Question about Dell - NPS-200PB-73M (NPS200PB73M) Power Supply
TO noggin i have dell p3 computer.before two month when i work on the pc the pc automatically restart within half hour again &again,and shows on desktop physical memory dumping. now, when i turn on the pc the pc works for hardly 5-10 minutes & automatically turn off. Just after switching off the pc won't turn on. if i try to turn on after 10 hours then pc turn on for 10 minutes or below & automatically turn off.And not turn on till 10 hours passed. one small green LED glows on mother board when i plugged. plz tell me that on which part the problem occured. Are power supply fail or mother board fail ? if supply dead then which component got damaged. I HOPE THAT YOU WILL SUTISFIES ME QUICKLY. Thank you FROM PAPPS
  • 151 Answers
Remove all pwoer connector from motherboard and short green and black wire in supply shocket.If supply is run then it is the problem of motherboard.
Posted on Mar 05, 2008
My computer will not boot up. it says AHCI bios not installed. it is a dell 530 s inspiron can anyone help please. it also doesn't show to have cd rom but added A drive which it does not have it wont boot...
This can happen on some models. Turn the computer off and unplug the tower. Press the power button to discharge any stored power. Plug it back in and press the power button. You will probably get this message again but let the computer sit. Windows may be working in the background trying to start back up. Let it go for like a half hour to an hour. If it does not start you may have to do a system restore or a repair install to make windows start correctly again. If waiting longer does not work for you then let us know and I can give you instructions on how to continue the repair process.
Hope this helps... Dale
Apr 20, 2011 | Dell Inspiron 530s Desktop Computer
Have to restart to get sound working and then it only works for half hour before i have to restart again.
Go to the device manager and then remove the insalled sound driver after that restart the computer it should pick the drivers automatically if not the go to the website and enter your service tag then you will be able to download all the latest drivers for your system
http://supportapj.dell.com/support/index.aspx?c=in&l=en&s=dhs
Feb 03, 2010 | Dell Inspiron 6000 Notebook
My lab top when restarted it beats 3 times, screen blank
Nothing to worry, Open your laptop from the back side.Remove the RAM  and reinsert it.
Your system will work fine.
Rate this solution.
Dec 27, 2009 | HP Pavilion dv9700t Notebook PC
Keeps coming up with configuring updates stage 3of 3 0% complete do not turn off your computer then it shuts down and comes back on again
Please use this solution thta I have placed on this forum.
Please follow exactly these steps then you computer should be working again.
I have used the following solution.
Restart computer.press f8 then choose option restore computer.
choose option open command.
type: prompt winsxs (press enter)
type: move C:\windows\winsxs\pending.xml text.xml (press enter)
type: exit and restart computer.
Computer should be working again.
good luck.
hope it works for you.
pieter.
Oct 17, 2009 | Dell Inspiron 1525 Notebook
Dell 5150c shuts down orange flashing light
It was a faulty or worn out power supply fan. I just replaced it and the computer has been running for about an hour and a half and still no shut down. The system temperature is stable. It runs quieter now. New fan cost 13.88CAD.
Mar 09, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
My WiFi isn't working on my Ispiron 1525?
this is working thanks a lot dear
i solve out my problem
thaks again
take care
and share the knowledge
Feb 01, 2009 | Dell Inspiron 1525 Laptop
Dell PowerEdge 1600SC Server problem
I had the same thing happen in a 600SC about a month ago.
Replaced the memory, and it fixed the problem.
It did the same hang. Would run fine for any where from a hour to 3 hours, and then quit (hang). And I got the same message. Talk to them and it was a short in the memory module, so some times it would read the entire stick, other times it would "not see it", and that would lock the OS.
Sep 03, 2008 | Dell PowerEdge 1600SC Server
My dell laptop still freeze
if its windows XP try doing a MSCONFIG:-
startup_tab_xp.gif Here's a good example. On my computer I have a mess of MP3s and I listen to those MP3s with a program called WinAmp. For some reason or other, WinAmp decided that it should always be running on my computer even when I am not using the program. That's silly. To prevent WinAmp from automatically starting every time I boot my computer, I ran MSCONFIG and unchecked "WinampAgent." That's it.
Remember, disable only those programs that you recognize and don't need to have running all the time. When in doubt, leave it on.
5. Click on the OK button.
6. A message will pop up telling you that you must restart your computer before these changes will take effect. Click on "Yes" and your computer will automatically reboot.
restart_box_xp.gif 7. That's it! Your computer should now boot faster and crash less.
And if you ever want to turn on any of the startup items you disabled with MSCONFIG, just run MSCONFIG again.
when your system restarts you will get a prompt that you have used systemconfiguration utility
do remember you put a chkmark in the box which says do not show me this message in future and then click ok.
Jun 13, 2008 | Dell Inspiron 6400 Notebook
Computers & Internet Logo
160 people viewed this question
Alun Cox
