Question about EliteGroup PT800CE-A Motherboard
Pc problem 2 with beep when it run
When i turn on my pc it never turn on but the red light is still blinking like it was loading and no beep then my monitor was blank...but sometimes it run and has a beepwhat could be the main problem of my pc?pls help me tnx!!!but the fan still running and restarting when you use it
    President:
  • 778 Answers
Hello Jake Ponce,
You could power your machine down, and open the case. Then making sure you are grounded to the case (to prevent ESD damage), I would reseat all socketed hardware and plugs, such as Memory and graphics cards, PCI slot devices, etc... Unplug and re seat everything (especially anything that has been manipulated recently), then close the case and power it back up. It's worth a try and could very well solve your issue.
Good Luck.
Posted on Feb 28, 2008
Why does my pc's power light indicator keeps blinking red (2 beeps) after it powers on and begins to boot, running for about a minute or two?
Hi
This means your PC is doing a Thermal Shut down, the CPU is getting to hot, this means the fan is not running at all or fast enough, or is dusty causing loss of cooling to the CPU.
To fix this open the case look at the fan if its running as it gets louder I would say in your case it is, you need to remove all the dust from the fan and the heatsink I use a small USB fan from poundland (UK) this should stop this error.
Cliff
Aug 22, 2014 | HP Compaq DC7900 PC Desktop
Beeps red light hp pc
The blinking should be in a pattern.
Power Green On (S0) Computer on
Power Green 1 blink every 2 seconds (S1) Suspend Mode
Power Green 1 blink every 2 seconds (S3) Suspend to RAM
Power Green Off (S4) Suspend to Disk (if applicable)
Power Clear Off (S5) Computer off
Power Red 1 blink followed by 2-second
pause - Repeat
Power Supply failure
Power Red* 2 blinks 1 second apart CPU thermal shutdown
Power Red* 3 blinks 1 second apart CPU not installed
Power Red* 4 blinks 1 second apart Power supply overload (crow bar)
Power Red* 5 blinks 1 second apart No memory
Power Red* 6 blinks 1 second apart No graphics
Power Red* 7 blinks 1 second apart System board failure (detected prior to video)
Power Red* 8 blinks 1 second apart Invalid ROM
Hard Drive Green Blinking Hard drive activity
*Blinking
Aug 17, 2013 | HP Computers & Internet
RED BLINKING & BEEPING LIGHT COMES ON WHEN I TRY TO TURN ON
I would go back to make sure that its plugged in correctly. What is your PC doing when you see the Red blinking light on your hard drive? Do you hear any beeps?
Feb 20, 2013 | Computers & Internet
When i turned on switch dell vostro 230 it give no display and led colour is red
No Display, so does it seem like the computer booted up and is running except that the Display is black? Do you hear fans running, disk drive spinning, blinking lights or beeps?
I'm going to assume that in your case since you mentioned a red light that it is not booting up all the way. Therefore your problem is probably with the memory, the video card or some other motherboard issue.
Remove the Power Cord, Remove the Battery, Remove the cover that houses the memory on the bottom of the laptop then remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 19, 2012 | Computers & Internet
Monitors will not turn on due to a power spike. Tower makes a beeping noise with a red blinking light. What could be the problem?
The moitors did not turn on at all after the power spike?
If that is the case, probably some electronic components were burned due to power surge damage.
I advise you to contact the manufacturer for repair and your local electricity supplier.
The beeping noise and the red blinking could be indication that no monitor is plugged in.
Jul 06, 2011 | HP xw6400 Workstation - 2 x Intel Xeon...
Playstation 3 turns on than turns off with flashing red light
If it turns off randomly and blinks red and beeps, then it's an overheating problem.
If it turns off as soon as you turn it on and blinks red and beeps, then it's an overheating problem that is getting close to being a YloD.
If there is a yellow light mixed in with #2, then you have the Yellow Light of Death which kills your console. If this happens, repost on here saying you have the YLoD.
If the problem is #1 or 2, then leave the Ps3 off for a day and move it away from carpet and anything that makes heat. Also make sure it is atleast 4 inches away from EVERYTHING.
Feb 15, 2010 | Sony Playstation 3 (PS3) Console
Problem
there are many things that can cause this, first obvious causes would be bad ram, dead mainboard or hard drive.. i say dead motherboard due to the fact you say there is no post beep on startup, easy way to tell, remove all the ram, and turn it on, if it squeels at you, you know the motherboard still at least is somewhat operational, next thing try replacing the ram.
Feb 28, 2008 | EliteGroup PT800CE-A Motherboard
Pc problem
Sounds like the power supply may need to be replaced.
EliteGroup PT800CE-A Motherboard Logo
24 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
