Question about ASUS P4VP-MX Motherboard
Only turns on but does not boot
One day i left the computer plugged for the whole day. when i came back i plugged it out. then i tried to turn on again the pc but it freeze when the windows xp logo came out. then i restart it then freeze when it's doing the memory scanning. after that whenever i turn it on only the YELLOW light in front of the casing only lights up and nothing else happens no boot sound whatsoever.
by the way the ram and harddrive were ok. and i have a new power supply unit.
the video card was not ok.
the processor and motherboard i was unable to check.
i unplugged every connection inside, i even unseat the motherboard from the casing, and tried to put back things in except for the video card since there is an onboard vidcard.
this time it's the RED light turns on and still nothing happens.
my motherboard is ASUS P4VP-MX and my processor is a 2.4ghz p4.
hope you guys can answer my problem. thanks!
  • 2 more comments
  • 7600 Feb 28, 2008
    i also forgot to add that i also changed the battery to a new one.
    but how i do check it by the way...?
  • 7600 Feb 29, 2008
    i was able to put back the yellow light i mispinned the connections from my casing to the mother board.
    about the ram. there was no sound.
    i also tried turning on without a processor. then without the hardrive, etc. no sounds whatsoever. just the yellow light turned on.
    how will i know if which one is busted? the processor or the motherboard?
  • 7600 Mar 01, 2008
    i was able to check my processor and its working ok.
    so what's with my motherboard? thanks!
  • 7600 Mar 02, 2008
    looks like the mobo is busted... so sad.
  • 749 Answers
Check for the cmos battery!! see if it still on 3 volts
Posted on Feb 28, 2008
  • 1 more comment
  • Rommel Balcita Feb 29, 2008
    you needed a TESTER to test it, but since you stated that you changed it with a new one there is no need for that TESTER.
    Check the memory slot... do this... remove the RAM and switch it on, you should hear a LONG BEEP for that. Next...
    You need to clean the contact points of the RAM use a coarse eraser to clean it.
    Insert it back and try turning it on again....
    post me back again...
  • Rommel Balcita Mar 01, 2008
    The basic components for troubleshooting is through these four parts:
    1. Motherboard - if error... no beeps, does not function
    2. Processor - if error... high or low beeps, not seated properly
    or not compatible
    3. RAM - if error... repeated long beeps, not present or
    not compatible or faulty
    4. Video card - if error... 1 long 2 short beeps, not seated
    properly or faulty
    Hope this helps... try other parts to this motherboard, it may not be compatible with the new ones.
    Hope this guides you to solve this problem.
  • Rommel Balcita Mar 02, 2008
    Also when checking don't plug in the keyboard and mouse...
    again... goodluck!
Hi When I boot it up , the acer emblem comes up then the screen goes black with a small cursor flashing in the top left hand corner
If you are having just a blingking cursor on boot up you must check if there is a disc inside the disc tray, or kindly check as well if there is a USB flash drive plug in on your computer and if there is any please remove them while your computer boots up as your computer might boot from it and it may cause just blingking cursor.
If there is no disc or USB flash drive installed, what you can try is to boot your computer in safemode and perform a system restore. Atleast restore back your computer 2 to 3 days back before this problem happen.
To perform safemode:
- turn off computer
- press the power the botton and after 2 sec tap F8 repeteadly until you see all the safemode options
- select safemode with networking/safemode use the arrow keys to highlight it then press enter
- computer will automatically boot into safemode desktop.
To perform system restore:
- click start > all programs > accessories > system tools > system restore
- click next then select desired date then follow the on screen instructions
- once system restore is done it will automatically restart and boot your computer in normal mode.
Cheers . . .
Mar 14, 2011 | Acer Aspire 5920-6727 Notebook
My compaq 7540 desktop..if we turned on it will load windows and after tht it will again restart..thn load window and again...repeating this whole day....
try to boot it by pressing F8 key while booting
then restore it back to earlier days
If you can't boot it to safe mode then you need to reinstall your windows using your quickrestore CD/DVD
May 07, 2010 | Compaq Presario 7594 PC Desktop
I left it on last night. This morning it was off
check your power cord to insure that you are getting power. make sure power cord is plug in the back.
look in back of computer. you will see a little orange switch. it says 115/220 click to 220. boot computer.
if computer boots up turn off and click back over to 115.
if it does not boot your power supply in your computer needs replacement.
Nov 14, 2009 | HP Pavilion a1410n (ER890AA) PC Desktop
My phone will not turn on or charge!!
Hey just keep it plugged in for like a whole day, then try it mine did the same thing, i left it plugged in for 8 hours or so and then it worked again!
May 14, 2009 | Sony Ericsson W850i Cellular Phone
Beeps 2 times & a warbling noise when trying to boot up - unplugging power lead & pressing ON/Off button & reconnecting power lead starts up OK - but it can be OK for several days & then repeats the p
The Cause of Problem:
The Power Buttons electrical circle sometimes just braked it by one of sensors and the result is the 2 beeps and Power Supply is in protected mode error.
The whole computer is turn off but the power button is turn on and this is the nub of the matter. Because if you want turn on the computer you can't because already turn on but just the Power button and you can't do anything.
The solution:
You need just change the Power Supply and don't do anything just the power cable put into the Power Supply after turn off computer.
Finaly change back the Power Supply.
Apr 25, 2009 | HP Vectra VL420 Intel Desktop PC - Intel...
I left my Compaq 2510p on standby with the battery low a couple of hours ago. I have now connected it to the mains charger and tried to turn the machine back on, but it won't turn on...any ideas what I...
Might be stuck in hibernation. Pull the battery and ac power for about 1 hour. Replace and try to boot. If fails, pull the battery and try to boot just off ac power.
Dec 01, 2008 | HP Computers & Internet
Computer boots fine but the monitor is blank
if the monitor works fine on your laptop, the problem definitely is at the computer, possibly with the video card (if it is using one). it could have loose connection, or parts might have damages. it seems the problem is intermittent so electronic component of the video card could have parts partially damages or leaky components.
if your still using the motherboards built in video out put, try installing a new video card.
Oct 31, 2008 | Computers & Internet
My mp3 wont turn back on
while you are holding the volume plus button down,plug your player in your puter and keep holding the button until it goes into the recovery mode.it worked for me.
Sep 21, 2008 | Creative Labs ZEN V Plus MP3 Player
Computer 'Won't boot
you did try the other card? obviously u did.
now remove every thing but PROCESSOR and RAM and forget about the Video remove all internal parts. then see that it beep or not.
a normal start up beep.
Jan 07, 2008 | Computers & Internet
Dell Inspiron B130 wont boot
First remove the battery from the PC! Leave it off for a short period of time! about 2min. This allows the computer to erase anything in temporary memory. Place the battery back onto th PC and try to boot it up. The other thing you can do is boot the pc up with just the power cord in place. See if it boots just from the power cord. Sometime the batteries from dell causes the whole entire PC to become unresponsive.
Nov 26, 2007 | Dell Inspiron B130 Notebook
ASUS P4VP-MX Motherboard Logo
101 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
