Setup: Asus A7N8X Deluxe running AMD Athlon Xp 2700 w/NVidia GeForce 4 TI 4200 w/AGP8X Situation: Everything was running fine. When rebooted system would not bring my DVD and DVD Writer up and they show Code 39 but when I try to update drivers it indicates the best driver is already in place. Also, It shows 2- M-Systems Disk on Chip 2000 are Code 10. Wait a min. they show Code 12 now??? Not enough resources- that's new! The biggest problem is that I'm 64 and know just enough to get in trouble. Help, but be gentle.
  • thepoetx Feb 28, 2008
    I had already tried everything you suggested above.
    The Microsoft site Wealthwise sent me to and an automatic fix to the upper and lower registers and my DVD's are working again. The two M-Systems Disk on Chip are still not functioning. I have no clue what they do or how to fix.
    President:
  • 778 Answers
Hello Thepoetx,
You can try a couple of things. One, Click Start, then Right click on "My Computer", then select properties and left click, then click on the hardware tab (once the properties box opens) and click the "Device Manager" button. Go down the list and find the drives you are having problems with and right click on each one and select "Uninstall", then re boot your system.
If that doesn't do it? You can try a manual Windows update (Start, all programs, Windows update/Microsoft update near the top of the list) and choose "Custom" instead of "Express" option for the type of update. Once the scan is done, you can look at additional updates (hardware and software) to see if there is anything related to the optical drives (CD, DVD drives) in question, and add those updates to the critical/security updates and the update may cure your ills.
A third option would be to search the Manufacturers Support site for the devices and download the latest drivers from them and update your drivers that way.
I hope this helps, and Good Luck.
Posted on Feb 28, 2008
    Brigadier General:
  • 3,614 Answers
Sir,
I try to get into this can you please provide me some info. bout the operating system you use, and the type of or brand of dvd writer that you have.
Thanks,
micro
Ge force 9500gt, 512mb, ddr2 compatible with asus a7n8x deluxe
The ASUS A7N8X only supports AGP8X, the 9500GT is PCI Express. There is no way the 9500GT will work with this board.
Dec 12, 2011 | ASUS NVIDIA GeForce 9500GT, (512 MB) PCI...
Asus a7n8x-e deluxe, nvidia geforce 6800gt 512 - OS doesn't start
Try to start your computer into a safe mode and then remove the old graphic card driver but if you cant get to safe mode then probably theres a problem with your operating system. Consider reformat and install a fresh copy of any OS you prefered.
Oct 23, 2009 | Computers & Internet
Motherboard problem..
It sounds like the front panel wire has either come loose from the motherboard or is plugged into the wrong spot. Recheck the motherboard to see if the wires are in the right place & not loose. Hope this helps.
Dec 27, 2008 | ASUS A8N-SLI Deluxe Motherboard
Ram Upgrade
Max speed supported for your mobo is: DDR2-533
You will have to buy (4) 1gb sticks (2gb sticks not supported)
To use all four gigs of ram you need a 64 bit os.32 bit only supports 3gb of ram. Hope this helps!
Here is the specs :
ASUS A8M2N-LA (NODUS-GL8E) (DDR2-533MHz) Memory Maximum Memory 4GB Memory Slots 4 (4 banks of 1) non-removable base memory 0MB Machine name: ASUS A8M2N-LA (Nodus-GL8E) Motherboard
CPU options: Supports AMD Athlon 64, Athlon 64 X2 and Sempron processors.
