Question about Medion Audio Players & Recorders
Charger Lost charger to model No.MD 95639/mdvid220
Sharp MD 702 Need Manual and charger or guidance on alternative\r\ncharger
Hi Boothsigns, Owners Manual available HERE Service Manual available HERE
Charger alternative: Any 5Volt DC with the same size plug of the original.
A universal power adapter LIKE THIS set at 4.5 volt will work as well. In that case, before connecting the universal power adapter to your MD 702: 1) Make sure the voltage is set to 4.5v; 2) Make sure that the polarity +/- is set properly to avoid damaging your unit!
Best of luck!
Nov 16, 2010 | Sharp Televison & Video
I need a manual for a outdoor spirit metal detector md-m201
what kind of charger does the outdoor spitit metal dector use
model 201
Oct 13, 2010 | Sport & Outdoor - Others
I have a Sharp MD-DR470H Minidisc player with a gumstick battery, i cannot find a charger anywhere, can you please help.
I've deliberately avoided answering your question for a few days to see whether someone else had located a gumstick battery charger, but clearly they have drawn a blank as well. They were never a common item even when Sony sold them new.
You may wish to do as I do: I use broken MD players as chargers. There are millions of MD units lying unused, most are worthless now and many are broken (typically the fatal TOC error). As a result it's easy to get them for nothing on local FreeCycle and Freegle groups and often they come with spare discs, batteries and other accessories. best of all, most of them are still in working order so you may even end up with a free upgrade. Every bit of MD gear I own has come from FreeCycle and Freegle except for my superb MZ-n910 which remains in regular use.
As luck would have it, I was about to hit the "Post Solution" button when I found this one on eBay. It wasn't there when I last looked! it will hold two gumstick batteries.
I hope that my answer has been of use, please take a moment to rate my reply.
Sep 26, 2010 | Sharp Audio Players & Recorders
I,have lost user guide of md 9000.so pls give me the pdf file of that guide?
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
I was not sure about whether this is the model you are looking for.
But this says JVC MD 9000.
Kindly comment if this is not the one you are looking for.
Aug 12, 2009 | Panasonic Video Cameras
Lost the charger for T5720 cradel, need voltage specs for replacement
HI,
The charger cradle for this model is 220V.
Hope this helps
May 24, 2008 | Motorola Talkabout T5720 (7 Channels)...
59 people viewed this question
Top Medion Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Medion Audio Player and Recorder Expert? Answer questions, earn points and help others
