Question about HP DeskJet 895cxi InkJet Printer
Feeder grabs several sheets at a time...need a service manual?
I have a Deskjet 895 CXI and the when I print it just keeps on grabbing serveral sheets at a time...Help?
Domenic
  • Domenic Pittarelli Mar 01, 2008
    how...is there a diagram...of how...to change the intake rollers.I have heard today...that if you use sandpaper lightly....and make the rollers rough...it will grab better...
    Thanx...
    Dmenic
  • 85 Answers
Change the intake rollers.
Posted on Feb 28, 2008
Paper feeder grabs several pieces of paper at once
The spot in which the paper is fed into could have a fence/blocker. Use wood or a little hunk of aluminum to only allow 1 sheet. You could get fandy and use a rod that could also be mounted on the font.Be crea8tive and good luck.
Jul 21, 2012 | Canon PIXMA MP530 All-In-One InkJet...
I am trying to print a label through the document feeder and keep receiving error messages on my Brother MFC9320CW AllInOne Printer .."Open the Top cover and pull out all 4 drum units completely and...
Try putting more than one sheet of labels in the paper tray. Even if you're printing one label, it helps the printer grab the paper without that error somehow. If you're already using more than one sheet, I don't know. Good luck either way!!! :)
Jan 18, 2011 | Office Equipment & Supplies
Printer paper feed
Hi there
This hapens a lot with different printers, best way is to gave your papers a good shake and keep in a worm place then it may work for you.
All The Best Pineworks
Mar 05, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
My praftically brand new Canon Pixma MP620 printer grabs more than one sheet of photo paper and stops printing picture on first sheet then garbles several pictures on a portion of the next sheet. I just...
check the printer's printing preferences on properties option.should be set to normal then check the printer rollers if its dirty where the papers pass thru, if the problem persists load only 1 paper every time you print for the printer not to grab more papers.i think it is in the feeder and the sensor maybe its dirty need to be cleaned up.
Feb 22, 2010 | Office Equipment & Supplies
Feeder wont grab sheets
open the cover of the document feeder you there will find two rollers (blue and grey) clean these rollers with a cloth dampened with nail polish remover
Oct 06, 2009 | HP Laserjet M2727nf Multifunction Printer
Paper jam in Panasonic KX-
Your document feed is separate from your received and report prints so that's why your reports are printing ok and the document feeder jams. When you open up the doc feeder and look inside the machine you will see a roller and above it on the cover that opens you will see a rubber pad. Clean both the roller and pad (in fact anything in there that is rubber) with a rubber cleaner, alcohol, or even soap and water on a cloth without it been dripping wet. You will probablt find that they are very dirty. The roller feeds the document in so that needs to be clean and the pad helps to keep all the other docs from feeding in at the same time and that should be very clean so it produces good friction.
Jul 07, 2009 | Panasonic KX-FHD331 Plain Paper Thermal...
Canon R265 keeps grabbing 6 sheets for printing one sheet
Paper has different thicknesses called Mils. Make sure you are using the correct paper for your printer. Paper that is thinner than is intended for your printer may sometimes cause it to take multiplesheets.
Jun 15, 2009 | Epson Stylus R265 InkJet Photo Printer
Information on how to use rear feed
1. Prepare your doc/file for printing.
2. Insert card stock with narrow side of stock in slot in back of printer until it hits rollers and stops. Don't force in any card stock thicker than max. rated.
3. Change printer setup to feed from rear.
4. Print.
Depending on what software you print from, you may need to change this each time you print if you intend to keep printing from that "tray."
Mar 09, 2009 | HP Deskjet 1120c InkJet Printer
DOCUMENT FEEDER
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 08, 2009 | Canon imageCLASS D760 All-In-One Laser...
Vertical paper feeder for the copier not grabbing next original sheet
I'm having a similiar problem. Can't consistantly feed one sheet at time. If i load several sheets it pulls all through, etc
Sep 03, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
HP DeskJet 895cxi InkJet Printer Logo
152 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