Chipset: Nvidia GeForce 6150 LE Chipset
HD Bus:
Front Side Bus options:
Memory Speed options: PC2-4200 DDR2-533 240pin SDRAM DIMM
Special notes:
- Motherboard manufacturer's name: ASUS A8M2N-LA
- HP/Compaq name: Nodus-GL8E
NOTE: *Actual available memory may be less w/o 64 bit os
Dec 24, 2008 | Computers & Internet
Installing extra memory causes freezing + closing down of pc
Check these specs for your board.it will support 2gb but only if its pc2700.anything greater will not boot or become unstable quickly.here are your specs.also i am enclosing an ASUS link for any and all manuals etc. for this board.asus a7n8x-vm motherboard
Specifications www.microsoft.com/Genuine"] --> CPU Socket A for AMD Athlon XP
Thoroughbred/ Barton Core Support Chipset NVIDIA nForce2 IGP
NVIDIA nForce2 MCP Front Side Bus 400/333/266 MHz Memory -Dual Channel Memory Architecture
-Supports up to 2GB of 2700/PC2100 DDR memory
-2 DIMM sockets Expansion Slots AGP8X (1.5V only)
3 x PCI VGA -Integrated GeForce4 MX GPU
-Integrated TV encoder
-NVIDA nVIEW dual-display architecture
-Support DVI (AGP-NV-DVI) and TV out (AV/S) cards Storage/RAID 2 x UltraDMA 133/100 Audio Realtek ALC650 6-channel CODEC
S/PDIF in / out interface LAN Integrated 10/100 Mbps LAN controller + Realtek PHY USB Integrated 6 USB2.0 ports Special Features Power Loss Restart
Support S/PDIF in / out interface
ASUS MyLogo2
ASUS C.O.P. (CPU Overheating Protection)
ASUS EZ Flash Back Panel I/O Ports 1 x Parallel
1 x Serial
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x VGA
1 x Audio I/O
1 x RJ45
4 x USB 2.0/1.1 BIOS 4 Mb Flash ROM, AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.3, ACPI, ASUS EZ Flash, ASUS MyLogo2 Industrial Standard PCI 2.2, USB 2.0 Manageability WfM 2.0,DMI 2.0,WOL by PME,WOR by PME, Chassis Intrusion Support Disc Drivers
ASUS PC Probe
Trend Micro™ PC-cillin 2002 anti-virus software (OEM version)
ASUS LiveUpdate Utility Accessories User's manual
UltraDMA cable
FDD cable
I/O shield Form Factor microATX Form Factor, 9.6"x 9.6"(24.5cm x 24.5cm)RICHARDM69
Dec 15, 2008 | ASUS A7N8X-VM Motherboard
Processor
This are the compatible with this motherboard : Compatible Processors - Athlon, Duron, Athlon XP , Processor Socket - Socket A , Chipset Type - NVidia nForce2 400 , Max Bus Speed - 400 MHz .
This is the complete specs for this motherboard , check this link http://www.shopping.com/xPF-Asustek-A7N8X-X-Socket-A-LAN-nVIDIA-Audio
Don't forget to rate the solution FIXYA thank you.......
Oct 18, 2008 | ASUS A7V8X Motherboard
Max. AMD for Asus A7N8X-X
Find the manual online.  Also, your question is foolish in light of the much better efficiency of new multi-core systems and general inavailability of AMD Athlon XP 3200+ in socket-7 form; it's not like you'd save money changing CPUs, or your system would merely fake it for a few days if you put in an XP 3200+ (in the socket that fits!) you had set aside, and it did work.  On the other hand, XP2600+ overclock pretty well.
Sep 10, 2008 | ASUS A7V8X Motherboard
Pc upgrade !
IAN.S
Where you need to be is on Asus web site. Your board can handle ONLY; Athlon XP 3200+(400 MHz FSB)(Model 10)(Barton), AXDA3200BOX
With that CPU you must also have bios version 1004.
Check PCB and BIOS versions before flashing BIOS!
asus A7N8X supported CPU click here; http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=A7N8X
Since you seem to need your manual. Click the link:
http://dlsvr01.asus.com/pub/ASUS/mb/socka/nforce2/a7n8x/e1859_a7n8x.pdf
You do not have an intergrated video card. You have a 1.5v 8x
AGP video slot.
I suggest you call Asus & make sure your CPU model AXDA3200DKV4E will be supported over model AXDA3200BOX.
You can call Asus tech M-F EST at 812-282-2787.
Good luck & Have a great day!
Mar 16, 2008 | ASUS A7V8X Motherboard
Computers & Internet Logo
60 people viewed this question
Alun Cox
David Payne
David Payne
