Panasonic TV/VCR combo
My TV turned off suddenly and all of the lights (timer light, recording light, etc.) came on for a few seconds then went off. Now my TV won't turn on at all. I tried a different outlet and still nothing. TV is rather old, but never had a problem with it. Help?
  • 979 Answers
Shop time. Plan on spending 75 to 125 dollars for power supply worl...accordianman
Posted on Feb 29, 2008
Tv wont turn on
On a lot of the Panasonic units that is normal--idiot light that means nothing at all.
Some people actually cover it with tape so do not have to look at it.
Apr 29, 2012 | Panasonic PV-C2061 20 in. TV/VCR Combo
T.v wont turn on
The light means nothing---if TV will not turn on or comes on briefly and shuts down--could be a jammed or not working mechanism in the VCR or the TV may have a power supply problem.
Hello i have a toshiba md9dm1 tv/dvd combo and i lost my remote I have a universal ge remote none of the codes work Do you know the code for my tv/dvd combo?
hi,
If you remote is a 4 digit one then the codes are
0394, 0924
If the remote is a 3 didgit one then the codes are
394, 902
MANUALLY ENTERING CODES
1. Manually turn on the device (TV, VCR, DVD, etc.) you wish to program.
2. Press and hold the CODE SEARCH/SETUP button on the remote until the
INDICATOR LIGHT lights, then release.
3. Press and release the button for the device you are programming (TV, VCR,
DVD, etc.). For AUX, press AUX then the device button you are assigning to
AUX. The INDICATOR LIGHT will blink then remain lit.
4. Enter the three or four digit code for your device using the number buttons in the
GE Universal Remote. After your code is entered the INDICATOR LIGHT will
turn off.
5. Aim the remote at the device (TV, VCR, DVD, etc.) and press the POWER
button. Your device should turn off
OK
Aug 03, 2011 | Toshiba MD9DM1 9 in. TV/DVD Combo
The cst in light keeps blinking how to turn it off
Hello
I managed to find a PDF manual for your VCR Combo, However i couldnt find anything to indicate a reason for the Cst in light flashing. I did find however find that the TIMER REC Light flashes if T-SET is pressed for a timer recording, but there is no tape in the DVD/VCR. It also flashes when all timer recordings or One-Touch Recordings are finished. So possibly this could be the light you see flashing.
The PDF can be found Here
Hope this helps
Mar 06, 2011 | Symphonic WF803 DVD Player/VCR
Need remote control code
Hello
Three digit universal remote control code for Panasonic are:-
003/ 054/ 055/ 062/ 070/ 148/ 149/ 170/ 171
Four digit universal remote control codes for Panasonic are:-
0171 0148 0054 0170 0062 0374 0381 0437 0950 0003 0070
Four digit unversal remote control code for Panasonic TV/DVD/VCR combo is
0437
Where the code is listed as [### ###] the first is for the TV and the second is for the VCR/DVD. Otherwise just the one code operates both the TV and the VCR/DVD.
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK.
Dec 02, 2010 | Panasonic PV-DM2792 Triple Play 27 in....
I am looking for the direct tv remote code for tv model PVQ-M2509 Panasonic Omnivision VHS como.
Hello
Four digit universal remote code for Panasonic TV-VCR combo are:-
0374 0381
Three digit universal remote code for Panasonic are:-
Direct Code Entry
Nov 25, 2010 | Panasonic PVQ-M2509 Combo
Timer VCR Recording for a Toshiba MV13M2 13 in. TV/VCR Combo
Hello, you can go to the toshiba web site and download the manual from there.
The other option is to go into the TV menu, and select the timer rec set selection and access it there and fill in the times for the program you want to recording and that should do it.
I hope tihs helps.
BWLY
Jan 23, 2009 | Toshiba MV13M2 13 in. TV/VCR Combo
RCA T13060GY
You or someone may have press record and the set is in record mode. that way whatever time it's set for it will come on. Or you have to unplug to reset. Leave off for atleast 1hour then plug back in.
Sep 23, 2007 | RCA T13208 13 in. TV/VCR Combo
Televison & Video Logo
100 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
