Question about Epson LX-300+ II Matrix Printer
Small Height Paper Size Problem
I used Epson LX-300+ II Dot Matrix
Printer roll doesn't stop when I set paper size height to 3" until 3.5"
But its stop when paper size height set to 3.6" or higher
I was try it to Windows XP SP2 and Vista Business
have any solutions?
  • KwokSen Feb 28, 2008
    but i need to print label with paper size height 2", its impossible to adjust margin until 1.6" isn't it?
  • samirh Nov 21, 2008
    My problem is also same but the paper height is 6"
How to printer sating of epson lx300+
Posted on Jun 22, 2008
  • 749 Answers
Here's an option for you to consider.... hope it helps!!!!
set it to 3.6 and make your adjustment on the page margins.
Posted on Feb 28, 2008
  • Rommel Balcita Feb 29, 2008
    That setting is really too small for the printer to activate the paper feed detector... Once inserted, it switches and then when the paper passes right after that switch, it no longer sense the paper... try to find the paper feed switch located at the left corner of the paper feeder inside to to peep in and find a switch like a reversed hook, place tape on it to keep it pressed for a while and try printing... That is you have to do manual paper feeding on the roller.
Epson lx 300 printing a4 size
my minonlte is showing code co4
Aug 01, 2013 | Office Equipment & Supplies
Custom size doesn''t present on your driver on Form to Tray Assigment in
Hi, I can't understand what "Custom size doesn''t present on your driver " means. the drver is just the piece of sofware used by windows to make your printer work. Custome size setting should have nothing to do with the driver.
Feb 23, 2008 | Epson LX-300 Matrix Printer
How to change print paper size in tally
Hi'' first open the file you want to print or preview the file, as it open there is a word file on the left top of the screen , click left the file and you can see selection , click page setup then click paper and choose what paper do wish to use to print , just adjust width and height ,.
Aug 14, 2011 | Epson LX-300+ II Matrix Printer
Custem size paper are not creat
am using an Epson LX-300+II dot matrix printer in Windows XP. I am
trying to print checks that are tractor feed 8.0" x 3.66". I added the cusotm
paper size in the print server and it is saved correctly, however, when I try
to print, the print properties dialog does not show the paper size. In fact,
there are many paper sizes in the print manager that do not show up in the
list of available paper sizes.
Apr 13, 2010 | Epson LX-300+ II Matrix Printer
Epson LX-300+ II
just change the page length setting in printer .just press pause button and switch on the printer and change the setting accordig to the page size it is bettreif you take online help from epson service call center they will guide you how to set the page length.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 22, 2010 | Epson LX-300 Matrix Printer
How can i add paper size of tally printing in lx-300
if you want change page setting in your printer ..... to get the all settings of your printer press font button and switch on the printer (before take setting make sure that you printer loaded with paper ) goes through the instruction printed in the paper to change the settings ........ change paper size.....
you can map your tally printer paper size in system .....go to printer and faxes ... file..>server properties ...>select create a new from ...> change the name as you wise and change the paper setting and click ok ........
while you give print change paper size to your created paper size and check
Dec 19, 2009 | Epson LX-300+ II Matrix Printer
Setting custom size (tear off) paper
I have some problem, but now have solved
1. replace your original epson lx-300+II driver by IBM ProPrinter II from windows installation driver.
2. in control panel-->printer and fax-->choose IBM Proprinter II ---> click File-->server properties--> click form tab--> chek create new and fill new paper size and don't forget give a name (ex. 8.5x6)--> save form
3.In printer and faxs right click IBM Proprinter II-->choose properties--> click device setting tab --> change tractor feed, manual paper feed and upper paper tray feed to new name (8.5x6)
4. Good luck
Jun 18, 2009 | Epson LX-300+ II Matrix Printer
Setting of new paper size from epson lx-300 +II
your solution works fine with me, but the problem is i can't able to save the settings on the printer. so everytime i need to print on that given custom sized paper type, i need to manualy select it from advance tab on printer properties before i have a good print-out..
Anyways,Thank you very much.
Apr 13, 2009 | Epson LX-300+ II Matrix Printer
Epson dotmatrix printerseting i want the page set har bar page set karna parta ha
Jaisa ki aapne kaha, har bar page set karna padta hain.. Here's a solution.
sabse pahele aap aapke windows printer and faxes folder main jaayeeye wahan par aapka jo bhe dot matrix printer hain usko right click kijiye. Uske baad Properties main jaakar printer ke liye hamesha jo paper use hota hain say, A4, FS, A4 Continuous stationary etc. select kar ke save kar lijiye.
Aab aapke document main jaakar jo paper size aapne printer par set kiya hain uske aanusaar page size select karke print le lijiye.
Aab ki baar saahi print aayegi.
Feb 17, 2009 | Epson LX-300 Matrix Printer
Setting the Paper Size Programmatically
yes you can set the paper size just press the pause buuton for 5 seconds and swith on the power it will auomatically print printer default seeting and it will give the option for how to modified go accoringly and set the size . bye
Sep 28, 2007 | Epson LX-300 Matrix Printer
Epson LX-300+ II Matrix Printer Logo
574 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
