS WILL ALWAYS HAPPEN WHEN YOU WATCH THE TV W/BLACK BARS ON THE SIDE,THERE IS NOTHING SHORT OF ALL 3 CRTS' REPLACEMENT TO FIX IT. JOE TV
Oct 31, 2007 | Mitsubishi WS-55819 55" Rear Projection...
Akai PDP-4216M 42 in. Plasma Television Logo
117 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
